Computer won`t boot
I was trying to install windows xp after removing windows 98 and I deleted too much and now when I turn my computer it won`t boot all the way it gets to verifying dmi pool data....
Missing operating system
Then won`t boot up.What did I do and how can I fix it?-Jerry-
  • Jerry Jan 31, 2008
    Can anyone help?
  • Jerry Dec 29, 2012
    got rid of it
  • 62 Answers
Did it came across " blue screen of death or BOOTMGR is missing/ NTLDR is missing
Use Last Known Good Configuration
You can also try to boot the operating system with the LastKnown Good Configuration feature. This feature will allow you to undo anychanges that caused problems in the CurrentControlSet registry key, whichdefines hardware and driver settings. The Last Known Good Configuration featurereplaces the contents of the CurrentControlSet registry key with a backup copythat was last used to successfully start up the operating system. To use the Last Known Good Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].Keep in mind that you get only one shot with the Last KnownGood Configuration feature. In other words, if it fails to revive your WindowsXP on the first attempt, the backup copy is also corrupt.
If the method above can't help you, you can learn backup data when windows won't boot
Posted on Dec 27, 2012
    Genius:
  • 1,142 Answers
U will have to reformat the hard drive and load win 98 or win xp whichever u want to fix this
you can have more detailed info at
http://www.computerhope.com/issues/ch000474.htm
Posted on Jan 31, 2008
  • Jfix Dec 29, 2012
    after a year no longer have that device.
I have a benq joybook 5100 and xp home edition.I formatted my notebook.I want reinstall from Home edition CD.But windows 98 starting... " 98 start file comes and "quick restore" a window comes."english" to...
you can use either two system. just follow  the screen when installing it... put it on the other partition (drive)....
when starting you can select xp or 98.....
Jan 28, 2010 | BenQ Joybook 5100 Notebook
HI my sons acer travel/mate 6292 has crashed and will not boot up, the screen is black but its stating the NTLDR is missing and asking to press ctrl,alt, and delete to restart, yet when I do this it goes...
Hi tracey,
Cause for the NTLDR missing:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable. are
Solutions:
Windows XP users
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Edit the boot.ini on the root directory of the hard disk drive and verify that it is pointing to the correct location of your Windows operating system and that the partitions are properly defined. Additional information about the boot.ini can be found on document CH000492.
If you are getting this error message while you are attempting to upgrade to Windows 2000 or Windows XP from Windows 95, Windows 98, or Windows ME running FAT32 please try the below recommendations.
  1. Boot the computer with a Windows 95, Windows 98 or Windows ME bootable diskette.
  2. At the A:\> prompt type:
    sys c: <press enter>
  3. After pressing enter you should receive the "System Transferred" message. Once this has been completed remove the floppy diskette and reboot the computer.
If you are attempting to add a new hard disk drive to the computer make sure that drive is a blank drive. Adding a new hard disk drive to a computer that already has Windows installed on it may cause the NTLDR error to occur.
If you are unsure if the new drive is blank or not try booting from a bootable diskette and format the new hard disk drive.
It's possible your computer's hard disk drive may have a corrupt boot sector and/or master boot record. These can be repaired through the Microsoft Windows Recovery console by running the fixboot and fixmbr commands.
Additional information and help in getting into the Microsoft Windows Recovery console can be found on document CH000627.
If you have tried each of the above recommendations that apply to your situation and you continue to experience this issue it is possible you may have a seriously corrupted version of Microsoft Windows. Therefore we would recommend you reinstall Microsoft Windows 2000 and Windows XP.
If you are encountering this issue during your setup you may wish to completely erase your computer hard disk drive and all of its existing data and then install Microsoft Windows 2000 / Windows XP. Additional information about erasing the computer and starting over can be found on document CH000186.
This issue has been known to be caused by a loose or fault IDE/EIDE cable. If the above recommendation does not resolve your issue and your computer hard disk drive is using an IDE or EIDE interface. Verify the computer hard disk drive cable is firmly connected by disconnected and reconnecting the cable.
If the issue continues it is also a possibility that the computer has a faulty cable, try replacing the hard disk drive cable with another cable and/or a new cable.
ENJOY! RATE THIS SOLUTION RNJ VINOD KUMAR
Jul 03, 2009 | Acer Aspire 5610-4648 Notebook
Invalid systme disk. Replace the disk and press any key
its domnickr,
its so we can not install xp in model 1255 it will spoils your hard disk all you can install win98 ED 2 only..... so its wise not to try it and reinstall using win 98 install disk. if format is not possible do format using Fdisk command.
step 1 :enter dos floppy
restart ur lap enter from insulation option.
chance boot perority to floppy disk ie Shift +.
restart lap
enter fdisk in commant
format using instruction for any help mail at domnickr@yahoo.com
Mar 21, 2009 | Compaq Presario 1255 Notebook
I have /had Windows 98 on my computer and a friend installed windows xp. I tried to get rid of Xp but lost Win 98, I have the original RestoreDisk for my compaq but it will not let me install to get back...
Have you tried booting the system with the restore disk, well it should reformat the system before it installs a fresh copy of windows 98 so you should back-up data before proceeding and check the boot sequence in your bios, set the first boot device to CD/DVD.
I hope this helps:)
Oct 20, 2008 | Compaq Computers & Internet
NEED HELP
if D drive was a partition on your hard drive it was very likely formatted ....
Robert
Sep 11, 2008 | Compaq Deskpro EN PC Desktop
Plz help me ..regarding uninstallation
go to start then select run and type msconfig the hit enter key
when a window pop up click on the boot.ini then delete the boot partition where windows 98 located then restart your unit
Aug 14, 2008 | Microsoft Computers & Internet
Win xp instalation
Make a windows 98 startup disk by downloading it from here http://ru.dod.net/ben/boot98.exe . Once you haver done that turn off the acerpower insert the disk and turn it on (make sure its set to boot from floppy disks in bios setup) Choose the option start computer with cd rom support. Now after about 1 minute youy should see a:\. Type in a:\fdisk and then choose yes and then create a partiossion using the prompts given . Once you have done that and its finished it should say you must restart this computer so restart it. Then boot from the floppy disk again and when it coms to a: type FORMAT C: and then press y. Once its done take the floppy disk put and restart your computer with the windows xp disk in and it should start installling windows xp.
Jul 08, 2008 | AcerPower Sn PC Desktop
Acer Aspire T180 PC Desktop
if you have windows 98 boot disk put that in, the firt thing you do is to go to f-disk and change the partions in it, then format c: drive. take out disk in A drive put in New windows XP CD and restart. the disk will run and install itself. and thats it. right now your partions are set to read only windows 95, 98, there are 2 options to choose from I belive the one you need is 32.
Dec 17, 2007 | Acer Aspire™ T180 PC Desktop
I cant install windows in my computer
Have you tried another installation CD?
Have you performed a HD format with a Windows 98 boot disk?
Nov 28, 2007 | Compaq Armada E500 Notebook
How to install os
This is a little difficult but it can B done :) Firstly I dunno if ya need to re-format ya drive? perhaps first ya could try to "Repair" of Win98? If that doesn't work,then, perhaps ya may have to re-format. If the Win98 is on a SEPARATE drive or Partition this also makes a difference.... Basically ... repair/re-install win98, then do a repair of ya Boot menu for XP, as Win98 sets up an incorrect Boot up for XP, and thus must be "Fixed" so XP will boot & show a Dual boot menu.. here are some links to help you step by step... http://pcworld.about.com/magazine/2109p156id111652.htm http://www.thehindubusinessline.com/ew/2004/08/30/stories/2004083000250400.htm
Aug 21, 2007 | Microsoft Windows 98 for PC
Computers & Internet Logo
366 people viewed this question
Alun Cox
David Payne
David Payne
