Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Ice despencer won't make ice any more
It's not making ice or not comeing out the despencer
  • spogmaster Feb 01, 2009
    my icemaker is getting water, its ferrzing in the tray, but hte despencer is not kicking the ice into the holdingbucket after hte ice is made
    Problem Solver:
  • 19 Answers
Are you getting water? If you have water check how cold freezer is. Freezer most get to minus 10 degrees somtimes as low as minus 5. If your freezer is working properly it should drop to zero or below.If you are not getting water and you freezer is cold enough to trigger the system.You either have abad solinoid valve or your line is stopped up. Loosen line at frig. first to make you are getting water.You have a wire with acouple spades on it you could hook directly to solinoid valve to check it. Hope this helps Fxit
Posted on Feb 04, 2008
Is it the despencer or the icemaker which thing showing the problem makes a difference to giving you info on the repair.
Posted on Feb 01, 2008
5 Suggested Answers
  • 958 Answers
SOURCE: whirlpool side by side fredge
is the ice maker set to make ice?..is it in the "on " position?
Posted on Feb 12, 2008
SOURCE: ge profile refrigerator ice maker
I have what appears to be a similar problem -- but have not yet found a solution. The door or valve on the ice dispensing chute is not closing or sealing properly. The warm air from the kitchen is drawn into the freezer (ice maker). The warm air condenses and freezes causing the ice cubes in the ice bin to freeze together, preventing their discharge from the bin. Also, the warm air and condensation freezes and builds up frost and ice in the discharge chute. When you try to discharge ice cubes, they get stuck in the chute and will not discharge.
Temporarily, you can open the freezer door, access the ice bin and loosen the cubes which are frozen together. You can also remove any cubes from the discharge chute. If there is frost and ice in the discharge chute, use a hair dryer to melt the frost and ice, putting a container under the dispenser in the door to catch the run-off water.
I've done all of the above and I'm still not getting a proper seal and air is still getting into the ice maker bin and dispensing chute. Looks like a service-call is next.
Posted on Oct 06, 2008
SOURCE: Door ice and water despencer doesn't work and light dims when activated
defrost not working
Posted on Jun 12, 2010
sodeep
  • 3267 Answers
SOURCE: my ice despencer is not
There is a tub that goes through the back of the freezer wall into the ice maker. Sometimes this tube will freeze shut and needs to be thawed out.
The water fill tube will freeze shut from low water pressure. Ether from a bad water valve or low pressure to the refrigerator itself.
Pull the refrigerator out and remove the tube from the back wall to check it.
Posted on Jun 14, 2011
When ice maker clicks on to make ice water comes front of refrigerator on the despencer
someone has the wiring crossed. Did you buy this used or has someone worked on the water valve? What is the model number of the fridge?
APPLIANCE 911
Dec 07, 2015 | Frigidaire Refrigerators
Ge side by side ice maker not filling up
most of the time when that happens first thing you do is make sure water is getting to the solenoid for the ice maker if you have a water despencer you have water the solenoid for the ice maker is normally found in the back of frig near bottom pull frig out till you can get behind it look where water line goes into the frig solenoids for water and ice maker should be there. leave frig plugged up have someone use the water despencer feel whitch one that is replace the other one
Aug 20, 2014 | GE Refrigerators
The ice in the tray melts and runs out the despencer outlet.\r\nMakes ice but the front part of the ice tray slowly melts and water runs out the despencer outlet. Have had service man work on it four...
Your freezer temperature is not coldenough, inspect for hardness of frozen foods. Make sure that the temperature is 5 degrees Fahrenheit or lower. Carefully feel the side of the ice maker if itis warm the unit is stuck in heat for release mode. Check and replace control module.Call repairman to check this.
Thanks
Feb 05, 2011 | Electrolux Refrigerators
I have a whirpool ED2VHEXTB side by side: ice maker works fine but often the ice freezes while inside the automatic despencer and wont come out
Check to make sure that the dispenser flap is closing properly. Sometimes an eyelet will break off and cause it to see ackwardly. They make ita kit to fix that even thought they try to get you to purchase a new door.
Oct 28, 2010 | Whirlpool Refrigerators
Hotpoint refridger ice maker not despencing ice or water
my ice maker stop making ice there is ice cubes in the tray but the ice maker does not dispence the ice
Apr 04, 2010 | Hotpoint HSS25GFP Side by Side...
My kenmore elite side by side is making a buzzing
The buzzing noise is likely coming from the main power board and will need to be replaced.
Nov 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Whirlpool side by side fredge
Feb 12, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
159 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
