Question about Mitsubishi WS-55807 TV
Mitsubishi VS-70707 rear projection TV
Won't power up. Push power button and green light comes on for a second then goes out. Any ideas????
  • 749 Answers
It maybe the circuit protection detection failed to function properly have it checked by a technician to solve the problem as soon as possible or before it gets worst trying to keep on turning it on.
Posted on Jan 31, 2008
    Guru:
  • 1,894 Answers
DOES THE LIGHT BLINK IN A PARTICULAR PATTERN?
Mitsubishi
YOU NEED TO CALL THE MITSUBISHI TECH SUPPORT, THEY SHOULD BE ABLE TO TELL YOU FOR FREE THE POSSIBLE TROUBLE...JUST EXPLAIN THE ERROR CODE..GOOD LUCK
Nov 10, 2013 | Mitsubishi VS-70707 70" Rear Projection...
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Our WS-55313 Mitsubishi Projection screen tv was on then just died. When we push power button or remote on, the green power light comes on for a couple of seconds then the tv goes off .
do the self check this model has.
When green light goes off press and hold both the input and menu buttons for five seconds and release both buttons.
The power light will blink a two digit error code like, two blinks, two blinks, a pause and then repeat it several times.
let me know what the error code you find is and I will let you know what it means.
SD TECH
Dec 26, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Our toddler pressed several buttons on our Mitsubishi VS-70707 rear projection tv, it powered off now we can't get it to power back on?
Very simple , you need to initialize you tv by pressing menu and input bottoms at the same time for 30 seconds until the picture coming up and select * intitialize* on the screen menu, and wait until is done and you done.
Dec 18, 2010 | Mitsubishi VS-70707 70" Rear Projection...
Estimated Weight
Direct quote from 2001 Mitsubishi Product Catalog Specs. Gold Series
VS-70707
Weight (approx. lbs.) 365
Jul 19, 2009 | Mitsubishi VS-70707 70" Rear Projection...
VS - 70707
goto your menu and turn closed caption off, its probably set to 'text1. let me know if this corrects it
Nov 06, 2008 | Mitsubishi VS-70707 70" Rear Projection...
Good day, crsomers1;
The 'giggling' may be a horizontal problem, also known as pie crusting. Try this first: unplug TV from wall, reset or reboot. Secondly: CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB.
I hope this was helpful, good luck, big IRISH.
Jul 03, 2008 | Mitsubishi VS-70707 70" Rear Projection...
Try pushing Input and Menu together and hold them both in for 5 seconds to see if it blinks a 2 digit code which repeats itself. Then let me know what it does and we can go from there.
Jan 12, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Push Power button, green light goes on for a few seconds then nothing....
I would suggest taking a look at the power module if that can be replaced. The Fuse blowing may have only been the beginning of the problem. Any recent issues with under or over voltage in your home?
Jan 20, 2007 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubishi WS-55807 TV Logo
168 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
