Question about Lexmark X4270 All-In-One InkJet Printer
Clean nozzle and align program option not working
I click on the clean nozzle option and align option in the lexmark program and neither of them work. I installed the latest drivers and have also removed and reinstalled the program a few times. Option still doesn't work.
Any suggestions??
  • 1 more comment
  • vickilynnkks Feb 01, 2008
    My operating system is windows xp
  • vickilynnkks Feb 05, 2008
    Yes I am using an original cartridge and have now refilled it yet. I do not use the color cartridge so I keep it in a plastic zip lock bag so that it will not dry out. Can leaving that cartridge out cause this problem?
  • Iuliu Ciupe-Vaida
    Iuliu Ciupe-Vaida May 11, 2010
    PLease mention more details, especially the OS u use (XP or Vista?)
    Sergeant:
  • 390 Answers
Leaving cartridges unused unless sealed and brand new, will mostly always result in poor or no function. If you never use colour, do not buy them. Then when you do eventually want one, buy one. I have not yet come across a way of storing cartridges for long periods, apart from my lexmark spare ones which i drain of ink (i do my own ink) and clean with solution, then place upside down on wet paper to unblock head when i want them.
Have you tried simply turning off unit, unplugging, replugging, turning back on and trying again. This can reset errors. lilacgerry xxx
Posted on Feb 06, 2008
  • Bagladi Jan 10, 2011
    How do you make your own ink?
    Sniper:
  • 60 Answers
Of cource leaving the colour cartridge out causes this problem :)))))))))))))
You did not mentioned that, waw, that's a new one LOOL.
Sorry, here it is:
Aligning the cartridges is EXACTLY alingning the black with the color one! So if the one is not in, it's like aligning a stick with itself, how come?
Maybe the nozzle cleanig process is also affectet bt that.
Put the color cartridge in and if it works, rate this answer please as very helpfull! :)))
Anyway, thx, you made my day today, u made me smile, thx again! ;)
  • 417 Answers
Are you using original ink cartridges?? if not replace to original and try as the carts that you are using if have been refilled maybe faulty.
Thanks J
Posted on Feb 05, 2008
  • Anonymous Feb 05, 2008
    Might do install colour cartridge then try
    thanks j
6ya staff
SOURCE:
The printer isnt working keeps telling me printing complete
Follow the steps below to fix the problem:
1. Align the print cartridges (open the Lexmark Solution Center on your computer > from the Maintenance tab, click Align to fix blurry edges > click Print) 2. Clean the print cartridge nozzles (open the Lexmark Solution Center on your computer > from the Maintenance tab, click Clean to fix horizontal streaks.) 3. Remove and reinsert the print cartridges. 4. Wipe the print nozzles and contacts using a slightly moistened soft cloth to clean it from dirt or clogs.
Try to print a document again to verify that the problem is fixed.
Oct 22, 2011 | Lexmark Z1420 Printer
When printing, the blue color is missing
Make sure your print cartridges have enough ink in them for printing.
Print quality issues could be due to dirty or clogged print cartridge nozzles. Please follow the steps below to fix the problem:
Using the Lexmark Solution Center:
  1. Click Start > Programs > Lexmark X6100 Series > Lexmark X6100 Series All-In-One Center.
  2. From the Maintenance tab, click Clean to fix horizontal streaks.
  3. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  4. Print your document again to verify that your print quality has improved.
If the problem continues, try to insert a different known working color cartrdidge or better yet replace it with a new genuine Lexmark cartridge.
If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Oct 11, 2011 | Lexmark X1190 All-In-One InkJet Printer
Not printing magenta
Print quality issues could be due to dirty or clogged print cartridge nozzles. Please follow the steps below to improve the print quality:
On the printer operator panel:
  1. Press Copy.
  2. Press Options until Maintenance appears on the display.
  3. Press the right arrow until Clean Cartridges appears on the display.
  4. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  5. Print your document again to verify that your print quality has improved.
If the problem continues, try to insert a different known working cartridge or better yet replace it with a new genuine Lexmark cartridge.
Should the problem continue, please contact Lexmark Technical Support Center for additional assistance.
Oct 11, 2011 | Lexmark X6170 All-In-One InkJet Printer
Lexmark x6170 not printing magenta
  1. Press Copy.
If the problem continues, try to insert a different known working cartrdidge or better yet replace it with a new genuine Lexmark cartridge.
When printing on x3350 with a new cartridge... get lines that are double and some with thick black ink on some letters.
Try to reseat the cartridges into the printer. If problem continues, then maybe the cartridge nozzles need cleaning. Follow the simple steps below on how to clean the cartridge nozzles on the Lexmark X3350:
  1. Go to Start, Programs (Windows XP: All Programs) > Lexmark 3300 Series > Lexmark Solution Center.
  2. Click the Maintenance tab.
  3. Click Clean to fix horizontal streaks.
  4. Click Print. A cleaning page prints, forcing ink through the clogged nozzles to clean them.
  5. Print the document again to verify that the print quality has improved.
Source: How to Clean the Print Cartridge Nozzles on the Lexmark X3350
Jul 13, 2011 | Lexmark X3350 All-In-One InkJet Printer
Brand new ink cartridge for Lexmark X3650. Error message to remove tape from cartridge. Tape has been removed. Print alignment prints in only black and same thing on cleaning process.
You can try to manually wipe the cartridge nozzles with a moistened soft cloth to clean it from dirts and clogs. You can also clean the nozzles using the Lexmark software on your computer. If you're using Windows, go to Programs/All Programs > Lexmark 3600-4600 Series folder > From the printer folder, click Maintenance > Clean Cartridges > Print. A page prints, forcing ink through the print cartridge nozzles to clean them.
May 27, 2011 | Lexmark X3650 Printer
Recently renewed ink cartridges in Lexmark x4650 with genuine Lexmark replacements and keep getting one or two lines of 'wavy text' per page
This can either be blocked nozzles on the cartridge, or an alignment problem. Go to Start - All Programs - Lexmark - Solution Center and print out a Clean Nozzle Page and an Alignment Page from the maintenance tab. That should fix the issue.
Apr 18, 2010 | Lexmark X4650 InkJet Printer
My Lexmark Z 515 printer does not print clearly especially the second part of a piece of paper. How can I clean the printer?
To improve print quality
1 On the operator panel, press Options repeatedly until
Cartridges appears.
2 Press the right arrow button until Align appears, and then press
Select.
An alignment page prints. Once the alignment sheet prints, your
automatic alignment is complete.
You may need to clean the print cartridge nozzles.
Using the operator panel
Load paper in the All-In-One.
2 Press Options until Cartridges appears on the display.
3 Press the right arrow until Clean appears on the display.
4 Press Select.
A nozzle page prints forcing ink through the nozzles to clean the
clogged nozzles.
5 Print your document again to verify your print quality has improved.
6 Try wiping the print cartridge nozzles and contacts, and then print your document again.
7 If print quality has not improved, try cleaning the print cartridge
nozzles up to two more times.
Using the Lexmark X5100 Series Solution Center
Load plain paper in the All-In-One. 2 Click Start Programs Lexmark X5100 Series Lexmark X5100 Series Solution Center.
3 Click the Maintenance tab.
4 From the Maintenance tab, click Clean to fix horizontal streaks.
5 Click Print.
6 Print your document again to verify your print quality has improved.
7 Try wiping the print cartridge nozzles and contacts, and then print your document again.
8 If print quality has not improved, try cleaning the print cartridge
If the print quality does not improve after cleaning the print cartridge
nozzles, dried ink may be on the nozzles or contacts. To wipe the print
cartridge nozzles and contacts:
1 Remove the print cartridges.
2 Dampen a clean, lint-free cloth with water.
3 Hold the cloth against the gold nozzle area for about three seconds.
Gently blot and wipe dry in one direction (this prevents the colors in
the color cartridge from mixing).
4 Remove the old cartridges
5 Let the nozzles and contacts dry completely.
6 Reinstall the print cartridges, and then print your document again.
7 If the print quality has not improved, try cleaning the print
8 If print quality is still unsatisfactory, replace your print cartridges.
Hope this helps.
Thanks
Have a good day.
Dec 01, 2009 | Lexmark X5150 All-In-One InkJet Printer
Color cartridge stopped working.
Try cleaning the contacts on both the ink cartridge and the carriage with a cotton swab dipped in alcohol. If that does not work, the nozzles on the color ink cartridge may be clogged with dry ink.
There is a nozzle cleaning utility in the Lexmark Solutions Center. Use that to clean the nozzles of your ink cartridges. The Lexmark Solutions Center is installed on your computer. You can find it in the Windows Start Menu under "All Programs" in a folder marked "Lexmark".
If your printer has been sitting without use for more than a few weeks, the nozzles may be too clogged with dry ink to clean by conventional means.
It nothing works, replace the color ink cartridge.
Apr 09, 2009 | Lexmark X6170 All-In-One InkJet Printer
I replaced an ink catrage on my Lexmark Z33 printer and it does not print propertly. It will print some lines on the page properly, but some it skips a line and part of another line and then prints the...
I have an Epson w/c had this problem a # of times. Go to the printer PROPERTIES tab (right click printer icon might work). Click on UTILITIES & you should see options for NOZZLE CHECK, HEAD CLEANING & PRINT HEAD ALIGNMENT. Follow instructions on all 3 until your Print Head Alignment printout is perfect. It might take a few head cleaning procedures
before you get it right. Good luck.
Aug 05, 2008 | Lexmark Office Equipment & Supplies
Lexmark X4270 All-In-One InkJet Printer Logo
67 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
