Question about Brother IntelliFax-2820 Laser Fax
Brother Intellifax 2820 printing problems
We have 2 of these and both of them continually have problems with printing thick black lines on paper. We have: replaced cartridge, cleaned drum, moved that little blue thing back and forth like the manual says, etc. It is getting very annoying and happens over and over again. Is this a problem with this machine? Is it a toner issue? Do we just need to buy new machines?
  • allan399 Apr 22, 2009
    i bought new drum, but the problem is still there
    Scholar:
  • 78 Answers
If it is on copying it can be a build up of ink on the scanner glass. Open the cover in which the the original is scanned. There will be glass strip that can be cleaned also check the white plate that sits above the scan glass.
If it is recieved faxes and prints as well the problem is going to be the drum has worn out. You have two machines, try interchanging the drums to see if the lines that are present on one machine travels to the next. That way you can see if it is definately the drum. If so change the drums on the machines and they should be fixed.
Posted on Jan 31, 2008
2 Suggested Answers
FixinFax
  • 3085 Answers
SOURCE: Our Brother Intellifax 2820 is saying change drum soon
The toner and drum are separate units. Buy one here.
http://www.discounttoneronline.com/mm5/merchant.mvc?Screen=PROD&Store_Code=dto&Product_Code=IJN_BRO-DR350&Attributes=Yes&Quantity=1
Posted on Nov 26, 2009
IntelliFax-2820 Plain Paper Laser Fax: We have a Brother intellifax 2820 and it's aking t...
You need to take out the cartridge and slide the tab on the top right from right to left about 20 times
May 16, 2010 | Brother IntelliFax-2820 Laser Fax
REPEATED REAR PAPER JAMS-BROTHER INTELLIFAX 2820
Try making prints or copies with the rear door open. If it does not jam your fixing unit (hot area) is functioning properly. With the rear door closed try again making copies or prints. If it jams it's most likely the exit rollers acting up.
1. I've seen the exit sensor break on these units and sometimes the drive gears wear and do not feed properly.
2. If using after market toner or refills this may also coat the exit roller with a film which prevents the exit rollers from feeding parper out by reducing the friction of theses rollers. Clean with fantastic untill cloth does not turn black.
Sep 01, 2009 | Brother IntelliFax-2820 Laser Fax
Jam paper inside
believe it or not, a bad/faulty drum unit can cause this. or possibly the feed rollers just needing cleaned. it really helps on jam problems when you can print just 1 page and let us know exactly where that paper stops at.
good luck,
razors
Jan 28, 2009 | Brother IntelliFax-2820 Laser Fax
INTELLIFAX 2820--PAPER/SCANNER JAM
go to brother & download driver for printer. good luck !
Jul 13, 2008 | Brother IntelliFax-2820 Laser Fax
Prints with a white line vertically down the page. How can I fix this?
Apr 25, 2008 | Brother IntelliFax-2820 Laser Fax
Brother fax 2820
Out of the lower paper tray when you go to print? Try this, remove the cassette tray and use a water dampened cloth and clean the gray paper pickup roller off. A lot of times this has paper fiber build up that causes the paper not to feed. The printer has a certain timing pattern for when paper should reach a certain sensor, and if it doesn't, then a jam error will occur.
Jul 18, 2007 | Brother IntelliFax-2820 Laser Fax
Auto feeds crooked
Are we talking about a paper feed problem from the paper cassette tray or the Auto Document feeder on the top. Either way, check the the paper width guides, or if it is the paper cassette tray, remove it and check the paper pick up roller locking clips.
Jun 08, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
417 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
