Question about Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-in-One Ink Cartridges
Is there a way to continue printing even though the printer says there is near empty or empty ink cartridge? Is there a way to completely empty the ink from the cartridge? Sometimes the printer tells me to change the ink cartridge and I can still see and hear ink in the cartridge.
  • GoddessJen Feb 02, 2008
    I only want to use BLACK, but it insists on all colors being available before it will print. Is there a setting to say "just black"?
    It also seems I can't do ANYTHING until I replace cyan - no scanning or faxing (which requires no dang INK). Is this really true??
  • 832 Answers
Near empty message is a reminder: plz buy a new cart (but do NOT change until EMPTY). You still can print.
the ink left in an empty cart keeps the system alive when some ink is neede for the automatic cleaning cycle.
If you print until this cart is really empty air will get into the tubes and ph. That leads to faulty printings.
brother had made sure that the amount of printable ink can be consumed. The rest is for service.
Posted on Feb 01, 2008
3 Suggested Answers
Mix-it-up
  • 832 Answers
SOURCE: MFC 210C Ink Problems
Steve,
did you watch the display after replacing the cart?
Very often the machine asks if you have changed the cart and demands an answer (1 for yes).
You can try to do an update of the firmware, too. Go to www.brother.com , choose your country and then your machine. Download a small update tool and run it.
If it aint getting better:
Do unplug from power outlet (even though you have done already) wait 10 Min. leave scanner cover open and take all carts out. Plugin to power again and leave scanner open. Wait uintil machine gives a warning signal. Reinsert carts and close cover: now watch the display and give always the answer YES(1).
Posted on Mar 04, 2008
SOURCE: Brother MFC 210C Printer Ink
Is the cartridge a remanifatured one? if so don't worry i had the same problem with my canon MP460 it's a chip setting on the cartridge
Posted on Aug 07, 2008
Problem with my Brother MFC 210C Printer won't print the colors.
Check your ink cartridge if they are properly installed.
Check your print settings.
Make sure your ink cartridge are not empty.
Replace your ink with the original Brother ink cartridge.
Sep 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
Ink is near empty
If it was recicled cartridges, thats normal!!
Jun 23, 2009 | Brother MFC 210C All-In-One InkJet Printer
Replaced color ink cartridges
Do a print head alignment. This will tell the printer there's a new cartridge.
Mar 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C series ink replaced
The brother machines require ink in all the cartridges as it is always flushing ink through the heads to "clean" it. This means you must have ink in all cartridges at all times unfortunately or the brother will not work. Even if you could somehow get it to work it could damage your printhead anyway.
Good Luck
Please rate my advice, good or bad.
Feb 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
Printer says ink near empty
Black electrical tape works like a charm on a Brother MFC-465CN. Thanks for the tip! :-)
Jan 16, 2008 | Brother MFC 210C All-In-One InkJet Printer
Replace Cartridge,Ink Emty Black
see here:
http://www.fixya.com/support/t213275-say_new_cartridge_yellow
Do use original ink carts because thirdparty ones have a different construction and wont be accepted by printer sometimes.
When (re-)inserting press ink cart into assy and clip the support over the edge.
Please check the other carts, too. They may be empty.
Oct 15, 2007 | Brother MFC 210C All-In-One InkJet Printer
MFC-210C
First ensure that none of your inkjet cartridges are empty or near empty. The machine will not perform cleaning if any cartridge is too low on ink. If the conditions are met the machine at least attempt perform the cleaning function. There is no guarantee that the print quality will improve on the first try.
Sep 16, 2007 | Brother MFC 210C All-In-One InkJet Printer
Only printing black and cyan
If you have used third party carts before you can't repair this problem due to the fact that the filter inside the printhead is clogged with particles. There is no chance to clean the filter. Sorry. Do use only dye ink. Pigmented ink is the printhead killer for brother printers!
Aug 25, 2007 | Brother MFC 210C All-In-One InkJet Printer
Printer not printing
Unfortunately, like most multi cartridge ink jet printers when one ink is empty the printer will cease printing regardless of whether you just want to print in black and white and you have plenty of black ink left. I have heard of people tricking the printer into believing the cartridge is full by placing coloured tape etc in front of the ink sensing device but I am not sure how the Brother senses the ink levels as i have some aftermarket ink cartridges for mine which seem to be completely non-opaque (unlike the originals). The need to have colour cartridges in even if you only ever print with black ink is good news for Brother as the MFC-210c uses a large amount of ink during it's routine cleaning cycles (that you cant stop) and will empty all 3 cartridges in under 6 months without ever printer a single drop of colour ink. Sorry about all the bad news, at least your not alone......
Dec 28, 2006 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
311 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
