Question about GE DBSR453EBWW Electric Dryer
52 inch ( i think ) hdtv
My hdtv wont bring up picture or sound....when u plug it in the code it flashes is 3 long dots......3 times
what is wrong....can u help me
  • robert samples May 11, 2010
    some one might help if you post this in the right spot we have a lot of goodtv people here but your posted under house appliances under dryers
You might want to list brand & model number & other relevant details when you put it in the tv category...just a suggestion.
Posted on Feb 01, 2008
6ya staff
SOURCE:
RCA 52 inch. projection t.v. deflection module repair. Power indicator light comes on flashes 3 times but no picture or sound.
Try website like Tvrepairworld.com buy one their RCA capacitors kit,they put together.The instructional cd came with it,will detail which capacitors require changing.
Sep 04, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My samsung t.v. 52 inches will not come on it
My tv is brand new samsung 32 inches lcd. I accidently press power button several times and now i dont see any red dot. when I use my remote control, i see red dot but thats all
Jun 19, 2010 | Samsung LN52A850 52 in. LCD HDTV
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Self- reboots at start-up, then shows picture but with pink dots.
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts. It is the board to the left and you notice that the four cap tops are swollen.
It is easy to replace get a stanard solder pencil and you are in business.
Thanks for using FIXA, BIG IRISH.
May 24, 2009 | Samsung LNT5265F 52 in. LCD HDTV
Converge off a little and screen has green tint
If you have the remote, go to the setup screen and move the picture. Converge has nothing to do with where the picture sits but, where the red, blue & green dots land. All you should see are pure white dots. There should be absolutely NO color ghost anywhere on the screen. If so, you need a bar / dot generator to set the convergence to center the dots.
Jan 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
1995 rca 52 inch tv...
Please post the model number of your RCA as usually its a bad flyback and start up capacitor when you get a 3 blink error code . But I can help you better if I have the model number of your set.
Oct 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 INCH D52W20B WON'T COME ON
A 1995 60 inch rca good picture and sound. Then it started a cracking noise and a hissing sound, then the picture went blurry. then it was nice picture and sound, then it died. took the back off and turned out the lights. Plugged the tv in and out from the wall socket and there was a sparking noise and a small arc when i plugged it in and out a few times ,at the part that the power plug plugs into.The white part that is beside the white power plug part has thick red wire coming out of it and goes into another plug that has more red wires in it. but the big white part beside the power plug part looks burnt and has black powder on it. that part is probably the problem but maybe not, what it the name of that part and how much would it cost and is it plugged in or soldered.
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
No picture
Does the set turn on i.e do you get any sound ?
There is a inline fuse inside the unit near the power pack.
Feb 01, 2008 | Televison & Video
52 inch aquos sharp tv, d9 model
There are 4 settings for the TV like zoom, stretch, smart stretch, and dot by dot... I personally like dot by dot it has the clear and fitted picture that you might want... Especially with HD chanels put it on the dot by dot setting...
Dec 28, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
GE DBSR453EBWW Electric Dryer Logo
29 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
vince
Marc Taylor
Are you a GE Dryer Expert? Answer questions, earn points and help others
