Question about Panasonic RR-US395 Digital Voice Recorder
Panasonic rr-us935 user account cannot download files from recorder to PC
I have a client in our environment who purchased this device and the software Panasonic_Voice_Editing_Pro_1.0 - however, when the client has the software installed via sms - they try to bring their files to the PC using the Panasonic_Voice_Editing_Pro_1.0 software and it gives an error - if an admin account user tries it works - anyone with an idea as to how to resolve this?
  • 4 more comments
  • zepharim Mar 03, 2008
    Hi Dineze,
    Thaks you very much for the direction. As it turned out, i needed to create a share and use the Voice software virtual mapping to it - this was done throught the Alias file and the user given full permissions to that share - then it worked.
    I had given the users full permissions to a folder that all client have access to use, however it would appear there is a security permissions issue that still would not allow the users the permissions regardless.
    Anyway, Thanks again for the info, it helped in my investigation.
    Summary,
    Create a share (either local or remotely)
    Give client full access to that share
    Map drive under the clients account to the share
    Add the mapped drvie to the alias file
    this allows the client to convert Wav files from the device to the share location.
    Cheers everyone
    :-D
  • zepharim Apr 01, 2008
    the driver is in the mail guest
  • teetrinkerin Jul 23, 2008
    hello everybody,
    i don't have the driver for rr-us395 either. could you please mail it to: teetrinkerin@gmx.de
    thanks a lot!
    tara
  • Marie Chandler Jan 09, 2009
    I have a client trying to send me files recorded on a Panasonic RR US395.  She doesn't seem to be able to copy the files to a disc on her laptop.  If I have the driver, can I open the .lnk file that has been copied on the disc?  Urgent help please, she is going back to the middle of nowhere tomorrow and we have 60 hours of audio files I need to get hold of!  marie.chandler@yahoo.com.au - please help with any info or driver!
    Urgent help needed.  Client has 60 hours of audio files I need to get hold of before she goes back to the middle of nowhere for work.  She copies files but we only get a voice editor.lnk file.  She used a Panasonic RR-US395 and I think if I had the driver I could get the files?  Is that right?  Any suggestions? Help!
Whats the environment like? If it is over a server or likes of, I suggest you trying your sharing/security options. If only an account administrator can do anything, it normally points to this problem....check settings that the admin account has to the settings your client has and see if there is a difference then work forward from there.
Posted on Feb 08, 2008
    Problem Solver:
  • 6 Answers
I found another alternative to this - using cmd - subst <drive_letter>: C:\<YourWorkingDirectory>
make sure the user or allusers have full permissions to this directory.
in the voice media menu, your drop down menu will now have this drive to work with or from.
Important - this method is a virtual drive not an actual long term mapped drive - meaning - when you log off or restart the machine - cmd method will have to be executed again - i created a script that does it for me and then launches the application - its easier that way.
also, if this does not work then make the working dir a share with all users permissions on it and network map a drive letter to it (not a virtual mapping) - then add this share to your alias and registry paths instead
hope this helps
Posted on Jun 11, 2009
  • Derrick Anderson
    Derrick Anderson Jun 11, 2009
    this is an easier work around for the write protected error - which occurs as a result of locked permissions on c:\ - note that normal network mapping does not work in this case - only the virtual drive method seems to work - good luck
The driver is in your mail guest
Posted on Apr 01, 2008
I donot have a driver of rr-us395 please send me a driver on jayeshpate@gmail.com
How do I download voice recordings from my Panasonic RR-US551 voice recorder to my desktop computer?
The RRUS551should come with a short USB cable that you can plug into your PC at one end and the RRUS551 at the other. Windows should detect your device automatically and present you with a menu of choices.You can select "Open containing folder and view files."
This will open an Explorer type window where you can just select the files you want and copy and paste them to somewhere else on your PC.
It is better to shut down your PC completely before disconnecting the cable.
Else you may corrupt files on your device.
Hope this helps.
Sep 12, 2011 | Panasonic RRUS551 (1024 MB) Handheld...
I have an mp3 recorder from panasonic, rr-us570, I need to download the recording onto my computer so I can email it to a tutor, how do I do that
Under Linux it showed up as a disk with one partition
and a VFAT filesystem, though I had to mount it manually. No problem copying or playing files.
Under XP it didn't appear as a disk. It did come with a CD but I left that at home.
Normally, you just find the device under "my computer", explore the filesystem on it until you get the right one, then drag it into your mail client.
Sep 02, 2009 | Panasonic RR-US360 Digital Voice Recorder
Upload files from Panasonic RR-US395 to Mac OS 10.4
I am assuming you are aware that this software is not available anywhere for the Mac. With that said, I only see two options for you (don't laugh at the obvious one):
1. Upload to a Windows based PC or PDA and transfer to the Mac.
2. Install a virtual environment for the Mac that supports Windows.
Jun 17, 2009 | Panasonic RR-US395 Digital Voice Recorder
Just installed my RR-US360 Voice Studio 2.0 into my new Dell 1525
I have herd that there is a driver option but i have installed all the drivers and granted privleages for them for various device models and they do not correct this - they also state to uninstall and reinstall - after 5 times for each device i realized panasonic support and tech advise generic brush offs!
i have a work around and it is located here:
http://www.fixya.com/support/t1607583-just_installed_rr_us360_voice
its a little involved but it does work! for any account type that isnt 100% locked down - but its a workaround and thats all and a total pain in the **** if you have to support a variety of them packaged in a network environment like i do :-S
I am suggesting that our devices for these types of requirements be investigated and panasonic removed from the environement as a result of their unwillingness to address this matter for the past few generations and models of these devices
Jan 27, 2009 | Panasonic RR-US360 Digital Voice Recorder
Panasonic RR-US360 Handheld Digital Voice Recorder PC Software
Panasonic RR-US360 Driver. No driverguide.com registering, no fees, just download the driver. Took from my original CD. Enjoy.
http://depositfiles.com/files/beb7hvsnj
Tested for viruses, trojans, spyware - CLEAN. Kaspersky clean.
May 19, 2008 | Panasonic RR-US360 Digital Voice Recorder
Dont Have the drivers for my Panasonic RR-US050 digital recorder
Same problem.
I have Voice Editing Ver 2.0, does not work on RR-US050.
Jan 07, 2008 | Panasonic RR-US050 Digital Voice Recorder
Panasonic RR-US455
The Panasonic IC recorders do not work with macs.
There's nothing you can really do about it.
Panasonic said it does not support Mac on it's website.
Dec 27, 2007 | Panasonic RR-US395 Digital Voice Recorder
Panasonic RR-US500
After installing the software update from Panasonic, plug your recorder into the computer. Go into 'Control Panel' and select 'Hardware and Sound'. Then Select 'Device Manager' and select 'Universal Serial Bus controllers'. You should have a device for 'Panasonic IC Recorder', it might be flagged yellow, right click on it and select 'uninstall'. Unplug your recorder from the computer, replug your recorder into the computer, the Device Manager screen will refresh and you should have 'Panasonic IC Recorder' back in the list. Try the Voice software, you should have in the drive list 'IC recorder'. Transfer your files.
It worked for me,
Pierre
Oct 31, 2007 | Panasonic RR-US500
Panasonic RR-US395 Digital Voice Recorder Logo
567 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
