Question about Zenith B27A11Z 27" TV
Broken cable connector
Can and if so how do I replace my broken cable connector on my 1999 Zenith A24A23W 27" TV? I really can't afford a tv repair man but I have a friend that solders and welds. Can he do it for me???
  • 2,130 Answers
Yes, its not that difficult. You may even find that you can salvage the one that you have. You'll have to unplug the TV and remove the rear cover. The connector may be located in the rear cover or a plate that sticks through the rear cover.
The connector may be attached to the TV's motherboard or a sub-board. It may even be just a bulkhead connector with a cable that is bolted to a plate.
Let me know what kind of "F" connector it is and I'll help you locate a replacement. Maybe you'll be lucky and just have to resolder the old one.
- Jim
Posted on Jan 31, 2008
The cable connector has been broken off from the outside, is there any way of fixing this without replacing the entire board
Yes...if you can remove the board from the TV safely. You will have to unsolder the tuner. Then remove the sides of the tuner to inspect the damage. You will need to replace the RF connector with an RCA part #215543. On another note, find an old TV repair shop and see if they can salvage a tuner from an identical TV. This is actually faster and easier to repair. Note this, just replace the tuner, not the main board. The salvaged unit may not be serviceable. Thanks for asking and show all hands of support!
May 16, 2011 | Zenith B32A24Z 32" TV
The cable connector has been broken off. is there any way of fixing this without replacing the entire board
With most tv's I've serviced, the cable connector is connected directly to the tuner module. The tuner module may be damaged beyond repair, depending upon how much physical force was applied to the cable connector. I would take it to a reputable repair shop and let them provide you a honest estimate of repair. They may be able to resolder the cable connector to the tuner module.
Coax receptor broken! Want to replace part.
if you truly need to replace the part then go out to a tv/mechanism store and buy the 12 in receptor to replace.
Mar 12, 2009 | Zenith A19A11D 19" TV
Magenta TV color goes magenta
CALL HIM BACK . sometimes when we troubleshoot a problem another one pops up ,when troubleshooting we move boards and unplug connectors . there can be dirty connections that pop up when where done and even a broken solder joint as well . he should fix it for free . i know we do and it does happen to us once in a while . good luck
Mar 09, 2009 | Zenith B27A11Z 27" TV
Need a code for my tv zenith
Zenith Product Codes
TV Mode Zenith Code 101 - VCR Mode Zenith Code 201 - Cable
Mode Zenith Code 353 - AUX Mode Zenith Code 401.
Programming Codes---
TV - 101 149 175
Apr 27, 2008 | Zenith B27A11Z 27" TV
Broken RF Connector
you would have to get a new part for it. try looking online and out in your model number and put in rf connector needs replacing
Mar 10, 2008 | Apex Digital AT2002S 20" TV
Sanyo tv coaxi wire broke
Let me guess you have broken off your I.F connector ,this is what you connect your cable to on the back of your set,if this is what you are talking about ,you will need to try and repair IF connector or replace your turner.sometimes when this piece is broken off turner is also damaged,there for you have to replace turner.
Dec 09, 2007 | Sanyo DS27910 27" TV
Sony KV32s45 sudden failure
I really have to say there is no miracle cure for TV's I have 20years of experience in fixing TV's I don't suggest for you to try to fix this as TV's run on high voltage and you could kill yourself.
If you really cannot find a tech to check it for you the only thing you can try is to check for a broken fuse.
You Must Take Great Caution.
If you are a person that like to take things apart you may try to take the back off .
Start by disconnect the power cable and follow the main power cable inside , normally it goes where the main switch is located and there you should find a Time Fuse normally the value is around 2.5 amps T for time it should say on circuit board & on fuse.Check for a faulty fuse.If faulty replace with the same type fuse and before you plug it in put back all covers than you may try to put on TV.
If fuse is good than fit back cover and take to a professional.
Nov 29, 2007 | Sony KV-27V55 27" TV
Zenith C27V22 27" TV loud humming noise
There is a coil in the set with a magnet glued to it, called the horizontal linearity coil. Sometimes the coil "sings", making a squeeling sound. I have seen this many times, and there really isnt anything actually electrically wrong with the set. To stop the squeeling the coil should be replaced.
Jun 19, 2007 | Zenith C27V22 27" TV
Broken RF Connector
Its fixable. the question is how much of the inside broke with it. cost for repair on that usually averages 45 to 65 dollars... unless tuner is damaged in most cases not. if not hooked to tuner then maybe a new isolation block..simple job Good luck
Mar 09, 2006 | Zenith C27A24T 27" TV
Zenith B27A11Z 27" TV Logo
78 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
