Question about Technics SL-1200MK2 Turntable
TAKE UP PROBLEM
On start,platter moves in jerks.works ok when assisted along(stabilises)fault resumes whenu start up again
  • 515 Answers
Those instructions provided by Jim do not apply to this specific turntable. This person has a direct drive turntable, and have none of the features you mentioned.
You either have a faulty IC on the main board, or your unit might be set to the incorrect voltage setting. If you look under your turntable platter, you will see a VOLTAGE switch. Make sure it is correctly set for your country (115V or 220V). If it is set correctly, then you probably have a bad IC, resistor, or capacitor causing this problem.
Unfortunately, this is not an easy fix, as it will require the use of an oscilloscope and frequency counter to determine the problem.
DJ PRO LAB.
Posted on Feb 24, 2008
  • 2,130 Answers
A couple things to look at. If it is a belt driven turntable, look to see if the belt is slipping. There should be a motor with a pully and a flywheel at the other end that spins the platter. There will be a flat belt connecting the motor pulley to the flywheel. Its possible that the belt is slipping at start-up, since that is the condition when the greatest stress will be on the belt. When you help it along with your hand, your helping it to get it moving, overcoming the slipping and the movement of the flywheel takes over and keeps it spinning after that.
It's also not a bad idea to remove the C-clip that is around the top of the spindle. It's what keeps the platter fastened down. Pull up up the platter and clean the spindle shaft. Dust & dirt can gather in there causing friction. You can pry off the c-clip with a flat-blade screwdriver. Becareful though, the clip can fly off and you might lose it.
Let me know how it went and I can help you locate a belt if that turns out to be the problm.
- Jim
Posted on Jan 31, 2008
Hi having a problem !!
If it has a belt drive, the belt has to be replaced.
Mar 22, 2015 | Technics SL-1210 Turntable
I HAVE A PIONEER PL-30 TURNTABLE AND I NEED TO REMOVE THE 'PLATTER' IN ORDER TO REPLACE THE BELT. THERE IS NO CLIP TO REMOVE. HOW DO I GET THE 'PLATTER' OFF. AGAIN THERE IS NO CLIP FOR REMOVAL.
Pull up on the platter with one hand after you remove the rubber mat. Then hit the center post with a rubber mallet while pulling up on the platter with on hand just hard enough to release the platter from the post. The platter should come off.
Aug 06, 2013 | Pioneer Audio Players & Recorders
Platter Grinding Noise on Aiwa PX-E860
Try to determine if the noise is caused by the motor or the platter touching something. Try moving the platter by hand. Press on it whilst turning to see if it's catching. If you can get the platter off you could try some silicone grease on places you think touch one another.
Jul 16, 2013 | Audio Players & Recorders
The dishwasher won't start, its stuck, pots/pan button is blinking, & the timer has (2)_ _ bars blinking. I tried to reset/pushed the start/resume button nothing happened. I pushed the cancel/drain...
did you hold the start/resume button for at least 3 seconds if this works the dishwasher will start ok but if there is a fault it will fail again best you contact your nearest service agent good luck
Apr 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Washing machine vibrates and starts to wobble excessivly had a repair man look at the machine he said he could not find anything wrong all the shocks and stabilisers were ok.just had a new kitchen...
get another man out,,,,,your washer has a fault with its stabilisers,,,it may need to be reset to your floor is it wobbles its that or your putting the wash load is lumpy,,,
Nov 28, 2010 | Bosch Washing Machines
Disk spins but clicks and Monitor won't
I'm sorry to inform you that the hard drive already gone bad. Clicking sound is an indication of bad hard drive.
Check with some computer stores to see if they could offer a data recovery service so that you could still retrieve the files in that HD.
Have a great day!
Oct 25, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
406 petrol Engine Loosing Power
take the fuel sender out of the tank and check/renew the flexible rubber pipe connection,it could be porous
Sep 22, 2009 | 2005 Peugeot 405
JVC - problem. The turntable does not move,
Most modern day turntables are semi-automatic. You move the tonearm from the rest post
over to the record and the platter will start turning. There is a small microswitch inside
either below the arm base or near. There should be a flat bar connected to the base of the arm
and this will actuate the microswitch. The switch is wired in series to the rotation motor.
Solution: 1. Obviously verify the belt is on. Take off the rubber mat and rotate the platter.
The rotation motor is on the left and it has a small brass spindle. The belt should
be visable through the holes in the platter. If not pull the platter gently up, there will
be some resistance. The belt wraps around a smaller inner ring on the underside
of the platter and the rotation motor spindle. If it is degraded it will be stuck to the
platter or fall apart. Generally there 3 common sizes. ( 21.4 / 23.6 / 25 inch) they
readily available on E-Bay, search term "turntable belt".
2. Obviously check power.
3. Check the microswitch, it should "click", verify with ohm meter.
4. Some turntables have a "cut" or stop function. The arm must return first to rest before
starting again, again the microswitch is the trigger.
Apr 07, 2009 | JVC AL A158BK Turntable
Problems with platter not moveing
Sounds like a sensor or drive moter fault,if you havent had it fixed then u can send it to us.
Regards.
http://www.audiovisualservices.info/
Dec 05, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
2002 Honda Accord. Engine does slow start and jerks
sounds like you have a problem with the spark the coil may be on its way out or there may be oil in the spark plug holls shorting out the spark.
your best bet is to pull the leads out 1 at a time and and look down and check for oil if there is oil there get a new rocker cover gasket.
if no oil refit plug leads loosely and start the car remove one lead at a time slowly and look at the spark cumming out the end off the lead is it blue? if so it is ok if it is yellow and dull you have a coil problem. also check that the spark is only comming out the end of the lead as it may be comming ou the side of the lead and shorting to earth,
you can do this by slowly moving the lead around the top of the sparkl plug holl and see were the spark is comming from
be carfull no to shock your self as it herts like hell
good luck
Nov 21, 2008 | 1999 Toyota 4Runner
Technics SL-1200MK2 Turntable Logo
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
