Question about NEC (MTLAMP820/1020) Projector Lamp for MT820, 102
2000 F-150 NO HEAT
BLOWER MOTOR RUNS HAS NO HEAT AT ALL ANTI-FREEZE GOOD
  • 3 Answers
Heater core clogged try blowing out with air compressor
i had on my blazer had same trouble should have 2 hoses going to unit 1 in 1out blow air both ways something may blow out of it ,
mine had slimy junk came out then work good after that
Posted on Dec 16, 2008
Change thermostat about 8 bucks at autozone worked for mine your old one is probably stuck open
Posted on Mar 06, 2008
How can I get my deforoster and heater to work
There are several possible causes. Check that you aren't low on anti freeze. If you added anti freeze recently, you want to add 50/50. Not 100% anti freeze. If that isn't it, it could be a bad thermostat. Several other things, but we will start there.
Jan 04, 2015 | Cars & Trucks
Blower stopped working
there is a blower motor located on the passenger side in the fire wall. to get to it unbolt washer fluid/anti-freeze holding tank then cruise control module and air box. next step is simple unplug the connector on the blower motor go buy a new motor ($50 at autozone) un-screw the bolts holding it in should be three the just reverse what you did to take it out 15 mins tops
Nov 05, 2013 | 1998 Ford Explorer
Heat doesnt work
check your fluids radiator should be full and resavor should be at full level if you dont have enough anti freeze it wont push fluid into your heater core also pay attention to your tempature gage if the temp is low you wont get good heat your thermostat could be stuck wide open I would try adding anti-freeze first though that usually fixes it make sure its 50/50 if you just add water sooner or later that water will evaporate
Dec 08, 2012 | 2005 Pontiac G6
My is heat is not work?My car is blowing cold air instead of hot air, I have a brand new heater core,the thermostat is not sticking,I got anti-freeze in it,It's getting cold in I need heat.Please help me
first feel the heater core hoses see if both are hot if so then your problem is in the blend air door must be stuck on cold. is your blower motor blowing cold air if not your blower motor might be the problem. the blend air door is down by the blower motor.
Nov 17, 2010 | 1995 Oldsmobile Cutlass Supreme
Car over heats for a few minutes until the fan kicks in what could be wrong. I have been adding anti freeze to it
U have low anti freeze wich is causing the engine temp to run higher than normal and the fans blowing help bring it back down u can take wash off the motor let it run for a while when the anti freeze is full and watch to see if u can see green fluid coming out fix the leak if there is no leak found u need thermostat
Mar 14, 2010 | 1994 Ford Taurus
02 ford tauras heater won't heat. Hoses too and from heater core are ''piping hot''. Radiator was recentlly replaced, and is full of 50/50 anti freeze. Also heater motor works on Highest setting only....
The temp door actuator motor is not working on the blower box,the dash will have to be pulled out toward the seats to access the actuator motor.
Jan 09, 2010 | 2002 Ford Taurus
Bad odor (Wire sheathing?) from vents when fan is on. We definitely have an intermittant (3 or 4 times in past year) driver side actuator problem. Cannot tell if odor is coming from all vents or not....
the heater core is bad it could be leaking and thats what the smell is coming from. you only smell it when the heat is on is because air flows throught the heater core to warm it by the hot anti freeze that flows through the heater core see if you anti freeze resivoir is low.
Dec 28, 2009 | 2004 GMC Sierra 1500 Crew Cab
2000 Chevy Venture not blowing any heat but engine is overheating. Could it be my water pump?
I would highly suspect the thermostat, cost is about $12 for the part and some anti freeze. Good luck
Nov 20, 2009 | 2000 Chevrolet Venture
NEC (MTLAMP820/1020) Projector Lamp for MT820, 102 Logo
122 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
