Question about Symbol LS2208 Handheld
How can I restore factry default?
How to reset LS 2208 RS232 scaner to default setting?
  • 106 Answers
Open your programming manual,or setup manual and read the codes return to factory
Posted on Feb 05, 2008
What an idiot. "open your programming manual, or setup manual and read the codes"
Why do people even bother to post such ****? Either give a straight answer or *******...geez
Posted on Nov 25, 2008
  • benchap Apr 02, 2011
    saleyr was right... By reading that bardcode in the manual, your device is resetted to it's default settings... Read beyond text, look at the rank of the user... Ben
Restore factry setting qmobile e600
Go to "Settings -> Backup & Reset -> Factory Data Reset"
Dec 15, 2013 | Cell Phones
Im using Nokia 5730, everything is OK, but when i m trying to factry setting restor.. it asks for lock code, which i dont know i tried 1234,12345,0000, etc... my emie is 351964030670444.. Please Help....
HI, MUNABI ,
for nokia handsets lock code is 12345(by default) , but you have already tried for same .
i think some one changed the code .
so lets try another combinations like horizontal , vertical etc. ,(may it work but probably it will noy)
so if you urgentlly needed then you can upadate your software from any nearby service center so you code again reset to 12345.
Mar 29, 2011 | Nokia 9300 Handheld
Symbol handheld scanner LS 2208 USER MANUAL
http://www.geoti.co.kr/DATA/symbol/2208.pdf
just click the link to access the user guide
adobe acrobat reader must be installed first in your system to read the guide easily
Feb 27, 2011 | Hoover Vacuums
I want to reset using RS323 port , i forgot its ip adress
Hi
You can reset the device through RS232 port then please follow the below steps.
You need a laptop with Console port and a console cable for EOC-8610 EXT, You really dont need the IP address if you want to do it via console (RS232) interface.
1. Connect the console cable one end to EOC-8610 EXT RS232 port and other end to Laptop serial port.
2. Open Hyper terminal and select com-port option and then provide the username and password for the device management.
3. Go inside the system menu and select Reset Factory default.
Remember if u set to load the factory default settings, the device will loose its config and will boot up with factory default configuration.
Nov 03, 2010 | EnGenius / EOC-8610 EXT / 54Mbps /...
Restore factry setting code unknow
Hi. If no one changed your code, default code is 12345.
Sep 03, 2010 | Nokia 6230
Symbol LS 9100 does not transmit data
after scanning the defaults barcode you just scan the "Enable LS 9100 Communication" on this manual on the link above.https://docs.symbol.com/manuals/1536503c.pdf
May 11, 2010 | Symbol LS9100 Hands Free
Hello! I have a problem with scanning bar codes by ls2208 scanner. This device uses rs232 serial port, and when I try to read some bar code, the scanner is reading, but there is no number in notepad. How...
The scanner is sending the data to the serial port. You need an application to pull that data in off of the COM port. You can test using HyperTerminal. The scanner defaults to 9600 baud, 8 data bits, 1 stop bit, no parity and no hardware or software handshaking. Point HyperTerminal to the correct COM port (most likely COM1) and set it to the settings I just listed. When you scan you should see the data show up in the window.
If you want the data to go into Notepad or any other program expecting keyboard strokes I would recommend the Motorola (formerly Symbol) USB cable CBA-U01-S07ZAR or the CBA-K01-S07PAR keyboard wedge cable.
Jul 13, 2009 | Symbol LS 2208 Barcode Scanner - P/N...
Have a look at the HOST setting in your defaults. I set one of these to default and had the same result. I'm guessing it's because the HOST is blank on Default settings.
Feb 07, 2009 | Symbol LS9100 Hands Free
Symbol LS2208 RS232
Go to the LS2208 quick start manual scan the "Set Defaults" barcode and it will return the handheld to factory default.
Jan 31, 2008 | Symbol LS2208 Handheld
Symbol LS2208 Handheld Logo
875 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
