Question about Bose 3·2·1 II System
Bose av 321 Lost subwoffer.
Is there anyone out there how has the diagram fir the DB15 connector on the bose AV 321 system, i had a break in in my house ans speakers and sub stolen they could not get the headunit, hehe but now i want to use it just with audio out so i need sohow to kvow where the power is on the connector, i know it´s 16v but i dont kvow whitch ones of the pins do what. So a diagram or a drawing is badly wanted
Regars Tomas in sweeden.
  • 16 Answers
SOURCE: bac speaker bose 321
The arrays from this system are only designed to run with the Bose Acoustimass / subwoofer, which in turn will only work with the Bose DVD player. If you use them directly to an amplifier, they'll sound poor / wierd and you probably blow the drivers. You might even damage your amp.
Each speaker has 2 drivers firing in slightly different directions. The idea is (when its used with the 321 system), the inward speakers give a mix of front and centre, the outer drivers give a mix of front and rear. A normal amp won't do this....
Posted on Jan 18, 2008
  • 905 Answers
SOURCE: bose 321 system reads bad disc on all dvds
if will not read a laser lens cleaning disc , then it will need to be opened up and the laser lens will need to be cleaned manually with the cleaning solution and a cotton tip , but do it easy and dry the lens with the cotton tip
if that don't do it then the laser mechanism will need replacing
electech
Posted on Nov 27, 2008
quang123
  • 107 Answers
SOURCE: Bose Lifestyle 50 - connection to a non-bose amplifier
The 2 system are completely different your is low level input and its is having only 2 input L and R when those signal they get inside your sub it process through an DSP ( Digital Signal Processor ) and become 5 output to yours satellite cube speakers
The AM6 or 10 are high level input connected direct to any output of any AMP from those signal they convert down to low frequency for sub woofer
Posted on Dec 16, 2008
cjackHD
  • 71 Answers
SOURCE: Adding Spaekers
If it's an original 321 system (series 1) then it has an audio output on the back. (via RCA jacks) You would still need an amp or receiver to connect the speakers to.. (unless they're powered speakers)
If it's a 321 series II or 321 series III- it does not have an audio output.
If the system has a DVD tray right in the middle of the media center, then it's a series 1.
Otherwise, you'd have to get a 1/8 splitter to come from your Mac's headphone output. (still- you will need an amp/receiver or powered speakers to have both 'rooms' playing the same thing from your computer)
Posted on May 31, 2009
I have a bose 321 system and I was wondering if there is a way to turn the bass up and down without the remote. I lost it
321 Home Entertainment System - Bose Product Support
worldwide.bose.com/productsupport/.../321.../page.htm...
Bose CorporationDiscover product support for your 321 home entertainment system. ... Learn how to setup and place your system components. more » ... You can adjust bass and treble levels to suit your listening preferences and your ... Discover how to use buttons on your remote and media center control panel to ... Get Adobe Reader.
[PDF]3•2•1 Home Entertainment System - Bose
worldwide.bose.com/axa/assets/pdf/.../og_321.pdf
Bose CorporationJan 29, 2002 - within the system enclosure that may be of sufficient magnitude to constitute a risk of electric .... Turning off the internal speakers in your TV .
Jan 18, 2016 | Bose 321 Series Iii Dvd Home Entertainment...
Playing fine but when is off is still plying
Control buttons on the Media Center may need to be replace by a Bose service Technician.
Sep 26, 2015 | Bose Av3-2-1 Series Ii Media Center...
Bose av321 video settings won't display on tv
Make sure the video output from your Bose System is connected to the right input source of your tv.If it does not work,try using a different remote control.If it still doesn't work,then you will need the service a Bose repair technician.
Jan 28, 2013 | Bose Av3-2-1 Series Ii Media Center...
How to connect Blu ray disc player with my Bose 321 system. I have 1080 p samsung LCD TV. How to get the best.
hi,
do the following.
1. connect ur blue rays hdmi out to ur tvs hdmi input.
2. connct blue rays out to any one of the coaxial(aux) input of bose.
3. connect ur tvs optical audio output to optical audio input of bose
4. connect monitor out of ur bose to any one of ur av in of ur tv. connect component video to better quality .
4 . in the blue rays audio setup select audio output priority as optical/coaxial
5 . in bose set aux as digital input.
to see blue ray select hdmi of ur tv, sellect in bose in which the blue rays coaxial is connected(aux) insert disk in blue ray an watch
to see dvd in bose select tvs corresponding input, select bose to dvd . insert dvd and watch
to whach tv program set tv to corresponding mode. set bose to optical audio input mode.
ok
Dec 15, 2010 | Televison & Video
My Bose AV 321 has only started playing the right side of the system. I swapped the cables and both speakers work, but only 1 side. I have also swapped cables and the same result.
The SAME EXACT thing has happened to mine!!!!! Does anyone have an answer for this? Surely the wire couldn't have failed and can a channel on the amp really burn out? I don't blare my system at all and ggggrrrrrr!!!!
Sep 11, 2010 | Bose 3 2 1 GSX System
Bose Model 321
the bose will not play anew dvd comes up need paasword
Aug 08, 2008 | Bose Wave Radio
ERROR MESSAGE
maybe the DVD player you got is not supporting all DVDs from around the globe. There is this thing called NTSC region 1 for Americas, region 2 for Europe, Region 3 for Asia, Region 0 for everything. I don't know the other regions but that must have been the problem.
Dec 13, 2007 | Bose 3·2·1 II System
Bose 3·2·1 II System Logo
90 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
