Question about HP OfficeJet 6110 All-In-One InkJet Printer
Hp office jet 6100.
I need to re time my scanner so it knows its home position. The scanner initializes but it keeps trying to drive past its travel limit.
  • 1 more comment
  • mikeej77 Feb 01, 2008
    Thanks for the advise...
    I had the manual on hand already..
    It covers basic features /operation, It does not cover any technician type tweaking or malfunctions.
    The major problem is that it doesn't seem to know where the original place is, over and over and over.
    What did you do to fix the problem????
    Genius:
  • 3,422 Answers
Here is the manual go through it carefully u will find the solution to retime ur scanner.
Click here to download
And im further looking into the sol. to ur problem
Goodluck,
Please Don't forget to rate me as fixya..
Posted on Jan 31, 2008
  • 1 more comment
  • Priya darshan Jan 31, 2008
    You need to have adobe acrobat reader to view the manual in pdf format.
    Click here to download it if u don't have
  • Priya darshan Feb 01, 2008
    Since it is not a small problem I would recommend you to call the HP people they will tell u the solution..
    Or u can even give them a mail explaining ur problem as u did here
    Alright just try this trick if it works hold cancel after turning off the printer and then throughout the whole startup process..
  • 749 Answers
Just switch off the unit and switch back on... It initializes and re-aligns to original place.
fixya!!!
  • 871 Answers
    Genius:
  • 1,067 Answers
Is ther firmware update to it go to www.hp.com suport area download latest drivers ok save to hardrive then remove old ones then install new ones from add remove in control panel ok after new driver hold power in unplug it then plug back in hold that power for 10 sec manaual reset also in the settings
  • 2 more comments
  • nick helpap
    nick helpap Jan 31, 2008
    could have loose ruberband that controls scanner area
  • nick helpap
    meeing it went past the band by acdent on sum heavey scanning cheak dpi settings too 300 max 600 if u have too will it scan the 1st part ok if so use crop program,
  • nick helpap
    u nee dto get it open wer scanner is cheak rubber band status see if local parts shoop has one or off old machine tricky stuff thx nick
  • nick helpap
    Removed all the torx-screws
    - Removed the little glass on the left side
    - Removed the Control Panel Cover (lifted it a little with a screwdriver and released two latches)
    - Removed the Control Panel itself (another two latches&move to the left)
    - The whole top of the 6110 is attached to the bottom with 4 latches. I removed that, turned it around and cleaned the glass.
    - The cables between 6110-bottom and controlpanel/feeding unit are long enough to set those things aside.
Ricoh 2035 cood sc120
If you wish to get some details; check the site linked here. Pull up older posts....
http://electro-medical.blogspot.com/
Apr 17, 2016 | Ricoh Office Equipment & Supplies
Says "scanner initializing". Have to reboot to clear.
scanner is unable to reach home position within allocated time.
you need to remove the glass platten and OIL the rails/drive shaft clearing any dust / rubbish as you go also clean the underside of the glass while its out. If this doesnt clear it then you will need a new scanner driver PCB/scanner motor ( replaced as 1 item)
Jan 10, 2014 | HP LaserJet M3035xs MFP All-In-One Printer
Ricoh Aficio Sc 122
The scanner home position sensor
does not detect the home position
during initialization.
Causes:
Scanner I/O board or SBU defective
• Scanner motor defective
• Harness between scanner I/O board
and scanner motor disconnected
• Scanner HP sensor defective
• Harness between SBU and HP sensor
disconnected
• Scanner wire, timing belt, pulley, or
carriage defective
Aug 14, 2012 | Ricoh Aficio 2232C Color Copier
HP Office Jet 7210 Scanner won't work
Try this simple step,
Disconnect the power cord from back of printer ( while printer is on )
wait for 10 seconds and connect it back
let the printer Initialize and Try to scan.
IF this does not work, you probably just need to uninstall and reinstall the drivers.
Jul 06, 2010 | HP Officejet 7210 All-In-One InkJet...
HP color laser jet 2840. During initial power up/calibration, scanner bulb starts to click (and flash on one end), screen goes blank. Many people report similar problems. Some say it's a problem with the...
If the equipment shows the message "Scanner bulb warming up" and not initializes, look resolve:
Well have to clean the scanner assembly. Contains about 4-5 mirrors. It is very difficult to disassemble, careful to clean.
From here you can get service manual. There are 6 parts. put them all in a folder and a unzipp the first.
http://eserviceinfo.com/downloadsm/34029/HP_2820,2830,2840.html
Oct 09, 2009 | HP Office Equipment & Supplies
Fucntional problem with Savin 4022 sp, SC 120. Did clear mode to get to sp screen but copier still will not turn off..
This is a scanner problem (the part with the lamp) is it crooked as viewed from the orig. glass? No need to reset this code when the movement problem is fixed turning power on and off will reset. -Carl
Jul 15, 2009 | Ricoh Aficio 450 Copier
My Office Jet 7310xi scanner failure
Does it scan from either the doc feeder or from the flatbed itself?
Can you COPY a page?
Are you using the buttons on the printer, or do you work from HP director?
Mar 29, 2009 | HP Officejet 7310 All-In-One Printer
HP office jet 6210 scanner failure error
have you tried to reset the printer?
(Take the power cord off hold # 3and then turn the printer on.)
That is an initial position problem
Parts are no longer available for this model from HP...
Jan 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Initializing self test scanner
http://www.fixyourownprinter.com/forums/inkjet/19182
Nov 19, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
201 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
