Question about Uniden BC350C Base Scanner
Uniden bc 350a
Hi, the squlech wont work therfore it wont scan. it has been exposed to some high rf from my cb radio ( about 70 watts) after i keyed the mike, no squlech. i shut it off for about 3 mos, and it worked fine. then i did the same thing. keyed the mike again, and lost the squlech again. is there a better solution? i dont want to shut it off for another 3 mos.
  • 5 more comments
  • jer19541 Jan 31, 2008
    i am a licenced ham for 20 years.
    good for you
  • Anonymous Aug 30, 2008
    programming uniden bc350a
  • Anonymous Feb 13, 2009
    I have a uniden Bearcat BC350A please let me know how to program it. Thank's Rockyn Robyn.
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Got my ticket 29 years ago when I was 17.
  • SHARCNET-USA
    Try operating the CB at it the FCC's "legal limit" of "4" watts and I bet you won't have the problem. That's why the FCC established rules for radio frequency bands.... to prevent interference with other equipment and radio services. You may unknowingly be interferiing with other things as well outside of your home....such as neighbor's TV's, Police/Fire radios, cordless phones.....I'd reconsider the 70 watts and go back to the legal limit before "Uncle Charlie" comes knocking at your door. Ever consider Ham Radio?
  • SHARCNET-USA
    CB Radio?....... 70 watts? hmmmmm.... there's you anwser right there......
  • 204 Answers
Hi, Is you CB gear grounded to an "earth" ground? Also try moving the scanner around, away from the CB coax, as your probably getting stray RF from there. I've run 100watt with my scanner 5ft. away from it and no problems for the last 6 years,,
You are using good quality coax, aren't you? Cheap coax leaks like a soaker hose. Hope this helps you,, Mechanic
** and preaching about ham radio does not solve this persons problem!**
Posted on Feb 03, 2008
When the mike is keyed the needle max out
It sounds like the radio wattage is cranked way up, the RF METER adjustment is not set right (Adjusting VR5 while keying the radio will fix that) SWR is VERY high or there is a break in the antenna line between the radio and the base of the antenna.
Dec 14, 2013 | Cobra 29 LTD CB Radio
My connex cx3300hp wont transmit
You need external watt meter& SWR meter..Change antenna..Is the radio meter keying 3/4 way up to 4 watts?(if not then its not Tx'ng)It could be 10.240 mhz crystal or IF pots(need Frequency counter) Or take it to professional Cb repairmen...
Mar 12, 2013 | Radio Communications
How to fix my uniden president cb radio?////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
Sub another mike, I have seen situations where the mike was the problem, if no change, check the RF output transistor usually heatsinked to the chassis.
Mar 13, 2012 | Radio Communications
Have a new connex 3300hp i can hear everybody else but nobody can hear me when i key up and talk the needle dont even move
look up the tune specs VR13 (L PWR) L32 L33 high power maybe your watts are turned down if it is brand new send it back to the place you bought it from.If the watts are turned all the way down you won't get any carrier your needle is not moving when tranmitting there is no rf power check to see if your tx light is on when depressing the mic button. you should have a rf adjustment turn it clockwise to turn the power up on the front of your radio.or the mods i gave you in the radio.
Mar 31, 2011 | Connex 3300 240-Channels Base CB Radio
Cobra 2000 with a d 104 mic and a palomor tx100 bi linear amp...how can if possible make the amp key up with less than one watt on the ssb side..Radio has a 4 watt dead key on am and i have ajusted the...
Hi, my name is John. Adjust the radio to key 1 watt, then switch to SSB on radio,then switch to SSB on amp, key down and adjust to 1 watt on amp. enjoy !!!!!! ...hope this was very helpful....
Aug 31, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
My 99 dose not rech out very far i need to tune it up how do you pick and tune it do you have a diagram to show how to tune it
Take off the cover, and hook it back up to antenna, and power, set it on AM mode, mike gain at minimum, RF power to HI, connect watt-meter to ant. out-put, adjust VR13, key the mike adjust it for 8-10 watts, do not go any higher than that because you will damage the transistors...Then replace cover and enjoy....hope this helps.....
May 20, 2010 | Galaxy Radios DX-99V 40-Channels Base CB...
I just installed a cobra 29 in a customers truck. Radio gets power but cannot get any feedback
Make sure you have the radio on cb not pa, turn the squelch to the left, turn RF gain to max. check the mike and antenna, key the mike, does it key up?....hope this helps....
Mar 11, 2010 | Cobra 29 LTD CB Radio
Does anyone know the pod too turn for lowering the watts on my connex it is too high and i would like to turn it back also the modulation thanks
You have to adjust the high key first so make sure you're rf power is on high, hope you have a meter set it on the 20 watt scale, key up and turn vr 13
located in back of radio infront of where you're coax connector is until it keys around 12 watts, thats where most connex 33hp should be set,now go to low power and key adjust vr 16 right net to the otherone down to about 3 watts, now you can drive a liners. Mod is Vr 2 right below them two. whistle in mic and turn to get the mod you want.
Jul 15, 2009 | Connex 3300 240-Channels Base CB Radio
Uniden BC350C Base Scanner Logo
480 people viewed this question
Top Uniden Radio Communications Experts
Steve
eradiostore
eradiostore
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
