Question about Bunn Pour-Omatic Coffeemaker, 10 Cup White
Warming Plate I have an older (about 1999) Bunn Pour-Omatic coffeemaker. The coffeemaker still works great but the warming plate has stopped working. Is there a way to repair it? Where would I begin to look for parts?
  • Anonymous Sep 20, 2008
    I have the same problem -- the warming plate works when the on-off switch lights up as "on", but lately I often can't get it to light up when I switch it to the "on" position - and the plate doesn't heat up. Is this fixable? Where would I take it for repairs?
  • kristarrrrrr
    kristarrrrrr Aug 21, 2012
    the switch pops out and 3 leads need to be gently removed, then order thepart, it's name is..."warming switch" their are lighted and solid versions...easy fix if you have a model # , I do not...lol
  • 152 Answers
Actually the warming plate have heating element... they stop working only when the heating element gets open circuited or wire to that plate gets cut....
Posted on Jan 31, 2008
6ya staff
SOURCE:
My bunn pour- omatic only gives warm water --any suggestions?
TRY RUNNING WHITE VINEGAR THREW THE TANK, IT MIGHT BE ALL CALCIFIED AND THIS IMPEDES HEAT TRANSFER .. MIGHT NEED TO DO IT A FEW TIMES , DO IT TILL THE WATER IS CLEAR. JAY THE PUMP GUY FL
Feb 03, 2012 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Overheating water boiling dry
if it is not adjustable you will need a new thermostat. Any bunn service centre should be able to help you out or if the coffeemaker is older it might be worth your while to buy a new one.
Sep 06, 2011 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
We have an older style white Bunn Pour-omatic coffee maker. Model GR. Model # D-267.325. We are looking for the nozzle that screws onto the bottom of the water tank and disperses the water into the...
you should be able to go online and locate a bunn service centre in your area, contact them and purchase a 5 hole sprayhead. It will be metal instead of plastic but will work fine.
Sep 05, 2011 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Have a bunn pour omatic home model older one great cleaned and started to leak. what is this called a small plastic insurt in lid that goes into the hole where the water runs into, the top part in lid...
It is part of the rocker arm. If you will call customer service with the model and date code, we will be able to help you resolve this problem. The number is 800-352-2866.
Oct 14, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Should I leave the Bunn Pour Omatic Coffeemaker plugged in at all times?
Yes, the coffee maker keeps a tank of water pre-heated, that is what allows it to brew coffee in a couple of minutes. The exception would be vacation (away from home) or other times when you won't be using it for a few days. Visit www.bunnomatic.com if you have lost your user manual.
Dec 31, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Need warming plate for Bunn Pour O Matic coffee pot
Due to UL regulations, warmer plates can't be sent out. However, you warmer plate can be repaired for a minimal charge. Please call customer service with the model and date code and we will be happy to provide you with the cost and address.
Nov 26, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Leaking pour basin
Your only hope of getting a new tray for these would be if your local Bunn repair shop has some hanging around that broke down for another reason. This is a very common problem with those models. You can find a list of Bunn repair depots at www.bunn.com Good luck!
Jan 21, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
The water is not getting hot
You can check to see if the switch on the side of the tank is turned on and is working, but if the problem is with the tank heater itself, you can't get replacement parts for this model unless you can find a broken one at a garage sale or a Bunn service center. You can obtain a list of service centers in your area from www.bunn.com
Oct 28, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
BUNN Pour-Omatic
Most likely it is your tank heater, but look on the top of the tank heater, because sometimes the wire will burn off the top of the element
May 20, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn Pour-Omatic Coffeemaker, 10 Cup White Logo
529 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Inky Fingers
Inky Fingers
Marvin
Marvin
littlechum55
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
