Question about Maytag MMV4205 Microwave Oven
MMV4205AAS no light, no fan...then no power
I have an MMV4205AAS that's about 2 years old. One day the internal light and internal fan (not the range fan) stopped working but it would still cook. I talked to a local service guy who said we could still use it as far as safety was concerned. We did for a little bit (a few days) but now there's no display or power. After reading some other posts here I'm thinking the fan that didn't work was the magnetron cooling fan and that when using the microwave the magnetron overheated and killed the thermal fuse on the magnetron thereby killing power to the whole unit. Does this sound correct? What about the initial light/fan problem? Thanks in advance.
  • 2 more comments
  • nateNYG Jan 31, 2008
    Yes, power to the outlet is good. No problems there. I haven't checked the internal line fuse. There is no power to the control board which I thought was the only way to really tell if the unit was getting power. Nothing works on it right now.
  • nateNYG Feb 01, 2008
    Not yet. I need to go out today and get a new fuse to try that and get a multimeter to check continuity on the thermal fuse. I found a wiring diagram in the control panel and it looks like for both the cooling fan and the light to go bad it would have to be something in the panel itself. At any rate, I'm going to try to get what I need today to at least get it powered again. I'll keep you updated.
    Also, I'm not sure how to fix the rating on this. I don't see anywhere where it will let me change the solution or anything.
  • nateNYG Feb 04, 2008
    I found out the main fuse was good. I jumpered the thermal fuse (magnetron thermostat) and was able to get power to the unit back. I ran it on low for a few seconds to confirm that the light and cooling fan were not working. The turntable and magnetron were both working good. From the wiring diagram the light and fan were both controlled by one relay. I jumpered the relay and both turned on so it looks like the relay is defective.
  • 749 Answers
That's right. Without the fan to cool-off or to maintain and protect the temperature of the unit, it would slowly cause damage to parts until it get worst... you should have fixed it when it was still early... Unfortunately, It already had caused a deep damage.
Have the fan fixed for temperature control.
The light fixed for your knowing that it is ON or working.
Replace thermal Fuse
Check for other parts, like broken connections or soldered parts.
Posted on Jan 31, 2008
  • 770 Answers
Well part of what you said does sound correct other parts dont make any sense.. Question one is the unit dead now?? have you checked the outlet for power??
have you checked the internal Line fuse to see if it is good??
Does the unit have power to the control board?? these questions need to be answered before we can move on ..As far as the light issue there could be a bad relay on the ctrl board but kets get the unit up and working first
  • 4 more comments
  • Gary Davd
    Gary Davd Jan 31, 2008
    PS: the unit could have gotten overheated and blown the thermal fuse which will also kill the pwr to the ctrl board
  • Gary Davd
    You need to also see if you are then getting pwr to the control board too pwr the rest you can as a temp jumper it out and see what else yo uwill need to replace
  • Gary Davd
    And also fix your rating on this job I gave you the answer you were looking for before Lemmor posted Thanks
  • Gary Davd
    Did
  • Gary Davd
    Did you
  • Gary Davd
    get it fixed??
2 Suggested Answers
sharcnet
  • 2130 Answers
SOURCE: No light, internal fan...then no display
The light isn't a safety issue but I would think that the fan would be.
The fan is designed to remove excess heat from unit and keep it cool. Without the fan, you're now operating the unit under conditions that it wasn't designed for.
With the unit unplugged, try removing the cover and see if a fuse has blown. If so, replace it with the EXACT value of the original.
See if the unit powers up again. Try heating heating up something for 30 seconds to see if the Magnetron is still functioning.
If so, check to see if the bulb is good. Did the bulb and fan stop at the same time? If so, it might be something in common that controls both.
Don't operate it further until you have it looked at. You don't want to cause something else to fail.
- Jim
SMEG SA35MX no longer heating. Light, fan & timer all still working but no heat. Approx 2 years old. Is there a fuse or other component I can replace myself ?
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 10, 2010 | Microwave Ovens
[Identical to earlier posting by stefeckstein]
Check for a circuit breaker on the back. If nothing, pull the plug and remove the case. Look for a blown fuse. If so, look for a shorted high voltage diode in the magnetron power supply or a shorted stirrer bearing located above or beside the cavity area where the microwaves enter. The stirrer is a metal fan-like device with a plastic bearing that often arcs internally. That shorts the microwaves out and blows a fuse. Replace the stirrer.
Aug 24, 2009 | Panasonic NN-SN657SMicrowave Oven
Microwave on w/light but fan and heat not working
The problem is the door switch is defective. I'm on my third new switch in 3 years. The part number is 5304440026.
Mar 29, 2009 | Electrolux Microwave Ovens
No power to microwave, changed fuse but still nothing!
There is an internal fuse and internal TCOs (thermal cutouts / thermostats) any of which can interrupt the power to the unit.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
GE Customer Service is here.
They can help you find your
your nearest GE-authorized servicer.
Dec 28, 2008 | GE JVM1440 Microwave Oven
Microwave dead even though power works
It sounds like the magnetron overheated and opened the thermal fuse on the magnetron.
This can be caused when the internal cooling fan is not running or by a magnetron that is failing.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the magnetron will be destroyed.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
The magnetron will have a 5 to 9 year warranty. Your manual will tell you that.
You can download GE owner's manuals and installation instructions here.
If needed, GE may send you a replacement magnetron. GE Customer Service is here.
Dec 04, 2008 | Microwave Ovens
Lg LMV1630st stainless steel microwave oven
I'm confused. If it's 6 weeks old, you can get it repaired free.
If it's 1-1/2 years old, the manufacturer will cover the part cost of the magnetron (assuming that's what's wrong) and you will have to pay for labor and any other needed parts.
Also, the subject line mentions a model LMV1630ST while your message body mentions model LMV1680BB.
For Goldstar / LG / customer service, help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Chances are your problem is a bad magnetron, but it may be another high voltage part.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | Microwave Ovens
- Jim
Jan 31, 2008 | Maytag MMV4205 Microwave Oven
Microwave cooked dinner and now does work
I had the same exact problem -- turned out the cooling fan for the magnetotron wasn't coming on because of a bad relay on the main control board. When the magnetotron overheated a safety kicked on which tripped an internal relay and killed power to the unit. GE repair guy diagnosed and resolved the problem. Only snag was that they didn't have a spare board so I had to wait a few days for them to deliver a replacement and for the guy to come back and install it. Now has been working for 5 days... of course I probably jinxed myself now! :)
Dec 18, 2007 | GE Advantium SCA2001BSS Microwave Oven
Maytag MMV4205 Microwave Oven Logo
187 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
