Question about HP Photosmart C4180 All-In-One InkJet Printer
C4189 all in one
C4180 all in one printer.When I boot the computer & the printer’s on, we can’t get a monitor screen. It’s black & unresponsive. I turn off the printer the computer boots up with a screen, then we can turn on the printer & all is well. Is there someone else who has had this problem & is there a setting or fix that I can download. Thanks
  • jette11 Feb 23, 2009
    I have the sam problem and have tried the different usb ports as well as purchasing a new cord. Has anyone come up with any reasons this may be happening? As the previous person stated, if the printer is on, my system will not start up (has a blank screen). If it is off, I can boot up and after system is up turn on printer and all works fine.
  • 749 Answers
That's weird, but try moving the usb cable of the printer to another usb port... If not replace the cable with a new one, might be faulty.
Posted on Jan 31, 2008
6ya staff
SOURCE:
I have a black screen on my computer it boots up good and works fine with a monitor but the screen on the computer remains black all the time
Not sure but try looking in settings that ask you which screen to view, you can have screen on laptop, laptop and monitor or monitor only.
Nov 21, 2013 | HP g4-1107nr 14in Laptop 1.6G4GB 500GB...
Black screen just after boot window from USB
Sounds like either the monitor or video card inside the computer is bad. Try connecting another monitor to the computer. Borrow a monitor from a friend, neighbor, relative or co-worker and plug it into the computer. If the borrowed monitor displays ok, then your original monitor is bad. If the borrowed monitor does the same thing and not show a display then your video card inside the computer is bad.
May 09, 2012 | Computers & Internet
Acer aspire 5100-3583 boots, screen is on, but
https://www.bleepingcomputer.com/download/windows-repair-all-in-one/
Dec 07, 2017 | Acer Aspire 5100-5033 Notebook
Blue tint...then unresponsive...only 5 months old
You're probably lucky that this happened now. You're most likely still covered under warranty. Contact Acer support and arrange a swap. If your pc works okay with another monitor there's no point in troubleshooting further. Get that monitor switched before the warranty runs out.
Apr 27, 2009 | Computers & Internet
COMPAQ PRESARIO DESKTOP PC SR1215IL. When switched on, cpu boots normal but no display on monitor. instead a sharp and bright blue vertical line appears for few seconds on the middle of screen. led of the...
tricky!! oh hi im Dyanne.. a totally unresponsive black screen can be th result of failure of th LCD or LCD inverter.( a specialized piece of electronics that energize th screen) to rule out th failure of th video display adapter or circuitry, try plugging in an external monitor..a standard pc monitor.. attached direct to th lappy. if it works, (as i susopect) th motherboard and video display are both working ok and its th LCD which is at fault. this can sometimes be repaired by a competent specialist. good luck xx
Dec 25, 2008 | Compaq Evo D300 PC Desktop
Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Feb 24, 2008 | Gateway FPD2275W LCD Monitor
Monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Nov 26, 2007 | Acer AL1711 17" Flat Panel LCD Monitor
Screen turns black
problem with the inverter chek it
Mar 18, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
HP Photosmart C4180 All-In-One InkJet Printer Logo
111 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
