Question about Galaxy Radios DX 77HML Base CB Radio
Fm mode inoperational
Orange wire is clipped whre does it connect?
  • davidg8913 Feb 01, 2008
    the clipped wire is soldered to a small pc board mounted near the channel selector switch . where the other end connects is unknown to me. please help thanks.
  • 152 Answers
Can you please tell where is the other end of the wire is connected to... coz i believe that you are mistaken the wire that these FM use as antenna.....
Posted on Jan 31, 2008
My stereo keeps defaulting back to demo mode
You most likely have the 12 volt permanent connected to the switched supply lead you need to identify which wire requires the permanent and the wire that requires 12 volt switched this will only appear when you turn your car key to acc position , it's normally a yellow or orange wire your looking for but check your models schematic.
May 13, 2014 | JVC In-Dash AM/FM/CD Receiver with USB...
What kind of wires
Single Stranded wire ( AWG # 22 ) can be used as an antenna
• For FM reception : any length from 1m to 5 m will work.
provided that there are FM stations near your area.
• VHF TV antenna can be used for a clearer reception with
RG 59 cable
• For AM band reception, it would be longer than 5m
Jul 26, 2012 | Televison & Video
I recently bought a 1993 Chevrolet K1500. It had the factory radio in dash, but the cassette player and under dash amplifier were gone. I bought both of these from salvage. In doing so, I noticed a...
Hello! The ALDL or On Board Diagnostic I (OBDI) connector is located under the dash on a 1993...And is different then the 94 you looked at...See diagram below...Is there a wire on "A" and "B"? "A" is a White/Black wire that changes to Black/White at the ALDL connector on pin "A"...and should read to ground..."B" is data and is Orange...These are the two wires that are shorted with a paper clip to get the trouble light to "blink" out a trouble code...I DO NOT see a connection between the fault that you have and the ALDL connector, Although the connector may be missing a wire (easily checked)...LETS SOLVE!!!
The problem appears to be be a lack of a connection to the Yellow ignition wire which could appear White...It's the ACC ignition power to the radio...Just because the lights are on doesn't mean the radio itself has power from the ignition...Also The Orange ignition wire (hot at all times) maintains memory to the radio...The White? wire out out the back of the radio appears to be the ignition wire...If there is already a Yellow wire connected to the radio plug that has 12 volts on it when the key is turned to ACC let me know...
Bottom line...Are there wires in both slots of the under dash ALDL connector??? And is there a splice into the Yellow ignition wire...SEND A COMMENT .saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Nov 29, 2011 | 1993 Chevrolet K1500
New blower motor and new resistor. Blower motor still not working. What do I check next?
switch. Use a 12 volt test light at the resistor connector. Take connector off resistor, check the brown/orange stripe wire for 12 volts--is it hot? if yes, connect your test light clip to that terminal and probe the other terminals. Orange/black wire terminal should light up with setting on high. Black wire terminal should light on any setting, etc.
If brown wire with orange stripe is not hot, check fuse 9.
If fuse 9 is OK, problem may be in the mode selector switch.
See diagram and let me know if you have any questions.
Dec 23, 2010 | 1989 Mercury Topaz
The PC will no longer recognize it. I've tried downloading the driver from the sansa website and manually attempting to fix it will no vail
Support for the Sansa Clip support information is on next site:
http://kb.sandisk.com/app/answers/detail/a_id/4303/kw/clip/r_id/101834
Correct link for updating the Clip's firmware:
http://kb.sandisk.com/app/answers/detail/a_id/300/related/1
When MANUALLY installing firmware:
Check the version of your player to have the matching firmware download for the player, as described in the updating firmware link.
Going to the Sandisk forum site for the Clip firmware download:
http://forums.sandisk.com/sansa/board/message?board.id=clip&thread.id=15109
Note: read the instructions how to perform the firmware update.
1. Choose the correct version for the player.
2. Connection mode in Windows should be automatic, when not recognized in Windows or with MAC and Linux use MSC mode ***** .
3. Extract the zip file on the computer first.
4. Next put the unzipped file on the player in the root directory.
5. Disconnect the player.
6. Restart the player: the firmware update should restart now.
*****Note:
Switching to MSC mode for Sansa Clip:
Method 1: through the menu
1. From the Main Menu, select Settings > USB Mode.
2. Select Auto Detect, MTP or MSC.
Method 2: forcing, using the buttons / switches
1. Turn device OFF.
2. Slide the Hold switch down to Lock (orange color showing).
3. Press and hold the center button while connecting the device to the PC.
Need more help ? Just post a comment.
Dec 14, 2009 | SanDisk Sansa Clip MP3 Player
Sansa Clip Stuck in FM mode - Won't go into music menu
Press the little button that looks like a house to go back to main menu
Aug 13, 2008 | SanDisk Sansa Clip MP3 Player
Getting Out Of F.M. Mode
use the button that looks like a house on the front of the player
Aug 03, 2008 | SanDisk Sansa Clip MP3 Player
Wiring diagram for car radio
WHERE DO I CONNECT THE PINK WIRE IN THE JENSEN VM9311TS AM/FM/DVD/MP3 RECEIVER
Dec 05, 2007 | Car Audio & Video
Galaxy Radios DX 77HML Base CB Radio Logo
63 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Marvin
Marvin
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
