Graphics card power
I have just installed a new graphics card, and the requirements say that it needs 350Ws of power, my current PSU only supplies 250Ws will this be an issue? The graphics card is working fine, but I am wondering if it will be hurt by the less power, or if it will end up slowing down the process of the other componets? Please help
  • jflynn Jan 31, 2008
    I have a dell dimension 4550
    And I have bought a new power supply but when I installed it the computer did not turn on and it would not operate.
Just installed the geforce 7300 gt,went to start windows and when desk top comes up the display is scrambled,could it be a PSU problem?
Posted on Jul 18, 2010
  • 43 Answers
I suggest you change your PSU if you want to play hi end games and do more graphic stuff. This PSU will work only if you use your computer for low graphic things like busines software Office and internet, if you use CAD you better change it or it will cost you more money.
It would be more helpful to tell us what computer do you have, and what card did you install.
Posted on Jan 31, 2008
  • Goran Veletic Jan 31, 2008
    :( hmm... unfortunately I suggest to you buying a new rig since dell used "its own" power supply standards, even though they look exactly the same as the standard ATX connector the wires are in different orders. and unfortunately I cannot find the power supply for that model that has more than 300 watts what I think is not enough either to power your PC for gaming.
New PSU doesn't have four point connection
You can still use this power supply but you will need to purchase a 4 to 8 pin connector . you can find them on ebay etc. You can also use two power supplies, one for gfx card one for PC. I use two. To turn on a PSU without it connected to PC ( just to use it as extra power.) You just have to connect the green wire to any black wire with a wire or paper clip. (At your own risk. Set pins first tape off and turn on by plugging into wall) . Good luck.
Nov 29, 2013 | Acer Aspire Computers & Internet
Computer video card swap?
Hello there!
Advantage is fairly possible.But the main thing that blocks people from getting full performance is,the power supply of your pc.
The new graphic card requires a little more of power supply to run better.You might wanna upgrade your PSU.
Cheers,
Aldo.
Feb 05, 2013 | ATI Computers & Internet
What is the best graphics card compatible with aahd3-hb?
Your mainboard has a PCI-Express x16 v1.0 graphics card. You can use any PCIE v1.0 or version 2.0 card. Make sure that the power requirements for the card are met. Check the specs, most will at least tell you a minimum wattage (400W PSU recommended)
Too little power will shorten the life of the card, or kill it instantly.
You can find the information on your current power supply on a sticker on the side of the PSU. Check this out and either
  • stay within the power supply's specs when selecting a new card
  • plan to replace the power supply when you install the video card
Mar 13, 2012 | Computers & Internet
Will a GeForce 210 work in a Gateway GM5072 desktop
Your computer will support this new graphics card.
I would find out what kind of power your PSU can provide as some of the higher end graphics cards require a higher end PSU.
You might be fine, but I'd do some research on power supplies.
Dec 24, 2011 | Gateway Computers & Internet
My motherboard was biostar nf61s.i want a new graphics card.i currently using nvidia 8400 gs it was not good to me.i want to buy a new nvidia 240gt.if it works fine?(and give hard ware installing...
If you need a new card for gaming purpose please go for ati 5770 or nvidia 9800 gt as you will get a better gaming performance from both of these as compared to 240gt.
You may also have to upgrade your power supply unit as higher graphics card require more power.
Feb 25, 2011 | MSI Graphics Card - nVIDIA Geforce 7600GS...
Having trouble upgrading to xfx radeon 5570 graphics card
1) Did you upgrade your power supply? The x300se was a low power graphics card. The new card needs at least a 400W power supply and that is what I find in the specs. However, the exact power needs depend on the rest of the specs for the computer (use a power supply calculator to get an estimate: www.thermaltake.outervision.com/ ). (Optical drive, hard drive, etc)
2) Did you uninstall the driver for the original card before removing it?
3) Check for updated drivers (newer than on the supplied card). Download and install those.
The original card was a low-profile card. Do you have enough space for this card in the box? (Similar question comes in with the power supply - make sure it fits in the case.) Also make sure that you are not getting overheating issues with the new graphics card. There are slot cooler fans and fans that can be mounted above all of the card slots. The best choice for your needs depends on the case and the temperature causing instability.
If you provide more details on where you are having trouble, I'll try to provide more assistance.
(at least this graphics card doesn't require a pci/e power connection to the PSU, as far as I knowm so that is one less thing to go wrong. Note: PSU are often rated by the max peak power that they can supply; it is the mean (average) power supplied to all devices that matters. Otherwise, a gaming session will pull too much power and shut the system down.)
Oct 16, 2010 | HP m7170n PC Desktop
Think new graphics card needs me to by new PSU. Need second opinion and suggestions. Think my current PSU is 375. Since i installed this new graphics card the PC has frozen after 30 mins or so of use. ...
Hello and thank you for using Fixya's services.
Absolutely, you need to upgrade the PSU.I would recommend at least a 450W (this would give lead a variety of different brand named VGA cards, since you did not specify).
No newegg.com here! Try eBay and get a reasonable, almost 75% off purchasing a new one. I would pull the one from the computer and research if that would fit perfectly in the case. Usually, a generic ATX fits most cases but make sure it does. Price on eBay @ or around $12.99.
Please let me know if you have additional questions.
Oct 27, 2009 | Dell XPS 400 PC Desktop
I have just installed an ati radeon x800xt graphics card. system is 3 ghz p4, 400 watt power supply. I have plugged power in but fan is not working
When you are running low wattage power supplies, sometimes you need power from 2 locations within that power supply, Ie make sure you get 2 cables that are seperate from each other but still part of the same psu, which plug into your graphics card. Always work with a static wrist strap, you could of fried your graphics card. I'd say it's probably inserted into your motherboard, you just need power from the psu as well as motherboard to power this card.
Aug 16, 2009 | Computers & Internet
New graphics card
Intel Pentium® III, AMD™ Duron or Athlon™ class processor or higher
128MB system RAM
A 300W system power supply
An AGP 2.0 (or higher) compliant motherboard
50MB of available hard disk space
CD-ROM or DVD-ROM drive
Microsoft® Windows® 98, ME, 2000, XP, or Windows®
VGA or DVI-I compatible monitor
This is what you need for graphic card to work!!!
Its very good card!!!
Jan 22, 2008 | Computers & Internet
Asus Graphics Card
The 2400Pro graphic card uses very light power, so if your powersupply gives a true 250W or more you should be fine. However it also depends on what is your total configuration, as in whats your CPU, how many hard disks, etc as these all consume power.
A good way to check how much your machine actually needs is to use the PSU (Power supply unit) calculator. A good one i came across is http://www.extreme.outervision.com/psucalculatorlite.jsp.
You can find your how to calculate your current PSU wattage from this interesting discussion http://www.tomshardware.com/forum/207120-28-calculating-amps-dual-rails.
Dec 06, 2007 | Computers & Internet
Computers & Internet Logo
201 people viewed this question
David Payne
David Payne
