Question about Targus Stowaway Keyboard
About ps2 pin wire structure
I am using samaung sdk3500 keyboard yesterday ps2 pin of keyboard is damaged then i cut the wire and i have another ps2 pin i try to fix that ps2 to this keyboard wire so please give me the combination of wire color or ps2 pin structure
  • 1 more comment
  • navnath Feb 06, 2008
    A worst suggestion
  • loosestudios Feb 13, 2008
    have the same problem with a sunbeam tech lighted multmedia key board
    than cost almost $ 40.Why let little wiring problem cause me to throw it away. Think about the land fill . Just fix it
  • LIJUBAHULAYAN Jan 16, 2014
    Visit for color code information : http://www.jeyel.in/2014/01/keybord-colo...
    Champion:
  • 207 Answers
I suggest that you have to purchase a new keyboard..Com'on dude!! why are spending much time on those damaged ones.. You don't want to hurt, do you?? its affordable you know...
Posted on Feb 05, 2008
6ya staff
SOURCE:
Logitech mouse left button does not work
That is a circuitry problem. You can try this following procedure if you can. --unscrew and open your mouse casing. --you need a tester (VOM) to test the wiring continuity. If one of the wire is open connection you can replace it with a new USB or PS2 connector. If all the wire is shorted, proceed to the next step. --Check if the microswitch is ok by testing the pin connection using the tester. Microswich has 3 pins, test only the soldered pins. When you press the switch, it might be shorted. If not, replace it with a new microswitch.
Microswitch and USB/PS2 connector are available in all electronics shops.
May 27, 2011 | Logitech Computers & Internet
Keyboard error of pc p4 compaq
Check that it is indeed plugged into the purple PS2 port on your computer, if the keyboard is USB then try alternating ports. Some-times just by plugging it into another USB port it can work.
Also it maybe that the keyboard has died, try a friends keyboard on your computer to test it. Try do as much as possible before purchasing replacement parts.
Take care!
damnor01
May 25, 2011 | Compaq Presario 5000 PC Desktop
Pc not recognising keyboard sahara kb 0325, using onscreen keyboard sux
Key board or mouse not work mean one of four reasons
1- kb or mose is damaged (replce it )
2- ps2 socket is damaged (can be replaced )
3- Resistance No 472 on motherboard is damaged (can be replaced )
4- I/O IC is damaged (i think no repair )
easy solution you can buy a (usb-ps2) converter
best regardes
Apr 05, 2011 | Sakar 62150 Keyboard
I have a BTC keyboard, Model #: 9000A. A wire became broken in the PS/2 male plug. I need a Schematic so I can solder on a new plug. I know this is a very old keyboard, but I like it and do not have the...
Unfortunately there is no color code for the cables in the PS2 connector. All the details that I can give you is that if this is the PS2
The pin #1 moves DATA.
The pin #2 is not connected or DATA2 (usually not connected)
The pin #3 is GND
The pin #4 is VCC for power (+5 VDC)
The pin #5 is CLK for Clock
The pin #6 is not connected or CLK2 (Usually not connected)
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Oct 18, 2010 | Computers & Internet
HPTFT5600 RKM Tracker Ball Connector colurs goto PS2 connector
Sorry to say but there is no standard on the color of the wrie used in any brand of the mouse or key board, I GOOGLE the PS2 PIN OUT and these are what I found: http://www.burtonsys.com/PS2_keyboard_and_mouse_mini-DIN-6_connector_pinouts.html
http://www.bbdsoft.com/keyboard.html
http://www.allpinouts.org/index.php/Mouse/Keyboard_(PS/2)
http://en.wikipedia.org/wiki/PS/2_connector
You need to find out about the wiring of your track ball. Brand and model? Hope this will help.
Mar 05, 2010 | HP TFT5600 RKM (Black) 15" LCD Monitor
HOW TO ENABLE "euro" KEY IN ABOVE KEYBOARD
Log on to
http://www.columbia.edu/~em36/wpdos/eurodos.html
May 04, 2009 | Computers & Internet
Broken ps2 connector ACK-595 Keyboard
go to this webpage http://en.wikipedia.org/wiki/PS/2_connector there´s a list of different wire arrangements it could help you.
Nov 22, 2008 | Adesso ACK-595 Keyboard
IBM Clicky Model M Keyboard
Viewing the male connector (on the keyboard or mouse cable), the pinout is:
In both cases, the pins are normally used as follows:
pin function
1 data (yellow)
2 (reserved)
3 gnd (blk)
4 +5v (red)
5 clock(white)
6 (reserved)
try to interchange wire from pin 1 and pin 5 if doesn't work.
Dec 27, 2007 | IBM (02K0806) Keyboard
Targus Stowaway Keyboard Logo
451 people viewed this question
Top Targus Computers & Internet Experts
Raj Patel
tony wahlman
tony wahlman
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
