Posted on Jan 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony hmk-v82 turn table speed. The speed changes slightly all the time, tone in music goes up and down accordingly. What is the solution?
Grubhead
Level 3:
  • Audio Player... Master 5,755 Answers
  • Posted on Jan 04, 2010
 Grubhead
Level 3:
Answers
5755
Questions
Helped
1662531
Points
11417
This is known as wow and flutter. It's generally caused by the belt being lose on a belt drive turntable or the motor on a direct drive one. The motor can cause it too on a belt turntable!
Icom v82 audio
its possible. but ........
if your using it on the amateur radio band the only thing allowed is a roger beep.. by FCC rules.
tip
How can I save Michael Jackson Thriller to my Sony Ericsson Vivaz?
Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How can I save Michael Jackson Thriller to my Sony Ericsson Vivaz?” I was annoyed by this problem for along time, so I post this article to talk about how to download Michael’s Thriller to Sony Ericsson Vivaz. With Sony Ericsson Vivaz, present your best experiences in HD video and personalize your entertainment experiences by downloading great applications through Play Now and the Symbian developer community. I like Michael Jackson very much, especially his music, at the time of his Anniversary, I want to download his Thriller to my Sony Ericsson Vivaz. At first I replaced my old downloader by music downloader from http://www.downloadvideos-convert.com/download-videos-music I want to say that it is really an excellent downloader for download and convert music or video. What’s more, it can help me trim my video of Michael Jackson’s Thriller as the ring tone of my Sony Ericsson Vivaz. Just by drag the slide bar from the start time to end time to cut at any highlight. I can promise that with high quality and fast speed. You can get a free trial from the website. Michael has gone by, it is a fact that we can’t retrieve, and we all miss him very much. There is nothing we can do just collect his classic music with our way. I think Music downloader must be your assistant
on Jun 17, 2010 • Computers & Internet
Need to adjust the neck on a 7 string bass, a conklin.
It appears to have 2 trussrods protruding from beside the nut on the headstock. These set the straightness of the neck. Turning the nuts on the end with usually a 1/4 inch allen wrench is the adjustment. A slight turn to the right brings the middle of the neck up, a slight turn to the left brings the middle down, if laying on a table looking down the neck. I would prop something under the middle to avoid unnatural flexing while I do it. Be extremely careful and allow the wood to sit a spell between adjustments. Make take some time to get it right.
How to set alarm time on bose wave radio
To set the Alarm 1 time - On the control panel, hold down ALARM
SET and press TUNING up or down. The time display changes slowly at
first, then more quickly. Release TUNING to stop.
On the remote, press TIME. The ALARM indicator flashes. Press
TUNING up or down. The time display changes slowly at first, then
more quickly. Release TUNING to stop. Press TIME to return the display
to the current time.
To turn on the Alarm 1 function - Press ALARM MODE or
ALARM in sequence to select the mode you want: tone, radio,
both tone and radio, or off.
For tone only, press until the indicator lights.
For radio only, press until the indicator lights.
For tone and radio, press until both indicators light. When the
alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the
radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes.
To turn off the Alarm 1 function - Press ALARM MODE or
ALARM until the display shows no Alarm 1 mode indicators.
To check the Alarm 1 setting - On the control panel, hold down
ALARM SET to see the wakeup time.
On the remote, press TIME to see the wakeup time. Press TIME again to
return the display to current time.
To wake to a preselected radio station with Alarm 1 - While
holding ALARM SET, press the PRESET button for the station you want
(change between AM and FM if needed).
Air conditioner goes off when fan speed is increased
when it's on 'auto', the fan adjusts according to the temp in the car and the temp setting you have it set at. try setting the auto temp control down to 65, then hit the "-" one more time to send it to "LO" - the fan should automatically jump up to max.
1helpful
Sony grand Wega 50E20000 power light flashes 3 times
Check the fan is coming up to speed when you first switch on it should be high speed then slow down slightly. If the fan is not cooling the lamp the tv will turn off to protect the lamp
FISHER LINEAR T TABLE TONE ARM JUST GOING UP AND DOWN
The electronics on a linear turntable are very sophisticated. A specialist repair shop is your best hope.
Warped record sound?!?!?!
Go to the following reply to your original post:
http://www.fixya.com/support/t303119-technic_sl_1210m5g_problem
1210M5G- warped sound on most records.
I answered here:
 Grubhead
Grubhead
SmartAviator
SmartAviator
