Question about Refrigerators
G.E. Fridge Have a G.E. fridge that runs continious............It will cycle off for 5 min in a.m.and then in afternoon cycle again. I've cleaned all the dust bunnies out of coils. And had a repairman out and he said all looks good. His advice was to monitor the elec bill. ( fine for him as he doesn't pay it ). What do ya think????
  • cbntx Jan 31, 2008
    Thanks for the response....I'm not sure if this fridge is 134.....
    I believe it's about 8to 10 years old...cbntx
    President:
  • 1,314 Answers
Modern day fridges with 134a tend to run more than older units but use very little electricity if the freezer and fridge temps are fine and the doors are sealed i wouldn't be too concerned running times vary with things like temp settings how many time the doors are open etc but when running they use about as much power as a 100 watt light bulb
Posted on Jan 31, 2008
  • robert samples Jan 31, 2008
    itl be 134a r12 was banned a while back
The compressor in the fridge energises for a constant 30 mins in every 90 mins. Is this normal?
depending on door seals and the number of times the door is opened and the temp setting on the thermostat and the positioning of the fridge it could be considered normal
see if you can get an idea of the cycle times at night when the fridge is not being opened and the room is cooler if the temp setting is close to 32 or zero celsius then the fridge works hard to maintain that low setting but if the setting is higher say 5 degrees celsius it runs a lot easier
the problem with fridges is that every time the door is opened , all the cold air falls on the floor and the motor has to run to fill the fridge with cold air again
fridges that are full of food maintain their cold better than empty fridges
May 04, 2016 | Refrigerators
Reset the ice maker back to making ice again
Turn the water supply off to the fridge, make sure the bailer wire (ice level bar) is in the down position. let the Ice maker run thru its cycle. When the cycle is complete the fingers that push out the cubes should all be down. Unplug the fridge for about 5 min. During this time turn the water supply back on. Plug the fridge back in and let it run thru a few cycles. This should reset the icemaker cycle. As a note: you should be able to hear the water turn on with a solid thump as the valve opens to fill the cube trays inside the icemaker.
Sep 18, 2014 | Samsung Refrigerators
Hi, I have a Bosch intelligent frost free 44 which I bought second hand a few days ago. Manufacture date appears to be 2006 and was told it works fine but I am not sure. When I first turn fridge on the...
I think it's the freezer fan that stopped working,open the freezer and see if it goes you should hear it running and even see.This fan allows the cold air into the fridge compartment,without it it takes ages for the fridge to get cold.I've got the same problem if you find the motor online let me know on alvalen31@hotmail.com
Nov 03, 2010 | Bosch Refrigerators
Tempreture on fridge too high ice build up in fridge mahes noise like a tractor
Your automatic defrost cycle may not be working. Feel the walls inside and if they are hard solid you have ice build up and the fan is hitting the walls or ice making the noise. Unplug your fridge for 2 days and let the ice in the walls melt. Put towels on floor to catch water. Plug it back in and it should run fine for a couple of weeks until the ice builds up again. You have a bad timer and it isn't letting the defrost cycle come on. Defrost cycle are heating elements that melt the ice build up and runs about 10 mins once a day or so. This will give you time to check if an afforable repair can be done or a replacement fridge.
Jul 11, 2010 | Samsung Refrigerators
What is the purpose of two temperature control nobs when there is a single compressor in my samsung 280 lts fridge
1.If this is only a fridge the one knob will be for the min and the other for the max.
max. : As soon as you switch the fridge on it will cool down the fridge to max cool down temp. example -2deg.
min. : As soon as the fridge reaches the max cool down temp and it had switch the compressor off, the fridge will start to warm up slowly, by the time it reaches the min allowed warming up temp, it will switch the compressor back on and do the cycle all over again.
2. If it is a fridge/freezer setup, the one knob will be for the fidge and the other for the freezer. If the temp in the freezer is fine a fan is activated and blows all the cool air to the fridge and controls the temp. by activating the fan.
Sep 06, 2009 | Refrigerators
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
What is normal running on/off time?
Fridge is perfectly OK. The on-off cycle depends on the physical load i.e. how much the fridge is stocked up with. A little heavy load would explain the cycle of on-off. Its normal and no need to do anything other than what u generally do, as mentioned, so carry on ......sodeep
Jun 17, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Fridge is cold but always runs.
CHECK THE DOOR GASKETS ON THE FREEZER AND FRIG.,IT SOUNDS LIKE THERE IS A AIR LEAK SOMEWHERE,LET ME KNOW-MIKE
Nov 01, 2008 | Refrigerators
Smell
Try lemon and baking soda scrub
Aug 25, 2008 | Refrigerators
Smell
Our refrigerator had a strong smell and it was freon leaking into the frig.
Jan 27, 2008 | Amana SXD524VW Side by Side Refrigerator
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
