Question about Canon PIXMA iP1600 Printer
Canon PIXMA iP1000
When I try to change ink cartridges the cartridge carrier will not move to the cenre of the machine when I try to open it. It remains stuck to the right hand side. How can I get it to move to the centre? HELP!!!.
Frustrated
  • Anonymous Sep 01, 2008
    TXT
I need to install ip1000 to my computer and dont have the disc
Posted on Jan 31, 2008
2 Suggested Answers
  • 749 Answers
SOURCE: Canon Problem
Well, you have to open the entire printer and reach out on that area to free the cartridge, it is caused by an obstruction on the gears of the head cleaner... remove that and have to wash it with water and then let it dry... place some grease to the gears so movement becomes smooth and last longer.
Keep me posted if you still have problems.
Hope this Fixya the problem.
Posted on Feb 04, 2008
How do you change the printer cartridge, please? I have mislaid my manual.
First make sure that the printer is on and the front cover and output tray are open. Next open the paper output cover by rotating it down towards the output tray. The ink cartridge carrier should move to the ink replacement position on the right side of the printer. Push the cartridge lock lever down until it clicks to unlock the cartridge that you need to replace. (The color cartridge is on the left.) Pull the cartridge towards yourself to remove it. Now open the replacement cartridge packaging and remove the protective tape from the cartridge. Push the new cartridge fully into the open spot from removing the old cartridge. (The label should be up and the copper covered sections should be down and facing forward.) Now push the cartridge lever lock up to lock the cartridge in place. If the lever doesn't move, check that the cartridge is fully forward in the slot. Finally close the paper output cover. Wait for the printer to complete the print head clean cycle before using the all-in-one.
Note: only remove and replace one cartridge at a time. Work quickly to minimize the chance of the ink system drying out after removing the protective tape.
Canon has the steps to change any ink cartridge on the Pixma MG4250 support site in the FAQ labeled Replacing an ink cartridge. The full text and pictures are available here: http://www.canon.co.uk/support/consumer_products/products/fax__multifunctionals/inkjet/pixma_mg_series/pixma_mg4250.aspx?type=faq&search=1&searchurl=/support/consumer_products/content/faq/?itemid=tcm:14-1276595 . You can also get the User's Guide and other documentation here: http://www.canon.co.uk/support/consumer_products/products/fax__multifunctionals/inkjet/pixma_mg_series/pixma_mg4250.aspx?type=manuals&language= .
I hope this helps.
Mar 22, 2016 | Canon PIXMA MG4250 Inkjet Multifunction...
FORGOT HOW TO CHANGE INK CARTRIDGE
turn ON the machine and open the front cover(ink cartridge cover)and wait then move the cartridges in the change position and if blinking change the cartridge.
Feb 15, 2013 | Canon PIXMA MP240 All-In-One InkJet...
I have a canon pixma mp250 printer and i can't find the manual to explain how to replace the black ink cartridge.
To change the ink, make sure that the printer is on (green light is lit). Then lift up the entire scanner unit and latch the support on the right. Wait for the cartridge carrier to move into the ink cartridge replacement position. Open the cartridge cover on the right hand side by pinching the front and the tab on the top together; then lift it upwards. The cover will rotate towards the back of the printer. Pull the empty cartridge back out of the slot. Open your new cartridge and peel off the protective tape. (Do not touch the electrical contacts or the nozzles.) Place the new cartridge in the slot (slide it forward). Then rotate the cartridge cover back down until it clicks. If you do not need to change the color cartridge, lift up on the scanner unit until the support unlocks. Then carefully lower the entire scanner unit to close it (don't pinch your fingers or drop the scanner unit). If the orange Alarm light comes on, check that the cartridges are correctly installed and the cover is in place. Wait until the printer recharges ink system before sending a print job or copying a page.
Canon has the documentation for the MP250 on their site: http://usa.canon.com/cusa/consumer/products/printers_multifunction/photo_all_in_one_inkjet_printers/pixma_mp250#BrochuresAndManuals (for the manuals) .
I hope this helps.
Apr 03, 2012 | Canon Pixma Mp250 Allinone Inkjet Photo...
How do I change the printe ink cartridge?
Hi There!
Here's what you can do to replace the cartridge
Just open the top cover together with the scanner cover. When the cartridge carrier move in the middle of the printer, it's the time you can replace the catridge, then lift up the top cover for the cartridge carrier & then the cartridges.
In replacing the cartridges, you just have to push the cartridge down the carrier, you will hear a snapping sound then return the top cover for the carrier and the scanner bed.
Hope this helps!
Vikroks
Mar 29, 2011 | Canon PIXMA MX310 All-In-One Printer
How to change the ink cartridge?
Download manual from http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp210#BrochuresAndManuals
Dec 31, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
How do you replace the ink cartridge on my Canon pixma mx320 printer?
Lift up the top lip cover together with the scanning unit cover to expose the cartridge carrier.
Open the ink locking cover. Gently pinch and pull up the cover of the cartridge carrier.
8bc22ce.jpgAfter that replace the ink cartridge...
I hope that instruction will be of help.
Please rate this answer.
Thank you for using Fixya
Jun 07, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
How do I change the ink on my Canon MX320
Just open the top cover together with the scanner bed.
When the cartridge carrier move in the middle of the printer, that is the time you can replace the catridge. Lift up the top cover for the cartridge carrier and then the cartridges.
When replacing the cartridge. Push the cartridge down the carrier, you will hear a snapping sound. Return the top cover for the carrier and the scanner bed.
May 20, 2010 | Canon PIXMA MX310 All-In-One Printer
Pixma mp180
Make sure the printer is turned on before loading the cartridges. Open the cover and make sure that the cartridge carrier moves all the way to the left before trying to insert the cartridges. When inserting the cartridges into the carrier, the end closest to you has to be pushed up to lock them into place.
Jul 25, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon Problem
Feb 04, 2008 | Canon PIXMA iP1600 Printer
Canaon pixma ip1000
i need driver for pixma ip1000
Sep 22, 2007 | Office Equipment & Supplies
Canon PIXMA iP1600 Printer Logo
520 people viewed this question
old marine
old marine
