Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Temperature control My refrigerator changes temperature and will not go to the set temperature. It is now at 46 degrees and I cannot get it back to the 37 degrees that it is set at. I did not change anything and I made sure that the door has been shut completely. I can hear the motor running, but it just doesn't cool properly. This happened once before and the temperature went back to normal on its own after about a day. What do you think could be causing it to change temperature? Do I need to have it serviced? Any advice that you could give me would be greatly appreciated. Thank you.
Sounds like a control board problem. If the problem persist call a tech. to come and do repairs finding it to be the control board can some time be a real pain on GE's. I have worked on your model many,many,many,many,many times to know it sounds like a board problem. Next time it starts cooling odd again unplug for 30sec. and plug in this will reset the controlboard if persist call out tech. or give me a shout with more detail to whats going on. If it is the board it's about $200. Good luck.
Posted on Feb 01, 2008
  • 26 Answers
Hi,pls check your thermostat if this early cut-off, try to replace the thermostat.thank you
edgz
  • 1462 Answers
SOURCE: Refrigerator not cooling.
compressor has failed. not a diy job
Posted on Apr 25, 2007
  • 213 Answers
SOURCE: GE PSW26M Artica Cooling and Ice Maker Problems
on the back of the frig is a small rectangle panel. inside that panel is the motherboard that controls the whole refrigerator. thoughs boards have been nothing but trouble. one of the problems it causes when it goes bad is the problem your having. replace the board to fix it
Posted on Nov 30, 2007
  • 531 Answers
SOURCE: Ge model PSC25MSTASS digital refrigerator setting
check for frost in the freezer back wall
Posted on Apr 01, 2009
SOURCE: The refrigerator temperature keeps dropping
I had the same problem with my GE GSS25LGMB and after some googling I learned that the damper door might be broken. Indeed after I took off the damper assembly the door appeared to be broken at the hinge. This door has its own thermostat and controls the influx of cold air into the fridge which explains the frozen food. I am trying to glue the broken piece back on. See if it works. Othwersie you'll have to replace the entire damper assembly which costs about $91. (http://www.pcappliancerepair.com/cgi-bin/detail.cgi?item=WR49X10091&brand=GEH)
Posted on Apr 28, 2009
  • 10 Answers
SOURCE: GE ARCTICA Refrigerator, M/N PSS26PSTA - poor cooling
possibly low on gas
Posted on Sep 13, 2009
I have a KitchenAid Refrigerator Model Number: KBFC42FTS. Bottom drawer freezer over cools -10 degrees.
That's interesting, -10 or colder is too cold and something is defiantly going on. This unit is controlled by a mulitple control boards, temperture sensors and other components. Question, what is freezer temp set at? Try increasing it by 3-4 degrees and see if that changes anything. Beyond that, I'm going to change the temp sensor first before doing any of the control boards. #29 is the temp. sensor. Good Luck
Sep 19, 2017 | KitchenAid Refrigerators
Samsung rs2577sw Refrigerator
if you make the changes on the temp nob doesnt it work.
Jun 20, 2008 | Refrigerators
How can I get into the cut-on settings of refrigerator
Purchase an appliance thermometer that is specifically made for refrigerators and freezers. These special thermometers were made to withstand cold temperatures and provide an accurate reading when exposed to such temperatures.
2Place the appliance thermometer in a glass of water.
3Set the glass of water with the thermometer in the refrigerator on the middle shelf.
4Check the temperature on the appliance thermometer after 24 hours.
The temperature should register between 37 and 40 degrees Fahrenheit (2 and 4 degrees Celsius) in order to store food safely.
Only barely above freezing -- say 34 degrees Fahrenheit (1 degree Celsius) is even better for food storage at the cost of slightly higher electricity consumption. But check that food is not slowly freezing in any part of the refrigerator, which could make it less palatable.
5Look for the temperature control dial inside the refrigerator if you have to adjust the temperature, and make it warmer or cooler.
If you can't easily see the control dial, check the owner's manual for a diagram that shows the location.
When looking at the refrigerator temperature dial, you may see numbers rather than degrees. The majority of refrigerators use a set of numbers, with the lower numbers representing cooler temperatures and the higher numbers representing warmer temperatures.
6Move the temperature dial in the necessary direction to adjust the temperature up or down. Be sure to move the dial only one number in either direction because it probably will not take much to change the temperature in the refrigerator.
7Adjust the temperature balance control if your refrigerator has such a dial or sliding switch. This allows you to direct more or less cold air to the refrigerator section from the freezer section.
8Wait at least 24 hours, and then check the refrigerator temperature again.
9Observe the amount of frost in the freezer section of the refrigerator if you are unable to properly set the temperature.
10Defrost the freezer if the amount of frost is more than .25 inches (.64 cm) thick.
11Repeat the steps as necessary until the temperature is within the safe range.
12Use a permanent marker to draw a line on the dial after you locate the best setting on the refrigerator temperature dial. This will give you a reference point in case your dial moves and needs to be adjusted in the future.
Hope this help in solving the problem....
May 12, 2011 | Refrigerators
How do I regulate temperature
I hope this will help in solving the problem.......
May 09, 2011 | Samsung RF265AA Bottom Freezer French Door...
How to set up the temp. please
Hope this will help out...
May 07, 2011 | Traulsen Refrigerators
I cannot adjust the fridge/freezer temperature
Hi, there
Hope that helps in solving the problem...
May 07, 2011 | Refrigerators
I have a Samsung refrigerator/freezer How do I adjust the freezer temperature?
1Place the appliance thermometer in a glass of water.
2Set the glass of water with the thermometer in the refrigerator on the middle shelf.
3Check the temperature on the appliance thermometer after 24 hours.
4Look for the temperature control dial inside the refrigerator if you have to adjust the temperature, and make it warmer or cooler.
If you can’t easily see the control dial, check the owner’s manual for a diagram that shows the location
5Move the temperature dial in the necessary direction to adjust the temperature up or down. Be sure to move the dial only one number in either direction because it probably will not take much to change the temperature in the refrigerator.
6Adjust the temperature balance control if your refrigerator has such a dial or sliding switch. This allows you to direct more or less cold air to the refrigerator section from the freezer section.
7Wait at least 24 hours, and then check the refrigerator temperature again.
8Observe the amount of frost in the freezer section of the refrigerator if you are unable to properly set the temperature.
90Defrost the freezer if the amount of frost is more than .25 inches (.64 cm) thick.
10Repeat the steps as necessary until the temperature is within the safe range.
11Use a permanent marker to draw a line on the dial after you locate the best setting on the refrigerator temperature dial. This will give you a reference point in case your dial moves and needs to be adjusted in the future.
Hope this helpout...
Aug 09, 2010 | Samsung Refrigerators
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
110 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
