Erase sandisk How do I erase data on my sandisk? I need a blank one to download updates for my Magellan GPS.
  • jem2layla Jan 31, 2008
    I don't have a MAC. What about my Windows XP. What does MAC have that XP doesn't? This sandisk is for my GPS system. It requires a blank SD.
  • 152 Answers
Try formatting it in MAC.... my friend had the same problem with his sandisk... he was advised to do so and it worked....
Posted on Jan 31, 2008
  • Anand Srinivasan
    Anand Srinivasan Jan 31, 2008
    well i dont know about the differences between these OS... all that i know is that me and my friend had to go to the library just for the sake of formatting the sandisk in the only system in the library with MAC OS...
Hello, I want to download the latest map update for my Magellan Roadmate 3065, but unfortunately it's out of storage. Is there any way i can clear the memory?
Normally, it is done via a computer and loads and unzips it to the computer, then it over-writes the map data already on the device, so it doesn't need additional storage.
Did you load Content Manager and load from there?
http://support.magellangps.com/support/index.php?_m=downloads&_a=viewdownload&downloaditemid=272
RoadMate 3065 - Software Update - Magellan Support - Magellan GPS
support.magellangps.com/support/index.php?_m=downloads&_a...272
Aug 28, 2012 - Description. Magellan® RoadMate® 3065 Software Update - Installation Instructions. To install this software update you will need to install Content Manager. Content Manager is a computer application that syncs with your Magellan GPS navigator to deliver new map updates and product information.
Apr 16, 2018 | Magellan GPS
Cant not get watereays on explorist 500 in canada
You can try to update your GPS firmware.
Before you update your Magellan eXplorist 500 firmware or install a custom basemap, Magellan recommends that you backup all of your GPS data.
Click here to download the firmware update (Version 2.57)
Connect your Magellan GPS unit via the USB drive.
Double-click on the update file to begin the installation process.
Follow the on-screen instructions .
Jun 17, 2011 | Magellan GPS
I wanted to know is there a way that i reprogram
You can go to the manufacture's website if you wish to update this device. You can update maps and software.
For reset you can you hold the bottom right or top left corner and turn on the GPS until you get the message "Do you really want to erase all user data?
Select yes.
Some have a pin sized reset button on the back.
Or you can download the reset utility here:
http://handheld.softpedia.com/get/GPS/GPS-Receiver-Reset-Utility-67753.shtml
Nov 15, 2009 | Magellan Maestro 4040 GPS Receiver
Magellan GPS freeze
if this is the north american Magellan 700, download and install the 3.32 update. follow the link below, choose your model and download update...you must have your unit registered on the magellan site before they will allow you to download anything.
Aug 11, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Hi My Magellan Maestro powers up with the Magellan screen and the bar scrolls but thats all it does? Carl Lucas Aberdeen MD
i just replied to a fellow with the same problem and since your problem is same, ill post what i wrote him/her but try a hard reset 1st..turn the gps on then locate the little pin hole on the side, using a paper clip, push reset....if that fails, try the 2.18 update if you havent already.
updates for any magellan can be found HERE
but read below first before getting the update
i cant stress enough that patients is a must here. this update is huge 1.75GB
follow the instructions below whether you have updated your gps already or not!
There are few ways to solve this problem. i assume you installed the 2.18 update for the 3100 and assuming you tried the reset already, try and run the update again and follow the directions to the letter..make sure the battery is fully charged (i also keep mine plugged in if the update doesnt say not to) and do not try and run the update across a network. this update is huge 1.75GB and can take an hour or so depending on the computer..do not interrupt the update process. if you do not have the 2.18 update read me file, i can try and post it here, but its in PDF and dont think i can post that
if all else fails, magellan will fix or replace for free any of there gps that were rendered inoperable due to one of there updates.
either solution will work but magellans going to tell you to run the update again anyway before sending it back.
i gave you the 2 easyest ways to fix it,but
there are other ways to get it running again, but if your not comfortable copying and moving files...youll make it even worst then it is.
hope this helps.
bill
Comments: Jul 19, 2009 - here are a few key points, but read the full update guide before trying the update again.
hope this helps
NOTE: This update is COMPATIBLE ONLY with Windows® XP.
Before Beginning:
Check to make sure you have everything required for updating your unit:
• Magellan Maestro 3100 GPS
• PC running Windows XP
• A Blank SD memory card (16 MB to 2GB)
• USB cable
• Paper clip or similar object (for resetting your unit)
EACH OF THE FOLLOWING POINTS IS CRITICAL TO THE UPDATE PROCESS
1) The battery of your Maestro 3100 must be fully charged before beginning the update.
NOTE: It takes between 3 and 4 hours to fully charge the battery with your vehicle power adapter. Check System Settings to ensure the battery is fully charged.
2) Your Address Book will be erased during the process. Please back up your data to an SD memory card.
a. Insert a blank SD memory card
b. Select User Options
c. Select Backup and Restore
d. Select Yes to confirm
3) Do not connect your Maestro 3100 to your PC until instructed to do so by the Update Wizard.
4) Close all other applications while performing the update.
5) Disconnect all Pocket PC devices from the USB ports on your PC.
6) Insert a blank SD card (16 MB to 2GB) into your Maestro 3100.
7) Perform a hard reset on your Maestro 3100 by pressing a paper clip or similar object into the hole marked reset.
Update Process:
1) Launch the Magellan_Maestro_3100_2_18.exe file.
2) Select Next on the Welcome screen.
3) Turn on your Magellan Maestro and connect the USB cable.
Aug 03, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 frozen on blue screen tried power on and off and reset button still frozen black bar at bottom of scren stays on blue screen
hope this helps.
bill
hope this helps
Before Beginning:
• USB cable
Update Process:
Jul 14, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Operating system for Magellan Mastro 3225 GPS has been lost
Create an account on their website and download the firmware update. It is free and I have done it.
May 16, 2009 | Magellan Maestro 3225 Car GPS Receiver
Map update error problem with Magellan 4250
I had the same problem until I plugged the usb cable into the back port of my computer. Then it worked. Something about using a higher speed usb port.
Oct 23, 2008 | Magellan Maestro 4040 GPS Receiver
Re: Magellan Maestro GPS 4250 original data erased....
download the new firmware again and run the setup
Aug 20, 2008 | GPS
Computers & Internet Logo
222 people viewed this question
Alun Cox
David Payne
David Payne
