Question about GE Bluetooth In-ear Headset Wireless Headset
My Motorola bluetooth won't stay connected
Hello. My Motorola H350 bluetooth will not stay connected. It pairs up, I get a connection and a second later it reads not connected. What can I do??
  • Anonymous Jun 16, 2008
    My Motorola bluetooth won't stay connected problem
  • Anonymous Nov 15, 2008
    I've got the exact same problem but so far can't find any fix for it.
6ya staff
SOURCE:
sandrew
andrew pester
  • 2961 Answers
SOURCE: Motorola H350 - Incoming calls
there is nothing you can do about the delay as it's the time it takes for the bluetooth to send the signal to your earpiece to tell it the call is answered, the only way to stop any delay is to set your phone to auto answer in the bluetooth headphone settings or in the call settings.
Posted on Aug 07, 2007
Anonymous
SOURCE: Pairing H350 with Rzr V3
you hold the button with the boom closed and as soon as the light stops blinking you realease the button and open the boom, the light should remain on and steady. promt your cell phone to find it and the code is 0000
Posted on Nov 28, 2007
Anonymous
SOURCE: pairing my bluetooth to my phone
The Passkey for any bluetooth is 0000 so if you put that in it should work.
Posted on Jan 03, 2008
map9966
Mike Peluso
  • 2351 Answers
SOURCE: maual for Motorola H350 bluetooth headset
This may help. Click the link:
http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/AU-EN/H350_User_Manual_19oct2007.pdf
Ignore the chinese as you go. Its like mixed together but you'll find what you need. Good day!
Please vote.......
Posted on Jan 17, 2008
Anonymous
SOURCE: Motorola Bluetooth HS850 Pairing Mode
There actually is a trick to the HS850 - flip the boom closed, then hold down the button just until the light holds solid - IMMEDIATELY after it does flip the boom open and this should keep the light solid. Then on your cell/device search for bluetooth devices - you should be able to find it now. Passkey for most devices is 0000.
Posted on Mar 09, 2008
Trying to set up my motorola h350 bluetooth to my samsung s30 phone.
Turn your H350 on by pressing and holding the black "Talk" button on the side of your headset. Hold it until the blue status starts to flash. To turn the H350 off, simply hold the talk button until the headset turns off.
Pair your headset with your cell phone by entering into your cell phone's bluetooth menu--Menu > Settings > Connection > Bluetooth Link > Setup (see Resources below).
Put your Motorola H350 into pairing mode by holding the "Talk" with the device turned off. Hold the button until the status light on the side of your headset begins to flash, and turns back into a solid blue.
Back in your phone's bluetooth menu, choose the option to "Search/Discover" bluetooth devices. And when your phone recognizes your H350, select the headset and enter "0000" as the passcode.
Thank You
Sep 05, 2010 | Motorola Mobility H350 Wireless Headset
I cannot connect my h350 headset to my phone how doi I do this
on your phone open your bluthooth section and(1) turn on bluetooth. then in the bluetooth options, (2)have your phone ready to search / find devices. (3)on the h350 press and hold the power button for about 5 seconds until the blue light comes on and stays on. it is now in paring mode. (4)tell ur phone to search for devices. your phone should find it. (5)then select the h350 on your phones found devices list. they will now pair. its possible a password will be requested, i believe the factory default password for the h350 is 1234. your phone password may be the same as your phone unlock code or your voicemail code.
time is limited you may have to do this a couple of times before they actually pair together.
Feb 19, 2010 | Motorola Mobility H350 Wireless Headset
Bluetooth connection
first switch on ur mobiles bluetooth........... then switch on ur moto: H350...... then automatically ask to pair with the headset.......... accept it.............. then enter passcode 0000........... then it wil got paired........then answer yes to the next question ......... got it!!!!!!!!!!!!
Oct 28, 2008 | Motorola Mobility H350 Wireless Headset
Motorola H350 bluetooth headset problems...
you have to hold the button down until the light stays on then pair it with your phone... If that doesn't work try turning your phone off then back on and try it again.. Took me 20 minutes to get mine to work the first time
Feb 25, 2008 | Motorola Mobility H350 Wireless Headset
Motorola H350 User Manual
On your bluetooth headset, hold down the power button until the light stays on steady. (it will blink when you initially power it on, but continue to hold for another few seconds for the steady light!) Your headset is now in pairing mode.
On your RAZR, press Menu > Settings and Tools > Connections > Bluetooth > Handsfree > Look for devices. Your phone will then scan for any bluetooth devices that are in pairing mode. When your headset pops up on the list, highlight it and press ok to connect.
If the device asks permission to bond with the phone, select yes. It will then prompt you for a pin code. The pin will be 0000 .
Jan 08, 2008 | Motorola Mobility Bluetooth Hands Free...
Lost pairing?
First when ya call connects, hit the Menu key (three lines inthe center) choose USE HANDSET.
Second Make sure the Bluetooth is fully charged, andit seems to lose charge fast.
Dec 15, 2007 | Motorola Mobility H300 Wireless Headset
Motorola H350 doesn't connect...
The issue is with the PS3s compatibility with the H350. Sony should be fixing some of the issues with an update, but from what i've checked online, the H350 is a problematic headset. i just got one as well, and have connection issues with it online.
Nov 24, 2007 | Sony Playstation 3 (PS3) Console
How do i connect my bletooth h350 to my phone
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
Jul 16, 2007 | Motorola Mobility H350 Wireless Headset
GE Bluetooth In-ear Headset Wireless Headset Logo
785 people viewed this question
Top GE Radio Communications Experts
Anthony Ward
Anthony Ward
ray gallant
ray gallant
Van Allen II
Van Allen II
Are you a GE Radio Communication Expert? Answer questions, earn points and help others
