My HP Deskjet F4140 was working fine until I got a piece of paper stuck. I removed and now it wont print. States printer off line and can not print a test page. IT will copy however.
  • 1 more comment
  • Anonymous Feb 29, 2008
    MY PRINTER WILL NOT COME ON .WAS WORKING OKAY, WENT TO PRINT A DOCUMENT AND JUST QUIT.
  • alear21 Jun 20, 2008
    HP deskjet F4140 will not print. I tried test pages and going through command prompts but it doesn't work. It does scan and copy. When I try to check ink levels it says it is unable to establish a 2-way connection. Anyone know whats wrong?
  • kisha79 Aug 05, 2008
    Printer was printing and all of a sudden i bumped it and now it states offline and it wont print anymore
    President:
  • 2,351 Answers
Turn it off. Unplug the power cord from the printer & usb wait a minute. Plug USB in & than the power cable & turn it on. Next
Open the Printers folder.
Right-click the icon of the printer in use, and then click Open .
Click Printer on the menu, and then ensure that there are no checkmarks next to Pause Printing or Use Printer Offline . If a checkmark is present on either, click the menu option to remove it. If the menu shows Use Printer Online , click that option.
Posted on Feb 01, 2008
6ya staff
SOURCE:
My hpdeskjet f4140 wont print a microsoft works document
Hi Josh,
Try disconnecting the usb connections to the PC.
Uninstall the printers software and reboot your computer.
Turn off the printer and then on again.
Insert the installations disk into your computer.Follow the installation instructions and connect the printer only when prompted by the installation setup to do so.
Hope this helps.Thanks!
Nov 14, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
My hp deskjet f4140 will only scan and coy. It will not print anything from my computer. I used it last night and it worked fine , then it just stopped. Ive checked my devices and printers under my control...
is it giving any error while giving print command? goto start settings printer & faxes open the printer icon by double click .any job is pending in the queue? try remove the usb cable and check t below the pinter icon whether it shows off line?
Aug 04, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
Moved printer and was very careful about it. Now cannot get printer to work flashes "E" and color,black photo, resume and power buttons flash as well. No control of the printer at all
It seems that there is a Paper Jam or Cartridge connection issue
1) Check the paper : is there any paper stuck -
2) Remove the cartridge and reconnect them .
checked the print ..
Aug 10, 2010 | HP Deskjet F4140 All-In-One InkJet Printer
My hp deskjet 895cxi has worked so well for years
probably clogged nozzles. Clean the print head. If that doesnt work, replace the cartridge with a new one
Jul 23, 2010 | HP DeskJet 895cxi InkJet Printer
HP deskjet F4140 Error light on & I can"t print
please reset your printer. turn off your printer, leave it for 30 sec and turn it on again....
If you still have problem try to re install the catridges again, follow below instruction
http://etech.maiila.com/hp-deskjet-f4140-all-in-one-printer-catridges-installation
Good Luck
Nov 01, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet F4140 tantruming
Hello!
Try unplugging your printer from the wall outlet and leaving it that way for ~30min.
If this does no help then it means that a fuse has burnt out somwhere in the device.
Sadly there is no manual on how to disasemble a F4140, plus it would void your waranty.
I suggest you try to return it under waranty, just don't say you don't know why it stopped working ;]
Hope this helps!
Sep 09, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
511 people viewed this question
Ekse
Marvin
Marvin
