Question about Refrigerators
Hotpoint side by side Model HSS25GFPJWW
I have a 2 yr refrigerator that makes ice, but when you push the ice dispenser the light dims and neither crushed or cube ice comes out. the water will dispense but no ice. The dim light with gradually get brighter as it would normally if it was dispensing ice. Any idea as to what the problem would be? I have the same problem with mine, hope we could get a detailed answer from some kind soul to help us out. Hate to pay a tech to come fix it if it ends up being something we could fix ourselves.
  • 749 Answers
Well I think it's time to call someone to check the electrical or mechanical parts of the refrigerator.. The freon inside the cooler tubes is already low and it needs to be refilled, I know you can't do it, there are a lot of tools needed to that.
Anyway, check the cooler knob if it is loose... that might be faulty, you may see it turning but inside it is not, "a loose-thread" maybe.
I wish I could do it for you... good luck...
Posted on Jan 31, 2008
  • 871 Answers
Hi there
you should let an electrician have a look at that because the lights that dim only means that there is a grounded wiring somewhere inside your fridge. what you can do is just look for an open wire. thats it. apparently, you could d this yourself, but be careful. hope this helps
fixya!
6ya staff
SOURCE:
The water is not working, but ice dispenser is, the make number hss25gfpjww
Clogged water filter or faulty water valve. You have a dual water valve on that unit which explains why the ice maker is working and not the dispenser.
Feb 23, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Have a GE Fridge Hotpoint Model HSS25GFPJWW The ice make, makes ice but the water dispenser (to fill a class) doesn't work. Replaced the filter and it still doesn't work, in Oct 09 it the same thing...
i would ck the water valve . this is a dual valve in the back one side may have burned out and is not opening to let water in one side is for icemker and other for foutain . and also ck the water line inside freshfood see if its frozen. ( if themp is too cold in fresh food side it will freeze . should be about 38 deg .. hope this helps mm
Jan 20, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Maker doesn't work
i press ice dispenser . and ice will not come out an light goses dimm please help
Sep 01, 2008 | Hotpoint HSS25GFP Side by Side...
Ice maker for Model HSS25GFPJWW
Probably, but sometimes frost builds up in them and makes them unable to turn. They are gear reduction motors so you may not be able to turn it by hand, but if you take the ice container out, hold the door open, the door switch closed and press the ice dispenser and try to turn it whichever direction it's trying to go, you may be able to free it up. If that doesn't work you'll most likely need a new auger motor.
Jul 21, 2008 | Hotpoint HSS25GFP Side by Side...
Hotpoint Ice Maker Stopped Making Ice
Friend,
ngfam1 At your service!
I came to your service on fixya.com some days ago!
And gave you some good advice!
But, I did not receive a rating from you yet!
Can you please give me a rating at our fixya.com site!
Bless, You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Jul 04, 2008 | Hotpoint HSS25GFP Side by Side...
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Clicking, no water or ice, power problem?
first i wold check the micro switch that the acuator paddle trips next i would replace the watervalves which is the most likely cause of this finally id replace the control bd as some early ges had a promblem with this there is also a solinoid in there for opening the ice chute door but that wouldnt affect the water but may cause a voltage drop if its getting bad id change the water valves the ice is on one valve the door water is on the other
Jan 19, 2008 | Hotpoint HSS25GFP Side by Side...
Your problems are the power board for sure. I have the same refrigerator and have read dozens of forums and advise pages looking for answers. If you let the problem countinue your fridge will completely stop cooling and all your food will be trash as has happened to me.
Symptoms: Fan in the back starts to make click or flopping sound as it tries to start up. Ice despenser doesent despense ice. water works sometimes. Eventually you notice your food defrosting partially and then refreezing as the defrost timer stops working which is controlled by the power board. Light dims and pulses when you hold the Ice despencer in. If you remove the light for the dispencer your water will work fine as long as the fan isnt making the clicking noise. Fan will eventually start up and run.
FYI GE customer Care is useless
Jan 03, 2008 | Refrigerators
Refrigerators Logo
116 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
