Question about Samsung PCK5315RX TV
Composite video inputs roll vertically
Video inputs from both composite inputs and the antenna all roll vertically and have bad convergence. If I put in a Component signal everything looks fine. ??!
  • 979 Answers
Sync seperator problem, sounds like. Could be bad cable, but I rather doubt it....accordianman
Posted on Feb 01, 2008
What is Bose 321 gsx video format?
The video formats are:
composite video (yellow phono/RCA) - 480i/576i [NTSC and PAL, respectively]
S-video video (black 4 pin din) - 480i/576i [NTSC and PAL, respectively]
Component (3x phono/RCA - Green Blue Red) - 480p NTSC only. Applies just to the DVD player output.
The 3-2-1 system has a couple of composite inputs, one s-video input, no (0) Component inputs. It has 1x composite output, 1x S-video output, 1x Component output.
The Bose system has very basic video handling capabilities. It will only pass through a signal in the same format as it is received. So, a composite signal in requires that the TV or display is hooked up with composite too. IOW, it won't up convert composite or S-video to component.
Sep 08, 2014 | Bose 321 GS series II
How to connect sega master system 2 to lcd plasma tv
If your TV comes with a composite video input then this may not be an issue. You need the RCA AV cable. Sega outputs only mono audio so put Yellow in TV video In and White in TV audio In (white connector).
http://www.gametrog.com/GAMETROG/HOW_to_connect_Hook_Up_SEGA_Master_System_Instructions.html
If you still have the RF box for the Sega then you should be able to put RF from Sega and TV antenna to the RF box and connect RF box to TV antenna in.
If TV is only HDMI input then you need a converter like this
Composite Video to HDMI Converter
Sep 04, 2014 | Video Game Consoles & Games
How do I connect the set top box to analogue television
What type of set top box? What outputs are available on the box and what inputs are on the TV?
For a basic OTA digital to analog converter, you put the antenna coaxial cable to the antenna in of the box. Then either connect the coax out to the TV's antenna in (set the tv and the box to Channel 3 or 4) or connect the composite out to the composite in of the TV (set the TV to the AV source).
For a set top box that has a composite out and a TV that only has a coaxial input, you need to add a RF modulator. Something like this: http://www.radioshack.com/product/index.jsp?productId=2103095 . If you have a composite input on the TV, use the composite cable directly; the modulator will decrease the signal strength.
There are other converters for component out to composite video. See http://www.svideo.com/ypbpr2svideo.html . Going from a digital source (HDMI) to analog can be done but the resulting signal is poor compared to the original. Also DHCP content will not be transferred. See http://www.gefen.com/gefentv/gtvproduct.jsp?prod_id=5280 for an example.
I hope this helps. Please add a comment with the specifics of your set top box and tv for the best choice for your situation.
Jun 29, 2011 | Televison & Video
Having trouble hooking up vcr
I've never seen a VCR use anything other than Composite, S-video or RF analog outputs. That's because VHS uses the NTSC or PAL analog video standards. (In the US, it is NTSC; in Europe PAL is the old standard.)
To use the Composite output, get a triple RCA cable (red, white and yellow connectors). Connect one end of the cable to Video Out (yellow), Audio Out right (red) and Audio Out (white) on the VCR. The other end of the cable goes to the corresponding Composite Video In jack and the adjacent Audio In jacks on the TV. If you are using S-video, (both units must have S-video jacks), the S-video cable replaces the Composite section of the triple cable, so you only need an audio patch cable (two RCA plugs on each end). Be sure to use the audio input corresponding to the S-video input. Note: S-video is generally better quality than composite, although HD digital is still superior.
If you wish to record from the TV, the TV must have a composite video or S-video output. This is not very common. If you wish to record programs from an RF source (cable or antenna), see the next paragraph.
In the days before digital, a typical connection scheme was to run the cable or antenna RF source to the ANT IN coax connector on the VCR, then run a short coax cable from ANT OUT to ANT IN on the back of the TV. This may not work with a digital source. Pre-HD VCR tuners would not be HD compatible, and may even filter out the digital signal in bypass mode (VCR off). You would need an HD to analog converter box at the VCR input to retain this setup. I have no information on your TV's support for NTSC video through the tuner (especially since you did not mention the model : /).
Jun 21, 2011 | LG Televison & Video
Im trying to connect my unit to my tv to record shows and i having trouble doing so please help i am hooking it up wrong
For OTA or CATV signals, you need to daisy chain the coax from the source (antenna for OTA) to the coax input on DVD recorder and then the coax out to the coax input of the TV. If you have a set-top cable box with an incoming CATV signal, it should be connected between the DVD recorder and the TV.
The unit can tune in and record 480i (SD) ATSC (OTA digital), NTSC (OTA analog), analog CATV and digital CATV channels.
A satellite receiver or a non-CATV cable box should get the incoming signal first and then have their composite video output (A/V) connected to the DVD recorder composite video input and then their coax (RF) output (if present) gets connected to the TV. For these, you would record from the IN1 or IN2 (press Select Input) instead of selecting a channel. Then connect the composite video out on the recorder to the TV's composite video in.
Digital signals are either enough to tune in or give no signal. So check that your antenna is correctly oriented for OTA.
Separately, you can connect the video signal when playing DVDs via composite (good signal) out and component out (better signal) out to the TV's matching input. For the component video, the sound is carried on a separate cable. Then set the TV to the input source.
In the case of wanting to watch a VHS tape while taping to a DVD, do not use the Component video source, set the TV to Input 1 (composite).
I hope this helps.
(you can get a copy of the manual here: http://tv.manualsonline.com/manuals/mfg/panasonic/dmrez47v_dmrez475v.html )
Nov 25, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
I have a Sharp LC-32D40U LCD TV. All the inputs for Composite (Y,R,W) are bad and only the S-video input on Input 2 functions. ( I have not tested the HDMI inputs as I ahve not HDMI source). I was told...
Unplug S-Video cable from tv then tyr Composite video input as if S-Video jack is hooked, related composite video input will not work.
Let me know if you need further help.
Aug 17, 2010 | Sharp Televison & Video
I have a samsung led tv and am trying to hook up a wii. The tv does not have component video - only hdmi and usb. How do I hook this up?
I've never heard of a TV not having component cables (the 5 plug cables: red, blue and green video cables, red and white audio cables). I've seen some newer ones without composite (3 cables: yellow video, red and white audio), but never component.
I find is hard to believe it has no component. I looked at some Samsung LED tv's this weekend, and although they lacked composite, they had component. Are you sure you mean component?
The Wii only comes with composite video cables, so you'll need to buy a component video cable for the Wii to hook it up if your TV has no composite inputs.
Component Cables for the Wii
TV's have inputs on the side and rear. If the TV truly has HDMI, USB and nothing else (which I find hard to believe), then you'll need a cheap home theather 5.1 receiver. Ifyou get a cheap one with HDMI out, it should have a few composite inputs on the backside. A cheap sony one can be had for sub $200. If you hook the Wii into the receiver via composite, and the receiver into the TV via HDMI, it will allow you to hook up and play the Wii (and it may upconvert it too, depending on the receiver).
Nov 23, 2009 | Nintendo Wii Console
I have a proscan tv model #PS27108, I do not know how to hook up the dvd player in regards to the cords and what channel to put it on? I would appreciate any help with this! Thanks in advance?
The ProScan will accept input on input 90/91/92 using the connectors on the backside. You can use S-video[the little round black connector] or the composite video [yellow connector] for the video in and use the red / white pair for audio in.
90 selects S-video and audio 1 in
91 selects composite and audio 1 in
92 selects composite in 2 and audio 2 in
Connect these cords to the S-video or composite yellow output, and the Red-right White- left audio outputs on the DVD.
If you don't want to do this, get a RF modulator ~$15, and connect the yellow/red/white from the DVD output to the inputs on the modulator, and then connect the RF [cable] output of the modulator to the antenna input on the ProScan, and tune channel 3 or 4.
tom
Oct 22, 2009 | Proscan PS27108 TV
Composite and s-video inputs stopped working
You may have shifted the input board a little while replaceing the IC's. Double check every plug and connector, not just by visuale inspection, but by going and removing and replacing every connector. I have had problems like this in the pasy and have learned the hard way, everything is not as it looks. Good Luck
Jun 04, 2007 | Philips 60PP9202 60" Rear Projection...
Coaxel and composite jacks produce scrambled picture, componite ok.
Bad hyper board = repair by qualified tech, PCB not available...
Feb 11, 2007 | Toshiba 50HX81 50" Rear Projection...
Televison & Video Logo
96 people viewed this question
Jerry Greenberg
Jerry Greenberg
