Question about Goodman GMS90703BXA Heater
Changed filters & unable to find restart button
We came home to a very cold house so my husband changed the filters. When we woke up the house was colder than the night before. How do we get it working again? My husband couldn't find the restart button. Is there anything else we need to do?
  • Anonymous Feb 11, 2008
    my heater is not stoping when thermostat reach temperatura
    Genius:
  • 1,067 Answers
Maby pilot light went out on u new one had button that will light it cheak 1st see if u see flame
Posted on Jan 31, 2008
I have a janone machine
Doreen:
use a screwdriver to remove the top housing (remove the screws holding the top housing on)... pull the top housing up off of the machine and reposition the spool pin and then reinstall the top housing.
Jul 04, 2014 | New Home HF-2022
Good evening all, This morning woke up to my home
Sounds like a faulty Tstat that's sending a low voltage signal to the contactor coil only sometimes. The high pressure cut out or the compressor's internal thermal protection could of opened, and then closed again after cooling. Make sure the condenser is clean and not obstructed.
Aug 31, 2013 | Whirlwind FH-778 Air Conditioner
How do you change a culligan water softener filter
The filter housing will have either a shut off valve before and after the housing or a valve on top of the housing that turns (Black).
Shutoffs before and after.
1. Turn both valves off
2. Push the "red button" on top of filter housing and hold to relieve the pressure off housing.
3. Unscrew housing to the left (lefty loosey, Righty tighty) You should have a housing wrench.
4. Remove filter, clean housing, lubricate the o-ring with silicone lubricant.
5. Replace filter, Screw housing back on (Hand tighten only)
6. Open inlet valve (slightly) while holding down the "red button" to relieve air in housing.
7. Open inlet and outlet valves and you are back in business.
PS if the housing is very difficult to remove.
1. Shut off inlet valve
2. Open the nearest cold water faucet and let it run until no water
3. Shut off outlet and repeat procedure as above
Good Luck, RJ
5.
Sep 29, 2011 | Culligan Sediment Water Filter
How to open the housing on big blue 20 to change filter
The best way to do this is to shut the incoming water supply off. Open the closest cold water faucet to relieve the water pressure. Shut off the outlet valve. You will need a BB wrench. Push the RED pressure relief button on top of filter as you turn clockwise on the wrench. Lubricate the o-ring with silicone lube, clean filter housing and re-install filter. Only tighten housing hand tight.
RJ
Mar 05, 2011 | Culligan 34" Whole House Water Filter...
Crystal-like substance
It sounds like your water system might need some filter housings installed?-- are there any filter housings in any of your water systems?-- If so, what are they accumulating-- what do you find, when you change filters.
Write back what you are finding.. If you have no filters, then let's install either ONE on your common cold water supply to the house-- or start with two at your washing machine. Which would be easier?- Write back-- Mack Baxter
Nov 02, 2017 | GE WBSR3140DW Top Load Washer
Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
May 27, 2009 | Honeywell ER150B Air Conditioner
Unable to hang up phone. The line is busy/can't make/receive call
sounds like you need a DSL filter, go to page 41 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf" if you don't have it) good luck!
Feb 12, 2009 | Panasonic KX-TG1033S Cordless Phone
Goodman GMS90703BXA Heater Logo
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
