Question about RCA RT2600 System
No sound coming from speakers
I turn it on it and it all looks good, then I go to play a CD which is RCA too. Ive checked all the connections, I go to play it and nothing i mean nothin and I really dont wanna take off the top to look at it, I know a little about repairs but obviously not this one could you please get back to me. Thanxs Rod
  • spikejones Apr 20, 2008
    I am getting no sound from the speakers. I can hear them "humming" so i know they are connected. the front 2 speaker's icon is blinking on the reciever's display. what is wrong here?
  • 38 Answers
A 50/60 Hz hum in speakers indicates a bad stage somewhere in the amp, probably DSP or input selector. Don't switch this unit on until you've had it fixed, the hum could waste your speakers as well.
Posted on May 21, 2008
Check the speaker connections for any short circuit and also for polarity.
check if mute is highlighted on the screen
check if the audio output of the player is properly connected (optical / coax or RCA
this should solve your problem
If not tell me your connection configuration with regard to input output.
Regards David
Posted on Feb 01, 2008
I have a pyle pre amplifer home receiver model pt270aiu and need help hooking up my wired subwoofer and receiver has rca plugs ive tried connecting by wiring to plugs but hardly ant sound
I had a brief look at the spec and it says the speaker outputs are banana sockets/plugs.
Once the four speakers are connected, or two with the fader control adjusted, it should produce good sound and if it does the next stage will be to connect the subwoofer with RCA plugs into the dedicated outputs.
I suggest you reread the manual.
Apr 28, 2018 | RCA Audio Players & Recorders
Play Ipod thru JVC CD car stereo using RCA cable?
JVC KD-S731R does not have the option of connecting an ipod. The RCA ports on the rear of the unit are a Line-Out. These RCA's only OUTPUT sound. Not an INPUT RCA that you require. The only other method of using an ipod with this stereo is to purchase an FM-Modulator to connect the ipod. Once purchased, you must connect the antenna wire coming from the vehicle to the module, then you must connect the antenna wire coming from the module to the stereo. The other wire will be connected to either a jack or a ipod specific plug depending on the type of modulator used.
Dec 08, 2009 | JVC Car Audio & Video
Audio won't play on DVD - but it will play for CDs
Hello, you can verify that your receiver is working or not. When you are playing a dvd unplug the audio RCA plugs (red and white) from the back of the Sony dvd player. Touch the tips of each of the RCA plugs with your fingertip. You will hear a buzz sound coming from the speaker associated with the plug if the receiver is working\ i.e. touch the red RCA plug tip and the right speaker will hum...touch the white tip and the left speaker will hum or buzz. This will not hurt your system or speaker. If you do not hear the hum turn the volume to 3 or so and wet your fingertip and tap the tip of the RCA connectors. You will hear "pops" coming from the respected channel. I believe your cd\dvd is at fault. Good Luck!
barneyluc
Oct 02, 2008 | Yamaha HTR-5440 Receiver
Music won't play through speakers
Please provide more detail of your system's setup and connections. Thanks!
Mar 05, 2008 | Alpine CDA-9855 CD Player
Audio problems
Did you connect both left and right RCA cable to aux1 forTV?Are you playing CD through your dvd player?
Also,double check your connection from your speakers to subwoofer.
Feb 27, 2008 | Teac PLD-2200 System
Sound only coming from one side
you should have 3 leads going into you multi changer, two rca's and one bus lead. power up the unit and remove the first rca cable if the music goes off unplug the second rca and plug the first rca where the second was plugged in, if the music comes back on then the multiloader is working fine and you need to check the radio controller and its connections
Nov 06, 2007 | Sony CDX-646 10-Disc CD Changer
Sound Won't play
We had the same problem with our last rca stereo. I don't remember what model it was. My husband took it apart and found that there was and area on the circuit board that was fried. I don't know of any other solution then the one we chose. Trash it. I'm not expert but I would imagine that you could by a new stereo for the price of replacing that circuit board. Just don't buy an rca. They are junk. Our new rca just quit playing cds.
Nov 05, 2007 | RCA RS2625 CD Shelf System
No sound when playing cd
What's cooking!? I too occasionally experience a similar problem with the RCA RS2042. When switching to the CD source, I receive sound from one speaker, while the other is faint. I have found that if you open the back and fotz around with the speaker connections (the system, not the speakers themselves), it will correct the problem. Have patience! Take care. -D
Oct 10, 2007 | Audio Players & Recorders
Sound and speakers
Check the speakers connections. The speaker cables may be shorted. Turn the unit off, check and correct the connections and turn the unit on. good luck :-)
Jan 11, 2006 | Panasonic SC-AK66 CD Shelf System
RCA RT2600 System Logo
83 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
