Question about Brother MFC 210C All-In-One InkJet Printer
Damm printer my all in 1 printer when paper in place and ready to copy the paper comes out blank.all of the ink is new will not print a word.will not COPY
  • 832 Answers
Did you use generic ink carts before?
It seems that the ink has clogged the whole print head.
Do use original brother ink carts which have special cleaning fluid within the ink.
After that run the manual ink cleaning procedure by pressing ink etc.
Make sure that all carts are placed well and are secured.
Posted on Jan 31, 2008
Ive a kodak printer esp 7250 i have used it a couple times to print off my photos and its been fine,i got the printer out today and put new ink in ready to photo copy and it is not printing for some reason...
How long was the printer stored before you took it out to use it? You can't store a printer with or without ink cartridges in it. When a printer sits, the ink that is in the print heads settles and dries. Once that happens, the print heads are pretty much ruined. You can buy new print heads, but its usually cheaper to buy another printer instead. The reason it is not printing is probably because the print heads are plugged.
May 12, 2011 | Kodak Office Equipment & Supplies
My printer will not print anything on the paper when I press print or copy. However, it is going through the motions as though it is but the paper remains blank. I have replaced the ink cartidges &...
You are doing well, keep trying the ink as it is a new cartridge has to still come through.
Do a few more deep cleans and then print some test pages. You may need to do this a few times.
Thanks michellelwol
Take care!
damnor01
Apr 16, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Changed new ink but when i print, the pages come out blank with no ink. Printing motion takes place but some how the ink done not reach the paper.
I had the same problem with my DCP 165.It simply wouldnt print.The paper was coming out but it was Blank.I had changed all the cartridges so there was no obvious issue with the ink.Then I printed a test page.It printed all the colour blocks except the black.Then i found out from Brother website that it was a problem with cleaning and after seeral cleaning cycles the printer worked fine. STEPS 1>ink management 2>Cleaning 3>Black or colour 4>OK Repeat the above process several times and try printing after that...Hope it works
Sep 15, 2010 | Brother DCP 165C Compact Color Inkjet...
Hi. Printer isn't working, paper comes out blank.
Most likely the printhead is clogged. Another possibility is that the cleaning station does not work. 3 ways the printhead can clog,
1. Using Generic Ink
2. Not using the printer for a long time
3. Print a large print job after the ink indicator says the inks are running low.
You are better off replacing the unit than trying to get the printhead unclogged. Cost is usually around $40 and is only a 65% chance it willwork.
thanks
Dec 17, 2009 | Epson CX4600 Stylus Color All-In-One...
Not printing
When a printer goes through the motions of printing bt delivers a blank paper, it is indicative of blocked nuzzles. Ink may be new, but their nuzzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it the nuzzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a place/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nuzzles, the procedure may be repeated over to get results.
Dec 06, 2009 | Epson Stylus DX8400 All-In-One InkJet...
PUT IN NEW INK CARTRIDGES BUT COPIES STILL BLANK AND PRINTING EVEN CHANGING ALL SETTINGS
how did the paper exit inot your pritner? Its act like printing or its fast and smooth? If its act like printing you just need to clean the printhead or if cleaning printhead did not solve the issue you need a printhead replacement, Now if the paper exit in your printer fast and smooth you need to replace the printer and the printhead., You need to call kodak for support toll free 1 800 421 6699 ext 05., The troubleshooting may apply also for blank documents using word or any other application.,
Nov 16, 2009 | Kodak ESP 5 Printer
Prints Blank Pages...even though ink is full.
problem is likely to be the print head, the ink can dry up inside the print head and block fresh ink from flowing.
you can get print head cleaning solution from ebay, which sometimes works, or else go here to get your replacement print head
www.kodak.com/gb/en/consumer/products/printing-supplies/printhead.../default.htm
the one i have is a clip in clip out part
May 03, 2017 | Kodak EASYSHARE 5500 All-In-One InkJet...
Yellow doesn't print
Try this 1.Try placing sheet of paper on copy board, and run many copies . I ran 25x12 times - still blanks coming out. Run head clean after about each 50 sheets. Persevere
Mar 28, 2009 | HP Photosmart D7260 Printer
Leaking black ink on printed pages
Hi, please attempt to run a numerous blank paper through the printer. This will dry or clean any ink found on the rollers.
Continue to run blank pages through the printer until no more ink is found on the paper, then attempt printing. If ink stains or streaks are still present, the printer may need service.
Tirzo
Jun 12, 2008 | Epson Stylus CX7800 All-In-One InkJet...
My printer won't print.
1:check the usb cable or replace it
2: remove the black print cartridge clean the contacts then reinstall it
Nov 28, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
70 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
