Question about RIM BlackBerry Pearl 8100
Pearl (trackball) doesn't scroll up / how to clean?
Need instructions on how to take out and clean the trackball (as we had to before optical mice came out... Any idea? Warranty is expired so can't exchange the handset.
  • 4 more comments
  • Volk Feb 01, 2008
    Great - thanks a lot!
    Since posting the thread I found a couple of video clips on YouTube as well
    Cheers
    V
  • prnclk1 Feb 13, 2008
    track ball wont track left!!!
  • Anonymous Apr 21, 2008
    same here. won't scroll up
  • Anonymous Jul 30, 2008
    trackball wouldnt scroll up
  • Anonymous Nov 08, 2008
    the trackball does not go up at all and is extremely frustrating what do i clean it with?
  • dennys098 Dec 24, 2008
    same wont scroll up
Ya mess around cleaning the track ball when you can buy new one for £4.99 with free postage
Posted on Jun 09, 2010
  • 113 Answers
You can order a replacement trackball at www.blackberry8100parts.com for $9 its easy to install
Posted on Jun 18, 2008
  • 846 Answers
The only way to get it up and running again is physically remove and clean or replace the part. If you want somebody else to doit for you go to Blackberry Repair. If you want to do it yourself, here is a Blackberry pearl Repair Guide that shows how, the part is available on Ebay.
Posted on Jul 12, 2010
Spray electronic cleaning spray on to the track ball and allow to dry.
This will clean and free the track ball.
Posted on Apr 22, 2008
Scroll is hesitating.. Will work for moment then button keeps scrolling but screen does not scroll with movement of button... Can this be fixed or do I have to replace? LynnsizzleV@aol.com
Lynne:
You can try a few things... Take a clean rag or cloth and moisten it with rubbing alcohol and gently scrub across the scroll wheel to remove dirt and skin oils from the scroll wheel and trackball. Don't let alcohol drip into the trackball body. If that doesn't work, and you are somewhat mechanically inclined, you can turn the trackball over and remove the screws that hold the housing together (some may be under the rubber pads on the bottom of the trackball) open the housing and clean the parts that contact the trackball and scroll wheel with a clean rag or cloth. Blow out any dust or dirt in the housing, Dry the parts you cleaned with alcohol and reassemble the trackball. Use rubber cement on the rubber pads, not model cement or super glue, in case you need to disassemble the trackball again at a later time.
Aug 16, 2013 | Kensington TurboBall (64227) Trackball
Need to fix blackberry trackball
When this has happened to me I've used one of those wet wipes or a Q-tip soaked with rubbing alcohol to clean it off. It usually takes a few wipes. Sometimes I've taken it apart and cleaned the trackball with the q-tip when it's gotten really bad.
Here's a link to show you how it's done:
http://www.blackberryforums.com/general-8100-series-discussion-pearl/113889-how-clean-trackball-your-pearl-8100-a.html
Oct 27, 2009 | RIM BlackBerry Pearl 8100
My trackball won't scroll up
Trackball needs to be kept clean at all times . you can clean them with a damp cloth ( make sure water does not drip ) .
also the trackball can be replaced for a very low cost if you dare to replace it yourself .
you can buy the trackball through ebay from $1.99 .
one last option is to get a small air compressor and blow air around the trackball without forcing too much pressure .
try all this and see how you go .
Sep 25, 2009 | RIM BlackBerry Pearl 8100
Tracking ball is limited in movement. I can scroll across, but not down.
Cause:
The sensitivity of the trackball/trackwheel might be less
Faulty Hardware
Resolution:
Increase the sensitivity by following procedure
Option -> Screen and Keyboard -> Horizontal Sensitivity and Vertical Sensitivity to 100
Aug 10, 2009 | RIM BlackBerry Pearl 8100
Can't scroll down with track ball. Pl. suggest
Clean your trackball regularly by slightly dipping a cotton swab into rubbing alcohol and using that to clean your trackball.
Unfortunately, dirt and oils on your fingers wear out the trackball over time, causing it to behave in unpredictable ways.
Jun 26, 2009 | RIM BlackBerry Pearl 8100
My blackberry scroll key not working
I just fixed mine trackball which can only move in the vertical direction. By removing the silver cover (there are three small clips that hold it in place), the trackball and its enclosure will fall out. Carefully remove the white plastic cover (there are 2 clips that hold them in place) on the other side of the enclosure. Take out all 4 cylinders (4 magnet at the end) with tweezer and clean thoroughly. The 4 cylinders got clog with lint and dirt which prevent the ball in contact with the cylinder. This will solve your problem.
Dec 14, 2008 | RIM BlackBerry Pearl 8100
Logitech Cordless TrackMan Optical Trackball connection
you are probably better off buying a new one
unless you are lucky enough to find a used one
Dec 09, 2008 | Logitech Cordless TrackMan Optical...
Bb8800 the pearl/cursor does not scroll up
This is usally caused by the trackball getting dirty.
Use a q-tip dipped in IPA and clean it. Roll the trackball around and swab the q-tip around to clean.
If cleaning fails then you will need to replace the Blackberry trackball.
Check the following link on instructions on how to do that.
Blackberry 8800 Trackball Replacement Guide
Oct 12, 2008 | RIM BlackBerry 8800
Doesn´t work with pro/engineer (panning an zomming)
 love this trackball mouse, yet they are very sensitive to wear and trash that causes them to fail. Wal-Mart sells great ones like the Logitech LX3 optical mouse that are not as sensitive and have more features
Oct 01, 2007 | Logitech Marble Mouse Trackball
RIM BlackBerry  Pearl  8100 Logo
6,142 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
