Question about LG VX9800 Cellular Phone
Car kit setting removal
My LG VX9800 cell phone displays "car kit" across the screen and when it says that i cant hear any sounds and no one can hear me. How do I remove the phone from this setting?
  • 3 more comments
  • cocodevou Feb 12, 2008
    same damn problem--say's "car kit' on it and cannot dial out or dial in...
  • weakland Apr 16, 2008
    my LG VX9800 cell phone displays "car kit" across the screen and when it says that i cant hear any sounds and no one can hear me. How do I remove the phone from this setting?
  • landyannie Sep 24, 2008
    So i've had the same problem. And i've researched the hell out of it.  Still no luck for me. But this is the things I've come across thus far:
    -Put a piece of foil (or something metal) to create an electrical current to "shock" your phone out of it.
    -Plug into a car charger.
    -Wiggle your own charger around (this one scares me, you could end up bending and breaking the charger)
    -Put your phone in a bag of rice to soak up any moisture
    *you may not know your phone got wet (especially if your kid is playing with it. Kids drool, that's probably what it is). But to check this take your battery out and see if there's a little pink dot at the bottom of it.  That's a sign there is water damage.
  • gbeining Feb 15, 2009
    My son had the same problem with his EnV phone. One morning for no apparent reason a "Car kit" display showed up and he could not talk or hear anyone during phone calls. We looked on the internet for other people who had the same problem and sure enough this seemed to be a fairly common problem. We examined the prongs like other people had suggested and sure enough the last prong on the right was bent over top of the one beside it. We took out the battery and used a pointy pair of tweezers to carefully pull the bent prong back over. We put the battery back in and turned it on and thankfully the message disappeared and the phone was back to normal. THANK YOU SO MUCH TO ALL THE PEOPLE WHO POSTED THIS SUGGESTION!!!!!
  • Anonymous Mar 13, 2009
    My phone is doing the same, how do i fix this?
Hello everybody. This morning I woke up and my phone said car kit on it. As the other people have said above, I tried to starighten out my prongs as best as possible. Then, I plugged my charger into the phone, while on, and I made sure that it was securely plugged in. Once it was securely plugged into the phone, I wiggled it back and forth and voila, it worked all of a sudden. As I was wiggling it, the car kit message was coming on and off. Once I noticed that the message was off, I took the phone out of the phone charger and everything was good to go.
This is a very strange problem, but luckly it is fixable.
Posted on Nov 19, 2008
Yea I dont have the prongs either they are all attached onto a chipboard that keeps them together, however I still stuck a pin inside the charger port, turned the phone back on and it turned off the car kit message. Thanks Much~!~
Posted on Oct 15, 2008
How do you bend the prongs? Mine are all on like a plastic board that dosen't allow them to move seperatley. I am so confused. Someone please give me more detailed instructions on how to fix this stupid carkit. Thank you.
Posted on Sep 27, 2008
Thanks for the help. i had a prong bent too! thanks everyone works great now.
Posted on Jun 24, 2008
I had this problem when I left my phone outside. It didn't rain, but it was 90 degrees and 80% humidity! I took out the battery and there was no moisture, so I scraped some with a knife into the charger port. Nothing. I kept trying, turning on and off and scraping and poking. I also plugged it into the charger and did a lot of wiggling. Something finally worked. No more "car kit". Thank God. My point? Don't give up, keep messing with the port and you may have luck. Better than buying a new phone, or even having to sign a new contract if you are eligible for a new phone
Posted on Jun 07, 2008
Theyr'e Right!!! I have an LG phone and I had the same problem for like 2 months. I read the solutions and I looked where my charger plugged in and sure enough there was a bar bent. I took a nail and pushed it back up and Presto!!!! Car KIT_no MORE. I made a *611 test call and it went through.
Posted on Jun 06, 2008
I just had the same problem out of nowhere this morning. After reading the advice above, I noticed one of the pins on my charger area was out of place, actually bending over another pin or two. I moved the pins back its normal location with a little wiggling, and voila, no car kit error. I guess when certain pins touch each other, it f's up the phone. Just be careful not to bend the pins too much or you may break them.
Posted on May 07, 2008
I had the same :"car kit" message, and Verizon had no clue. I noticed that a couple of the pins in the charger port had been bent, and were touching each other. I carefull straightened the pins so that they were each the same distance apart from each other, then turned the phone on. Phone fixed.
Posted on Apr 10, 2008
    Novelist:
  • 94 Answers
I had the same problem after my 8 month old drooled all over (and into) my wife's vx9800. I read a fix on another phone's solution and decided to modify it and gave it a try:
1) Turn off the phone and take off the battery.
2) Dry out any readily visible moisture and allow the phone to dry for a couple of hours.
3) Take a pointed object (I used a pin) and gently scrape around the inside of where the charger plugs into the phone. Clear out any dirt and/or corrosion that has accumulated in that area.
3) Put the battery back on and turn the phone back on.
PRESTO!!! The "Car Kit" message is gone, and my wife is able to make and receive calls again.
Posted on Apr 06, 2008
  • Larry Warner
    Larry Warner Apr 09, 2008
    Not unfixable, just needs to be dried out, and any corrosion or gunk cleaned out as described above. I'm sure there's a point of no return as far as water damage goes, but like I said, the steps above worked for me. "Car kit" message is gone and phone works just like it did before.
"car kit" usually means the phone got wet...
unfortunately there is no way to fix it...
Posted on Feb 15, 2008
6ya staff
SOURCE:
LGVX9800 Dials out but caller cannot hear me
did you try going into the settings and tools menu and changing the earpiece volume under option #3) sounds
Oct 25, 2008 | LG VX9800 Cellular Phone
Vx9800
I bought an LG vx9800 from a friend that is now over seas in Sri Lanka. I was waiting to be able to transfer it to my account and somehow the screen lock was activated and I don't have the 4 digit code. How do I fix this?
May 23, 2008 | LG VX9800 Cellular Phone
Car kit mode
it could be a liquid damage if not u need to refurbish the phone by downloading the operating system
Feb 29, 2008 | LG VX8300 Cellular Phone
Cant format SIM card
Using the miniSD Card
The V can access the following file types stored on the
removable miniSD card:
My PIX: gif, png, jpg, bmp
My Sounds: qcp, mid
My FLIX: 3gp, 3g2
My Music: wma
You do not need to format the card, just put it in the slot. The phone will do the rest.
You can chek the card by going to settings and tools---scroll down to memory--ok--go to card memory--ok---and it will show you the information about the card.
http://www.cellphones.ca/upload/manuals/lg-vx9800-manual.pdf
The link above is the manual for your phone.
If you are trying to copy pics and musics to your SD card or phone and cannot, let me know and I will tell you the easiest way to.
Feb 14, 2008 | LG VX9800 Cellular Phone
Unlocking a LG vx9800
if its locked it shoud be the last four digits of your cell number
Jan 20, 2008 | LG VX9800 Cellular Phone
Dropped it into sink
was there water in the sink at the time?
if so check the connections on the base if there is green corrosion on it the the damage is done you will have to find someone who will repair water damaged phones.
If no water and just the drop that caused the prob then try removing the battery while the phone is still turned on this may shock it back
Nov 17, 2007 | LG VX9800 Cellular Phone
Lg vx9800
menu-
Settigns and Tools-
System- (security code is ussually last 4 digits of phone #)
security-
Type in code-
reset default
this should fix the problem and keep your contacts aswell.
Oct 30, 2007 | LG VX9800 Cellular Phone
"Car Kit"
this model do that when it get wet if that the case there is nothing to do but chage the board, go to the celu store they have jonk to fix these for about $25.00 more or less..good luck
Aug 06, 2006 | LG VX6000
LG VX9800 Cellular Phone Logo
484 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
Sheldon Dedek
sheva420
sheva420
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
