Question about Sabrent SBT-RDIT PCI IDE Silicon Image RAID Host Controller Card RAID 0/1/0+1(For Both Low Profile P... (1801019)
Pci ide raid card problem
My pci raid card finds my drives sometimes. When I am in windows xp pro I can find all of my hds in windows explorer but then they will disappear and the system will lock up. When I reboot 1 or 2 of the drives on the raid controller card won't show up at boot. I have tried different raid cards (Maxtor and Silicon Image) and I have installed new ribbon cables to the drives twice and this doesn't seem to make any difference.
System:
Windows XP Pro (SP2)
Intel pentium 4 CPU 3.4GHz
2 gig ram
Radeon 9800XT video
Integrated audio
Silicon Image pci raid controller card
Terry
  • Traxcat Jan 31, 2008
    v-tech model: vt-465ld (450 watt)
  • 56 Answers
Could be a PSU problem. What wattage PSU do you have?
Posted on Jan 31, 2008
6ya staff
SOURCE:
I have a Dell Optiplex 170L mnitower. It has one IDE and one SATA port. I have connected a 1 TB drive to the sata and disconnected the ide drive that came with the system. No I am thinking, what if I add...
Hi there! You don't actually need a IDE to SATA converter. If you purchase a RAID 1 card, it gets hooked up to your computer via PCI or PCI-E. The RAID card will have at least two SATA ports on it - those are what you use to create your RAID. The sata port and ide port on the computer will not be used in the raid1 configuration. If you're going to go ahead with this, I'd recommend trying to find the exact same brand and model of drive as the first one you have. Also, keep in mind that creating a RAID 1 array requires formatting BOTH drives. Your Optiplex 170 only has PCI ports, so this may be a viable RAID card. It is fairly inexpensive, but will do the job. http://www.newegg.com/Product/Product.aspx?Item=N82E16816132001&cm_re=PCI_RAID-_-16-132-001-_-Product If you need any more help/advice let me know! Alex
May 30, 2011 | Computers & Internet
I cannot find a driver anywhere for my belkin f5u098 ide raid controller.
The drivers for this ATA Controller Card are resident in Windows, just like the Motherboard's onboard ATA/IDE Controller. If they don't autodetect and load make sure you are running at least Service Pack 2 for Windows XP and SP4 for Win 2000. Vista and later will have resident drivers.
Sep 23, 2009 | Belkin Ultra ATA/133 PCI (f5u098) ATA...
Pci ide controller for third hard disk
You need to enter into scsi bios first, then do an autodetect for hard drive, this will set the IDE/SCSI hard drive on raid controller.
To enter SCSI control you need to press the same key stated on screen on startup (F6 I assume) I think F3 is just boot settings.
If the card do not enter regularly in CMOS settings for the raid then this card is defective.
Mar 28, 2009 | Sabrent SBT-RDIT PCI IDE Silicon Image...
SATA Raid card on PCI unable to detect eSATA Hard Drive
if you install the raid controller drive,it means it will shown the drives..but it not shown? is this what you mean? did you try to see in the computer management? if you dont know, check this out..right click my computer-manage-select disk management and check if your drive is there......this is only what i know about what you mean.
Mar 03, 2009 | Intel Motherboard
SATA RAID Controller Card Problem?
You are almost there. Go into your BIOS and enable RAID. Then your raid bios should show up on next boot.
Feb 15, 2009 | Intel Motherboard
Pci ide controller for third hard disk i have connected a third hard disk160 gb in my desktop via pci ide controller card in windows xp. hard disk is not being...
first u shud check if the BIOS is detecting ur new HDD.
if its not u can activate the new port through bios in the advanced peripherals options sectin :)
Jan 30, 2009 | Sabrent SBT-RDIT PCI IDE Silicon Image...
Hello, I have a PCI Ultra Ata/133 Dual IDE card. I have two Ide devices hooked to it. Everytime I hook it up in the system My regular Motherboard IDE says can't be read, reboot. I am trying to get not Raid...
Sounds like the system is trying to boot from the drives attached to the controller. Go into your setup and make sure the system is set to boot from the proper drive.
Jan 12, 2009 | Maxtor Ultra ATA/133 PCI Adapter Card...
IBM Blue Screen
I had the same problem with an Intellistation 6868 for years. It just wouldn't load XP but ran fine on Windows 2000 SP4. I tried 3 different XP Installation CD's with no luck. After several attempts at installing XP I bought a clean XP Upgrade from ebay.
It took me 3 goes to install it but eventually I got it in there. If you can get XP to start on the 6868 press F8 and start it in safe mode first then when it's booted fully, shut it down and and then start it clean again. It worked for me. I've been running it for 5 months now and it's fine.
I couldn't get it to work at all on the 6868's onboard IDE so I installed a PCI Raid Card and it boots fine on that.
System:
IBM 6868 52A M-Pro Intellistation
2 x Intel P3 866 CPU's 256 mb cache
2 GB ECC RD Ram
2 x Seagate 320 GB 8MB Cache HDD on a Sunix ATA133 PCI Raid Card
2 x Seagate 10000 rpm SCSI HDD on Adaptec Raid Card
ATI 9520 AGP 128mb Graphics
Win2000 Professional SP4 - Upgraded to XP Professional Edition SP3
Dual Boots with Xandros Linux Desktop Destop 3.01C
Sep 08, 2008 | IBM IntelliStation M Pro 6868 PC Desktop
Sabrent SBT-RDIT PCI IDE Silicon Image RAID Host Controller Card RAID 0/1/0+1(For Both Low Profile P... (1801019) Logo
180 people viewed this question
Top Sabrent Computers & Internet Experts
WTF Chuck.....
WTF Chuck.....
Colin Stickland
Colin Stickland
Alun Cox
Are you a Sabrent Computer and Internet Expert? Answer questions, earn points and help others
