Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
The top rack is not getting clean.
The bottom rack seems to be cleaned ok, but the top rack is not getting cleaned at all.
  • Bec3 Feb 11, 2008
    My appliance repairman says the motor on my 3&1/2 yr old dishwasher is broken and I can either spend $400 to repair it or buy a new dishwasher! He says that this is becoming a common problem in the newer dishwashers.
  • 3 Answers
This is one common possibility
It may be the food chopper assembly. Mine broke last year from a toothpick,
the food doesn't get chopped because the blades are broken, then the filter clogs and water wont spray high enough.
Heres a test--turn on the dishwasher and wait until you can hear water running then open the door really fast and look at how high the water is spraying--there should be alot of water all over the top rack running down
Posted on Jan 31, 2008
Kenmore ultra wash diswasher top rack not cleaning
see please the next video for your fix it: God bless you
Jul 21, 2012 | Kenmore 24" Built-In Dishwasher with Ultra...
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes in the top rack not getting clean. Bottom rack is fine.
Your filter/chopper is clogged. You have to clean it out and that will restore water pressure to the top rack.
  1. Remove the bottom rack.
  2. Remove the top rack
  3. Remove bottom Spray arm (turn top nut clock wise)
  4. Take off the delivery tube by turning it clock wise over the heating element ( undo the two clips one at the back and one on top)
  5. Take out the screw for the top screen and remove top
  6. Take one screw out for chopper housing and remove
  7. Remove chopper and clean or replace chopper if broken
Reinstall all parts and test.
That should help please rate your experience. Thanks
Dec 11, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
Whirlpool DU1055XTSS Quiet Partner 1 is not cleaning top rack
the sprayer is clogged with ****. I had the exact same problem. my mother-in-law gave me of some 80 year old man that has fixed appliances all his life. Ten minuets after he got to the house it was fixed. cost $70.00. He just took a couple things apart dumped out the **** inside the parts and put it back together. Hope this helps.
Jun 02, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
Only bottom rack cleans. Re-plumb or replace?
Do you have a garbage disposal? If I run mine while the dishwasher is running, dishes do NOT get clean!
Jan 09, 2010 | GE 24 in. Profile PDW7800 Built-in...
Dishes on top rack do not come out clean. Bottom rack O.K.
Have you tried cleaning the filter? We had a similar problem. The repair man came and removed all the spinners and the other stuff at the bottom above the motor to get to the filter. It was blocked with all kinds of old food bits and pieces, the odd bit of plastic film etc. He cleaned it, replaced it and we havn't had a problem since but he said it needs to be done about every two years. It can be done by someone who has reasonable DYI skills.
Jan 04, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
Upper rack is not cleaning. Greasy dishes on top seem that dishes are not being washed. Seems the upper water turning dispenser is not working, Bottom rack seems ok. I guess I only have half a dish washer...
Check the upper arm for free spinning, then remove the arm and check that the seam between the upper and lower halves has not split somewhere. Also check all the small holes for debris plugging. Run the machine in wash cycle for a little while with the upper arm off--that should flush out anything blocking the pipe up to the arm. If still nothing from the upper arm, tear down the lower arm assembly down to the deck while noting position of all parts removed. Clean the big screen at the bottom in white vinegar and hot water. Inspect the holes in the bottom for anything blocking them.
Aug 15, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
Not enough pressure to top rack
PULL WASH ARM OFF OF THE TOP RACK AND SLAP AGAINST YOUR HAND AND SEE IF FOREIGN MATTER IS LODGED IN ANY OF THE SPRAY JETS. CLEAN AND REATTACH
Jul 22, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Top dishes not getting clean
OPEN THE DISH WASHER AND PULL OUT THE TOP RACK AND SPAY IT OUT WITH AN OUT SIDE WATER HOSE BECASE IT GET CLOG SOME TIME
May 05, 2008 | Kelvinator MDB121RF Dishwasher
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
294 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
