CAPTIONING A DVD VOB FILE
I want to insert a caption or running line ads while a dvd vob file is running. How do i do that, and how do i run it to make a continues loop and stand alone dvd with lines ADS.
Is there any software that i can use to work with vob or mpeg files.
  • Romiebrite Feb 01, 2008
    Thanks for the help. I was able to do it.
    Romy
    Genius:
  • 1,067 Answers
Use nero 7 or 8 in it use nerio vison drag drop video in edit it add cool eccts spining around name in it whatever u wanna type
Posted on Jan 31, 2008
6ya staff
SOURCE:
Have movies on my harddrive but whn I try to burn them they wont play in the DVD player
- It might be that your DVD does not have a compatible video codec
- you actually invest on video codec which converts any video file to .VOB
- There is a software that converts any video file format (example *.avi, *.mp4, *.mpg ) to .VOB
- This should be taken as personal use because we do have laws againts anti piracy (sorry, just a friendly advice)
May 16, 2011 | Office Equipment & Supplies
Tip
VOB movies for Acer Iconia Tab A500-Stream DVD VOB to H.264 MP4 to Acer Iconia...
Transfer/Play DVD VOB files to H.264 MP4 for Acer A500 <br />Join multiple DVD vob files into one for Playback on Acer Iconia Tab A500 <br /><br /><b>A VOB file (Video Object)</b> is a container format in DVD-Video media. VOB can contain video, audio, subtitle and menu contents multiplexed together into a stream form. VOB file can contain H.262/MPEG-2 Part 2 or MPEG-1 Part 2 video, MPEG-1 Audio Layer II or MPEG-2 Audio Layer II audio, but usage of these compression formats in a VOB file has some restrictions in comparison to the MPEG program stream. <br /><br />How to convert and play DVD VOB files on Acer Iconia Tab A500? For Acer Iconia Tab A500 can not accept this format. <br />Acer Iconia Tab A500 is also a great media player which supports a lot of media formats including files with XviD, MP4, H.264, H.263 as video format and MP3, WAV, WMA, eAAC+ as audio format. So you need to convert the files before transferring and playing them on Acer Iconia Tab A500. <br /><br />Aunsoft Video Converter is the best <b><a href="http://www.aunsoft.com/video-converter/">VOB to Acer A500 Tab converter</a></b> for you to transfer files to tablet. It makes it easy to transfer VRO files to Android tablet by converting DVD VOB to MP4 for Acer Iconia Tab A500. You may also deinterlace VOB to progressive mode for perfect playback on Acer Iconia Tab A500. <br /><br />Below is the quick step-by-step guide for you to <b><a href="http://canon-videoconverter.com/2011/06/join-multiple-dvd-vob-files-into-one-for-playback-on-acer-iconia-tab-a500/">transfer and play VOB to Acer Iconia Tab A500</a></b> via Windows XP, Windows Vista, Windows 7. <br /><br />Step 1. Load VOB to Aunsoft Video Converter. <br />Run Aunsoft Video Converter as the best VOB to Acer Iconia Tab A500 converter, and click the "Add" button to import the .vob videos. <br /><img src="a500-vob-converter.jpg" /> <br /><br />Step 2: Choose the suitable Acer Iconia Tab A500 format. <br />As we know, Acer Iconia Tab A500 supported video like XviD, MP4, H.264, H.263 format like MP4. Here just take H.264 HD Video (*mp4) for example. Choose Common Video &gt; H.264 Video (*.mp4) as output format. <br /><br />Tips: Click "Settings" to set the Video/Audio Parameters like Size (resolution), bitrate, frame rate, etc to be more suitable for Acer Iconia Tab A500. For example: Set Size/Resolution to 1280*800 pixels. <br /><img src="set-a500-profile.jpg" /> <br /><br />Step 3: <b><a href="http://www.aunsoft.com/video-converter/">Convert/Rip DVD VOB to MP4 for A500</a></b>. <br />After all the above settings, you can click "Convert" to start <b>conversion VOB to MP4 for Acer A500</b>. Only a few munutes later, you can get the generated files by clicking "Open" icon. <br /><br />When the conversion is done, just connect Acer Iconia Tab A500 to Widnows PC via USB cable, and mount the converted videos to Acer Iconia Tab A500. <br /><br /><b>Tips:</b> If you want to <b>join multiple DVD vob files into a large files for smoothy playback on Acer Iconia Tab A500</b>, just check "Merge into one file" to make it.
on Jun 06, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
How to rip a DVD easily
DVDs contain folders and files which are specially developed for DVD players and not for computers.<br /> If you explore the DVD on your computer, you see on most DVDs the folders Video_TS and Audio_TS. The folder Audio_TS is on video DVDs empty. This folders is normally used for audio DVDs.<br /> If you open the folder Video_TS you see that the extensions of the files in it are .vob, .ifo and .bup. The .vob files are actually the .mpeg or video files and only these files contain video. The .ifo files contain information like scenes and time. The .bup files are backup files of the .ifo files. These files aren't relevant for computers.<br /> If you double click a .vob file and you do not have any DVD player installed on your computer, the computer says that it can not open the file. But there is a trick to do let your computer play this file.<br /> The trick to play this file is to copy the .vob files to a folder on your hard drive. The next thing you need to do is to change the file extension into .mpg.<br /> Do not change the name of the file but be sure you change the extension of it!<br /> If you copy the .vob file and you change the extension in .mpg, there is no guarantee that it works. This depends on the codecs you have installed on your computer. But often this trick will work.<br /> So what is the solution if the above doesn't work? The following I will show you <a href="http://www.freedvdripper.org/dvdvideoguide/how-to-rip-a-dvd.html">how to rip a dvd</a>.<br /> Step 1: Download <a href="http://www.freedvdripper.org/">best free dvd ripper</a> and running it. click "Add". It supplies four ways to load files:<br /> Step 2: Select output Profile<br /> You can select one output format you want to rip a DVD as below.<br /> Step 3: Edit the Video<br /> If you want to customize the video, Wondersahre DVD Ripper offers a powerful video editing function, including cropping video, setting the video effects, trimming movie, even customizing personal watermark.<br /> Step 4: Start to rip a DVD<br /> After you select the output format and edit the video(option), all you need to do is clicking the "Start" button. Then you can get a cup of coffee and come back later to check if the conversion is finished. Furthermore, this DVD Ripper even offers the option to automaticlly shut down the computer when the conversion completed.<br /> Now, you must get the idear how to rip a dvd. Enjoy it!<br /> Related topic: <a href="http://www.freedvdripper.org/dvdvideoguide/how-to-rip-copyrighted-dvd.html">How to rip DVD on Mac</a>.<br />
on Mar 02, 2011 | Computers & Internet
Can not play vod file on computer oops , I meant VOB files on my DVD movie, no movie name stated, to make it harder.
I assume you mean VOB. I have not heard of a VOD file...
If you have gotten your hands on a VOB file somehow, chances are they have been copied/extracted from a DVD. VOB stands for DVD Video Object and is the core file of a DVD containing the actual movie data, an MPEG movie stream and the supported audio.
To play the VOB files, you need to have a DVD player that supports VOB format. However, if you have the Windows Media Player (version 12 or higher) or VLC Media Player, it is good enough to play the file. Note that you will see a prompt telling you that it is an unsupported format, don't worry about it and just play it anyways. It will play just fine.
If you want to obtain the VOB file from a DVD for some reason, just open the DVD in Windows Explorer instead of playing it through a media player. The VOB file would most likely be under the VIDEO_TS folder. Some other files that you will also see in the folder are IFO and BUP. The IFO files are the information files containing meta data about the DVD and instructions for the DVD player on how to handle the disc. The BUP file is simply a backup copy of IFO files.
If you want to convert VOB file to AVI or a similar format, aviNET is a great tool to do that
Dec 01, 2010 | HP Computers & Internet
I just burn a writeable cd from my desktop pc using windowa movie maker. I can play it back on my pc no problem but when I insert it into my dvd player it reads no supported files found.windows used high...
Computers use video files such as AVI, WMV, MPG etc.
DVD players use VOB video files, and will not recognise the computer video files.
Unfortunately, Windows Moive Maker cannot create VOB files - you will need another piece of software to convert the WMV file Windows Movie Maker creates to a VOB.
A lot of disc burning programs (e.g. Nero) include video converters. See if you've already got one on you computer.
If not, try Googling 'WMV to VOB'. There's quite a few free ones out there.
Hope this helps,
Matt
May 01, 2010 | Computers & Internet
I have a samsung flash camcorder (smx-c10lp/xeu) and have been struggling to put any recording onto a dvd. Can you suggest a program please? I have tried nero but it doesnt recognise the file types. I am...
it depends on what exactly want to do with the files...if you just want to store them and use them into computer for future watching and managing ...Nero can do that ..but you have to choose to make Data dvd ...it will not be playable in classic dvd players...but it will play in most computers..with the right codecs on ...
also ..if the files came out in Vob format ...(I assumed that cause you said nero do not sow the files..) there are VOB to..avi converters on the net ...downloads for free..
but ..from what I understood ...tis camera is capable to export Mpeg 4 file format ...this is readable in most dvx players...and all computers with a player and a dvx codec....and also can be converted in dvd clasic format even with nero...if you choose to make dvd ...ad mpeg 4 files ...and have patience ..cause it is taking time ...
anyway ...if you want to make a classic dvd format ..playable in all dvd ...(video -ts files...) you need this kinda program
http://www.soft29.com/how-to/convert-vob-to-dvd.htm
use it to make (convert the files in dvd format ..than use nero to burn dvd...
Jan 10, 2010 | Video Cameras
Dvd copy
Yaa ;
In your DVD you shoud have some Filse like:
VST_01_01.VOB
VST_01_02.VOB
OR with any file name having VOB extention. Actually thats the file where your DVD videos are stord.
try to copy these files to your computer in any new folder.
then use the NERO to burn these files to your DVD.
Thanks
[email protected]
Mar 08, 2008 | Televison & Video
Lacie Silverscreen USB2.0 500Gb
If you can use software to encapsulate the VOB file(s) in an ISO, it will play them in order.
Feb 07, 2008 | LaCie Silverscreen 80GB USB 2.0 - Portable...
DVD CONVERTER
no clue, thats not my area. Sorry
Feb 01, 2008 | Computers & Internet
Hi try download.com free to try software.
Thanks J
Open Questions:
Computers & Internet Logo
59 people viewed this question
Ekse
Marvin
Marvin
