Question about Kenmore 22422 Top Load Washer
Kenmore Model 20722990 broken coupler
Can you give me information on how to get the back off this washing machine, and how to correctly get to the coupler. I have the machine laid down on it's front side and can tell the coupler is broken.
  • 1 more comment
  • freebubba Jan 31, 2008
    This information was very helpful, and very accurate. I just need to get the part and "whalla" it will be done. A Big Texas thanks for your assistance.
  • Anonymous Mar 21, 2014
    install new coupler
  • Anonymous Mar 30, 2014
    diagram needed
  • 125 Answers
Stand it back up. Remove the end caps on the front of the control panel, (there is a screw under it). take out the 2 screws. The control panel will come forward then flip up. Next use a screwdriver to pop out the spring clamps that hold the cabinet onto the frame. They are about 3/4 of an inch wide and about 3 inches from each side. Disconnect the lid switch. Now you can tilt the cabinet away from the back of the machine, while tilting the bottom front of the cabinet will slide out and the cabinet can be set aside. now you will have access to the motor etc. Release the clamps holding the pump onto the motor. Now you should see two screws that hold the motor clamps, one above and one below the motor shaft, remove those. Use a flat blade screwdriver to pop off the clamps holding the motor. pull motor out to expose coupling. Make sure to use part # 285753A. repair sould take 10 minutes.
Posted on Jan 31, 2008
Kenmore 70 series model 20722990 tub 110 water
The drain sump is clogged with dirt and needs to be removed and cleaned thoroughly.
Some tips from this video: drain cleaning
Nov 20, 2013 | Kenmore 20722
My Kenmore 70 series washer sounds like it has something stuck in it and makes a grinding and buzzing noise the agitator will barely move but the washer will drain but not spin
That could be the motor coupler. It could also be the transmission. It is pretty easy to fix. I recently worked on my brother's washer:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 04, 2012 | Kenmore 20722
I have a Kenmore top loading large capacity washer model 1028882791. It began washing as usual then began to making a loud humming sound. The agitation stopped. It only makes a loud humming sound. I...
The humming sound is coming from the drive motor running but unable to drive the agitator nor the basket to spin. The drive motor is definitely running as the drain function works because of the fact that drain pump is directly coupled with the rear spline of the motor. The drain pump works in either direction as long as the motor runs. The problem is obviously a broken motor coupler which transfers the mechanical energy of the motor to the transmission. The solution then is to replace the broken coupler. Click on the link below for the detailed step-by-step procedure in replacing the motor coupler.
Replacing Motor Coupler on Kenmore and Whirlpool Top-Load Washing Machines
Jan 13, 2011 | Kenmore Washing Machines
Belt is loose or needs replaced. on a 70 series kenmore washer machine
Can you provide the exact Make, Model and Kenmore model number? ..........
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.........
The model number on top load washers is usually found by lifting the lid and looking above the tub.
The Fixya numbers are Stock Numbers.
Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem.
Slipping on direct drive washers is usually caused by a damaged / broken Motor Coupler or clutch.
If yours is a direct drive machine, see the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135&osCsid=5666a1d539401da8aec3c1514f2bc0f9
Jul 09, 2010 | Kenmore 24032\24036 Top Load Washer
Model 110 20722990 ser. ck 3590340 tp 111 wont agitate spin can hear metallic clicking noise
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20722990
and you'll see a list of major sub-components with diagrams and parts.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
Since it will neither agitate nor spin, but you can hear a clicking noise, the Lid Switch is probably all right but the Motor Coupler is likely bad.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
If the rubber piece is destroyed, you would hear the clicking of the plastic prongs.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Feb 01, 2010 | Kenmore Washing Machines
Repair ??
need to know what colo and size.
Oct 21, 2008 | Kenmore 22422 Top Load Washer
Broken Washing Machine
frontload or top load frontload,,remove debris from inside pump,, top load , coupler problebly broken,
Oct 11, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Washing Machine 70 series
When this machine is not spinning, the water should still be able to drain, as the motor drives the pump on the same shaft as the coupler for the tranny. Set to the spin setting and depress the lid switch, if the water still does not drain, you may have something stuck in your pump, which would also lock the motor shaft and not allow it to spin or agitate. If the water does drain, check the motor coupler, which is located between the motor and transmission, if broken, the motor will run but there is no drive to the transmission. Hope this helps...
Sep 14, 2008 | Kenmore 20722
Kenmore model # 20722990
It sounds more like the timer motor is stopping. There mght be something binding or a dead spot on the motor.The next time it does that, advance the timer slightly a few times and see if it then advances on it's own Check all the wires, too. Take the timer assembly out and flush it several times with alcohol or plastic safe electronics cleaner while operating the timer (engaged) several times.
Mar 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
315 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
