Question about Panasonic PT-47WX51 47" Rear Projection Television
Power The power will turn on, then once the a picture shows on the screen- it shuts off.
  • 579 Answers
TV's have a circuit that monitors the high voltage and shuts down the set if it senses something amiss.
On projection types, figure on just replacing the entire board that has the flyback transformer on it.
Hope ya fix it!
Posted on Jan 31, 2008
Vizio E470i_A0 shutting off after loosing horizontal frame sync
It could be several things but I'd start with a main board, the fact its shutting off kind of drives me away from Tcon as that shouldn't shut the set down if there was an issue there, it also could be power supply, you could test the voltages from the board once it starts giving issues and if some are off then change the power board.
Dec 10, 2017 | Vizio Televison & Video
Sony KDL-40XBR2 - powers on, backlight is on, no pic, turn it off and back on, same for 10 to 15 seconds, then TV does power off/back on by itself...most of the time picture then shows up.
Depending on your enegy, on home, if is variable or steady 110V
you can check these on your TV, but safety first, or seek a qualify tech:
1) bad capacitor for power module **
2) bad inverter board or capacitors burn.
good luck!
Jan 16, 2017 | Sony Computers & Internet
TAKES 45 MINUTES TO COME ON
Evidently there is an internal power supply problem.
Nov 12, 2013 | Televison & Video
II get sound for about 15 sec. but no picture and then shuts off
kp57ws50_57_in_rear_projection_hd_228277.jpg Problem with Sony KP-57WS520 57 in. Rear Projection
This model is really prone to one problem in particular--screen even briefly comes up bright red, green or blue and set shuts down.
15 seconds from turn on front power light should blink as set checks several things internally---if something wrong it does not let picture show.
Usually after shut down or failure power light will blink a sequence of blinks but not always depending on problem.
Did you see the screen at all go red, green, or blue before?
the more you tell me the better I can help
Mar 28, 2012 | Sony KP-57WS520 57" Rear Projection...
1 year ol 52 inch flat screen with new power supply cycling.
Still sounds like a power supply issue would it still be under repairers warranty
Jan 07, 2010 | Samsung Televison & Video
The wii menu does not appear on the tv screen but have green light on the wii console and i cannot close that wii...someone can help me..
First check your cable connection.
Eject the disk, if you have inside.
Unplug the console at the back
Wait 10 minutes
Plug it back in
Turn it on from the remote
Press reset if it does not show up
Hold the power button to shut it off
Turn it on once more.
If this not help may your Wii need service.
Oct 29, 2009 | Nintendo Wii Console
My Philips plasma only shows half the screen. The other half is just blacked out.
This model has PiP (Picture In Picture), find the button on the remote or check manual, this mode is most likely turned on and is being shared with one of the AV channels, or try turning on a plugged in SCART device to see if this picture shows on the other half of screen.
Sep 14, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Flashing, slow startup, and finally, just snow
Try resoldering the pcb, especially the heat producing components on the pcb, do it with the crt base card too, I guess this will fix this up. Good luck.
Dec 11, 2007 | Sony KV-32XBR48 32" TV
Viewsonic E53 monitor
Base on the information given to me.
I think your computer is on sleeping mode.
first thing check if the video cable is not loose connecting the pc.
because what would happend, if it is loos it would turn on and off at times.
The other thing you can do.
right click on the desktop.
go to properties
go to screen saver
click on power
adjust the time you want your monitor to shut off.
Dec 06, 2007 | ViewSonic G90fb 19" CRT Monitor
Monitor only stays on for 3 seconds
There is probably a bad capacitor within the monitor that will not allow the picture to "hold" in the on configuration. This will need to be replaced. You can send it back to Phillips, or 17" monitors are pretty cheap these days. I would suggest a Samsung or BenQ. They both carry 3yr warranties.
Aug 17, 2007 | Philips 170S4FB 17" LCD Monitor
Panasonic PT-47WX51 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
