Question about Coby MP-C582 MP3 Player
Computer wont react to MP3
I have Windows XP, with USB 2.0
Nothing happens when i connect my player to the computer
ANY advice?
  • 1 more comment
  • Anonymous Feb 05, 2008
    i want usb drivers
  • druct8133 Feb 12, 2008
    i have the same problem. Lousy piece of junk. It won't recognize the mp3 player no matter what i do.
  • okslimman1 Jun 28, 2008
    I pluged it into my computer and copied some somgs to it , when i tried to listen to it nothing happon. No lights or anything, the computer can not seen it now.
When you connect ur device with ur computer a window should pop up or if ur computer is windows xp- if it doesnt pop up itself try the hidden icons button it should show a removable hardware icon... then just click on it...
Posted on Jun 12, 2008
    Champion:
  • 207 Answers
Usb doesnt have any drivers
drivers are for the devices which are connected if the comptuer is not responding to the device there might me various issue
first the
check if any other device wd usb port is working or not
then check the auto play optin
check weather the device is detected in device manger or not
then decide wt is wqrong if any other device is being detected by the compter ther will be trouble wd teh mp3 other wise computer
Posted on May 19, 2008
When i installed the media player into my computer. i get a little screen saying usb device not recognized. one of usb devices attachedto this computer has malfunction,and windows does not recognize it....
Hi, smpk4083 mp3 player not recognized by the computer
Why is my smpk4083 mp3 player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see smpk4083 mp3 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the smpk4083 mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: smpk4083 mp3 Players can connect to your computer in MSC or MTP mode. Exceptions are smpk4083 mp3 player Connect and smpk4083 mp3 Express which only use MTP mode. MTP mode is the recommended and default method for smpk4083 mp3 Players when used with Windows OS.
The smpk4083 mp3 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Hope it helped.
Have a nice day,.
Feb 22, 2011 | Sylvania Audio Players & Recorders
Not connet on computer
Hi, Sony NWZB133F MP3 Player not recognized by the computer
4. Power issue.
- Run the hotfix.
For MAC users, see Sony NWZB133F MP3 Player not recognized by a MAC OS
STEP 1 - Connect the Sony NWZB133F MP3 Player to the PC
NOTE: Sony NWZB133F MP3 Player can connect to your computer in MSC or MTP mode. Exceptions are Sony NWZB133F MP3 Player Connect and Sony NWZB133F MP3 Player Express which only use MTP mode. MTP mode is the recommended and default method for Sony NWZB133F MP3 Player when used with Windows OS.
The Sony NWZB133F MP3 Player will show up on Device Manager's right pane as:
Have a nice day....
Feb 22, 2011 | Sony NWZB133F MP3 Player
Can not sync songs on mp3 player
If this problem occurs then your ML648B needs to be formatted.
1. Connect your ML648B to your computer with Windows XP or later.
2. By default your computer will recognize ML648B as GPX MTP Device. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B.
3. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop.
4. Right click your mouse and then select the Format option. When the Format Removable Disk window appears select the Start button to start formatting your MP3 player.
Jan 07, 2009 | GPX ML648B MP3 Player
Trekstor 74412 i.Beat emo 2 GB MP3 Player
I opened Media Player and plugged the mp3 player into the usb port and used the feature called Sync and it started downloading my music onto the mp3 player. I also checked the function in my computer under device manager to make sure the usb port was working correctly.. Hope this helps!
Jan 05, 2009 | Trekstor 74412 i.Beat emo MP3 Player
Try this , plug in usb cord into the emo, simultaneously push the small reset button at the lower right corner under the power button , if that doesnt work here's the link for the xp drivers
http://www.trekstor.de/downloads/produkte/i-beat_emo/driver-tools-win-all_i-beat_emo_v2-620-013_all.zip
(copy and paste )
hope this helps :)
Dec 29, 2008 | Trekstor 74412 i.Beat emo MP3 Player
My computer isn't detecting my Sansa mp3 player anymore.
check for up dates to the software for your mp3 and also make sure you have the right software for the make and model of the computer meaning is it a xp, vista or windows 98 .
windows xp should detect new hardware auotmatically. you could delete the software and remove the hard ware for your mp-3 player and try to reinstall it.
Dec 01, 2008 | SanDisk Sansa m240 MP3 Player
Sylvania SMPK 1021/2021 MP3 Player
have you tried copy and paste or drag and drop.go to your computer and open removable disc or drive or storage device E or F
Nov 10, 2008 | SanDisk Sansa e250 MP3 Player
Connects to the computer but wont turn on
i have the same problem to!! what a heap of ****!
Oct 11, 2008 | Samsung YP-K3 MP3 Player
My computer does not detect my mp3 player sansa 4.0 gb
either unplugg it and try again or try a diff usb port
Jul 22, 2008 | SanDisk Sansa e260 MP3 Player
Coby MP-C582 MP3 Player Logo
73 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
