Coffee and Espresso Makers
Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
Coffee grounds in pot
By Psych23 on Jan 31, 2008
My coffee maker works fine most of the time, but every once in a while, one side of the filter gets folded over while it's brewing and i get a pot full of grounds. Any suggestions on how I can get it to stop doing that??
Same Problem
Jan 12, 2009
-   I have the same problem everytime with the same product. My filter folds when it gets wet, coffee grounds are not filtered and sent into the pot. Is there a special coffee filter needed for this product?
-   carodan10
Solution #1
posted on Jan 31, 2008
Somewhat Helpful)
pierre235
Rank: Guru
Rating: 87%, 839 votes
maybe you grind or buy coffee that is to fine it take longer time for water to go true the fine coffee differente coffee different grind cheers
Was this helpful?
Yes
No
Solution #2
posted on Oct 07, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thanks for the suggestions, guys. I have since tried cutting a little off the top of the filter in the spot where it always gets folded over, and it usually works. :)
Solution #3
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
My filters folded over too.......grr.......so I found if I ran the filter holder under water first and then put in the filter, it sorta stuck to the sides. Also I tried flattening out the coffee inside the filter. Both of these ideas worked well.
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Answer
which style of the bodum french press' is best, the chombard, brazil, or kenya?
Answer
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop... (More)
Answer
so i filled it with 8 cups of water and put 8 spoonfuls of coffee in the top and turned it on. When... (More)
Answer
my dolce gusto gives me 2 cups of hot coffee and the rest tat come out are luke warm
Answer
tassimo leaking water from underneath when used
Describe your Coffee and Espresso... problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repairmen
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
