Question about Pioneer PDP-6100HD 61 in. Plasma Television
Color since switching to dish
My PDP 6100h6 61" Pioneet plasma has too much blue and not enough red since switching to Dish network
  • 4,102 Answers
Hi the problem your having is caused by static through the dish cable it will have either blown a resistor witch is cheap to repair the other problem will be the ics these are more expensive and not easy to do unless you are competant in repairing tvs.
If you are able to do repair yourself then you will need multimeter and also a good anti static soldering iron also you will need to get the schematics to follow and to test any test points.
If you are unable to do repair yourself then taking it to repair shop would be best bet as you could damage the telly beyond repair if you are unsure what you are doing.
Its not an expensive repair but unless you know what you are looking for you might never find the fault let me know if you need further assistance
Posted on Jan 31, 2008
DHCP
Hi Harryward_26, my name is Cheri Torres and I work on the Social Media Team at DISH. In order to comply with movie industry standards, DISH network, as well as all TV providers, must enforce content protection standards when required. This message indicates that your TV or connection is not High bandwidth Digital Copy Protection (HDCP) capable. It is likely your TV was manufactured before industry standards required HDCP. In order to resolve this issue you would need to replace your HDMI cable with component cables (red, green and blue). Once you do this you will be able to view the content. If you have any further questions or concerns feel free to email me direct at Cheri.Torres@Dish.com. Thanks!
May 05, 2012 | Philips 42pf9966 42-inch Hd-ready Flat...
Starting last week I am seeing my Pioneer 50" turn
Hi ashutosh8 my name is Mike Houston of DISH Network and Isee you are having an issue with the TV turning off. On the DISH Network remotepress the buttons of Menu-8-7 and you should be on the Inactivity Standby screen.You will need to disable to allow the receiver to stay on. You will want tomake sure the TV is plugged directly into the wall. If you have any further questionsplease e-mail me at michael.houston@dishnetwork.com.
Oct 31, 2011 | Pioneer PDP-5010FD 50 in. Plasma HDTV
We just bought a NS-PDP50HD-09 Insignia 50" plasma
Although we would not be able to assist you with power issue you're having with your TV, I can assure you that the issue with your new HD Insignia TV not turning on has nothing to do with the DISH Network receiver you have connected to it.
Phillip Chang
DISH Network Customer Service Representative
Feb 14, 2011 | Insignia 50 in. Flat-Panel Plasma HDTV
I have the dish network box which is HD although I can get a video feed on the television I get no audio
The first step you want to try is unplugging the receiver for ten seconds. After that check the cabling if you have component cables (red, blue, green, red, white) make sure the red and white are connected firmly. Also make sure they are connected right next to the red blue and green cables on the back of the TV. If you have an HDMI cable try connecting it to another port on the back of the TV. If that fails try replacing the cable.
Daniel Busa
Jan 30, 2011 | Samsung PPM42S3 42 in. Plasma Television
My TV does not display the color red after hooking it up to the Dish Network box. Also the color green looks brown.
If you are using the Component RCA video connectors (RED, BLUE, GREEN) make sure they are correctly attached at both ends.
Nov 05, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Panasonic TH-42PD25 The picture is black with
Make sure if your using the video input jacks, that the yellow is plugged into Video 1 and the same with the audio.Red & White. If your using Component, they are color coded- Red Blue & Green along with the Audio In -Red & White. It sounds like you have the video in the wrong jack.
Oct 28, 2009 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Xbox and dish network problem
if you have like a dvd player then try hooking the xbox up to it in the front where the video is for the 3 plugs then try to plug dish network in the back of the dvd where the ant in plug is at then take the cord from the dvd player and plug it in the back of the tv if this dont work let me know
Aug 08, 2009 | Microsoft Xbox 360 Console
A new HD box from dish network has caused a problem with red tint
Call the dish network as they will fix you up for free rather than lose you as a customer.
Apr 07, 2009 | Zenith IQD61W35 61 in. Rear Projection...
Cannot program sky remote to operate volume control on pioneer pdp-4270xd pioneer plasma 42". have tried using code 0707 as this is the nearest I can find.
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0166
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Nov 28, 2008 | Pioneer PDP-4270XD 42 in. HD-Ready Plasma...
Plasma TV
Try to open the back cover of your tv and reduce the Vs or Vsc (on Power Supply Board) 5-10V below its spec value. Normally the spec value was printed on the back of PDP panel.
Jan 30, 2008 | Televison & Video
Pioneer PDP-6100HD 61 in. Plasma Television Logo
60 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
