Question about Refrigerators
GE side by side refrigerator is rumbling
My 3 year old GE side by side refrigerator (GSS23SGSB) suddenly has a rough, rumbling noise coming from the freezer compartment. It's like the motor is running roughly. That's Problem A.
Problem B is that our condo developer wedged the fridge in so tightly that I'm worried I might not be able to pull it out in case maintenance has to be done at the rear. Is there a trick to using the rollers -- i.e, to make sure they're not locked or immobilized or something?
Thanks in advance for any assistance!
    Problem Solver:
  • 8 Answers
Unit may be off level do to being wedged in so tight. No trick to rollers just carefully pull out unit.
Posted on Jan 31, 2008
Model #rb215lash
I know nothing about your model, but in my experience with refrigerators over the last 40 years, they can make a whole range of different noises at different times. There's even a note in the manual of my GE side by side something to the effect that strange noises are to be expected. I'm amazed at the range of different sounds that comes from our 10 year old GE. It's hard to say ignore noises because I never ignore a new noise from my car, but unless the same noise repeats under similar conditions, I'd not rush into trying to 'fix; it.
Apr 14, 2014 | Samsung Refrigerators
Our GE GSS25WSTSS is 5 years old. For the past 3 years it has been making a fairly loud pulsating deep whirring noise whenever the fridge motor is on. Applying pressure to the right side door gets rid of...
This might more simple than it seems, or maybe not. Try pulling both handles downward to lock them in. The handles are removedjust as easy by pulling them up. My first guess is either it never was fully seated or second the handle has slop between the locking area "manufacture defect". Let me know please.
Apr 21, 2011 | GE GSS25WSTSS 25.4 Cu. Ft. Side-by-Side...
I have a GE Profile side by side counter depth unit about 8 years old and the fan on the refrigerator side up top suddenly became noisy.Does this need to be fixed right away? Will it affect the cooling?
Greetings,
yes, sometimes these motors will make noise for years and other times, they go out pretty quick...so, to answer your question...it would be prudent to have it repaired.....Bruce Denton
Dec 14, 2010 | GE Profile PSI23NCR Side by Side...
Whirlpool model ED5FHAXSLOO refrig 3 years old very noisy
If it is cooing fine, then the noise is probably your evaporator fan (the one inside your freezer). This can be cause by one of several things. The motor on this fan may be going bad, or, more likely, you may have a build up of ice around the blades that are touching the fan. This may be caused by a defrost circuit that has gone bad, or, the freezer may have been open alot lately and there is an excess of frost that hasn't melted away yet. If you can, manually defrost the freezer and see if it goes away. If it doesn't, it's probably the fan motor. If it does, and then comes back, it's probably the defrost circuit. Hope this helps!
Dec 06, 2009 | Whirlpool ED5FHEXMQ Side by Side...
My water dispenser suddenly has stopped working.
Yes, it could be the water filter. Also check to make sure the water is turned on and that any lines to the refrigerator aren't kinked or crushed somewhere. It's also possible that you will not be making any ice as well if your appliance has an ice maker
Apr 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Side by Side Refrigerator dispenses ice but no water
if the light is not coming on i would say that board needs replaced and it just pops right out
Mar 16, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Groaning noise on GE side by side refrigerator
Usually the groaning noise is from a locked up icemaker. Remove the icemaker and defrost it with hot water. Check to make sure the unit is in good shape and not chipping. Let it dry out and then reinstall.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/robert_e97a69269ae71345
Jan 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Sep 12, 2008 | GE GSS25JEM Side by Side Refrigerator
Refrigerators Logo
303 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
