Question about Intervideo WinDVD 5 for PC
Pop up onto screen
Within the past mo. I've noted a distracting pop-up of this product (along with a control panel image -i.e. play, volume,etc.) on startup. It overlays my screensaver. I don't know if this is due to something I did, or if this computer thinks it's playing a DVD. I purchased this Toshiba Satellite M40/M45 from Best Buy in 2005 - where it came loaded with a multitude of programs.
I had attempted to copy pix onto a CD w/o success just prior to this pop-up.
Can you suggest what I can do with this? I am able to get rid of it by hitting the "X" icon, but the next time I turn on the computer, THERE IT IS!
Thanks for any helpful suggestions.
Arija Brewer
  • 66 Answers
Well check first of all your startup program see if your are able to remove it from there ,oderwise type msconfig in start menu>>run box and check if that popup or program is listed there also check your screen saver settings !!i hope this works
Posted on Feb 01, 2008
Delete pasword
is cant make that cuz one way solution is hard format
Let's start with the most common Hard Reset methods and go from there:
Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlightsFACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release thePower key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and theCamera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc.
With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time.
When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key.
Continue holding the Volume up and Home key until the "Android system recovery" screen appears.
Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection.
Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean.
6. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS...
While the phones power is off, press and hold the Volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step).
A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key.
Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up.
Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK.
After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK.
Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen.
7. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS.
Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit.
The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press theVolume up key to boot in this mode.
Wait for the "triangle!/Android" screen to pop up. Once it does press both theVolume up and Volume down keys simultaneously. A Recovery Menu should pop up.
Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection.
After it's done make sure "reboot system now" is highlighted and then tap thePower button.
In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through.
8. Here is a hard reset for a Sharp Android Smartphone.
While the device is off, hold the Sym button (it's located on the keyboard) and thePower button simultaneously.
Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection.
Scroll down to Yes - delete all user data and then press the Power key to confirm.
Once it is done select reboot system now and press the Power key to confirm and reboot your handset.
Important Note: On some Sharp models (such as the Sharp FX Plus ADS1) if holding the Sym button and Power key simultaneously doesn't take you directly to the Android system recovery screen you might have to do one additional step. If using this hard reset key combination takes you to a screen which shows an exclamation mark within a triangle, then press the Home key (while on that exclamation mark screen) and this should take you to your Sharps Android system recovery options.
Apr 27, 2014 | Samsung Galaxy Cell Phones
Unlock cont g mail
Apr 21, 2014 | Samsung Galaxy S Advance GT-i9070 Black...
Password
Apr 20, 2014 | Samsung Galaxy Cell Phones
Internet
Apr 18, 2014 | Samsung Galaxy S Duos S7562 White Dual SIM...
My tablet model p3100 reset repeadely
Apr 16, 2014 | Samsung GALAXY TAB 2 7.0 8GB BLACK P3100,...
Try to reboot but still on ftm mode
Apr 09, 2014 | Samsung GT-P6200 Galaxy Tab 7.0 Plus 16GB,...
Master reboot
Mar 24, 2014 | Samsung Galaxy Cell Phones
FENDER HOT ROD DEVILLE 410 POPPING SOUND
I have answered some of this before, however I have reveiwed the schematic and as an electrical engineer I want you to do a couple tests.
First, plug in a set of headphones into the preamp out jack. Note that due to the impedance mismatch what you hear will not be very loud. Now change the state of the clean OD. Did you hear a faint pop?
Next plug a LOW impedance device OR even an instrument cable into the power amp "input" jack. Do this with the power off then warm amp up.
Now, change the state of the clean OD. Did you hear a faint pop?
Now for the analysis. If you did hear one in the first test and NOT in the second, the pop you are hearing is the "NATURE OF THE BEAST".
I can tell you from the design that the pop you hear is from coupling within the clean and OD relays within the unit. There is no cure for this within the unit other than find another brand...
I would recommend that you use an EXTERNAL pedal for the effects you want rather than trying to use the clean OD in this amp. I suspect it was never intended to be shifted during playing as I can guarantee it will pop when you shift while having anything other than dead silence (not even a bit of hum from your guitar). There is also statistical noise in the preamp that the laws of physics will not let us get around that may be enough to create a bit of a pop.
You could also use a volume pedal between the preamp output and the power amp in to throttle the volume to zero before shifting to OD.
In general I think you will find that what you are hearing is the nature of this beast.
Mar 18, 2010 | Peavey Music
Very faint sound on everything, including system sounds. when playing a cd, can hear music, but not lead vocals except faintly. are the speakers shot? Everything was okay yesterday, and no settings have...
First of all, if you have volume controls on the keyboard, please make sure you turn the volume up from that location.
Next, locate the Speaker icon next to the time in the lower right corner of the screen. Double or single Click on that and make sure the volume slide bar is all the way to the top. If you don't have a speaker icon, roll over these icons slowly and an info bubble will pop up. Look for one that involves audio. If you right click on the icon, you may be able to select volume mixer or something similar, there you will find multiple volume settings, turn all up.
Finally, if you are having this problem when using a media player (Windows Media Player, VLC, Quicktime, etc), there will be a separate volume control within the player itself. They are usually a slide bar underneath the video or graphics display. Turn this up also.
Please note that if you are using a laptop, Laptop speakers are notoriously of poorer quality and lack the wattage of desktop speakers. In turn, it may not be a problem with your laptop2_bing.gif. You may need to look into purchasing an inexpensive set of external speakers.
Feb 26, 2010 | Logitech Audio Players & Recorders
Dell Ultrasharp 21' monitor
I had the same issue. I pressed and hold the + button and the monitor did an auto adjust and the pop up stopped.
Aug 23, 2006 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Intervideo WinDVD 5 for PC Logo
69 people viewed this question
Top Intervideo Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Intervideo Computer and Internet Expert? Answer questions, earn points and help others
