Question about Gateway (4000782) Motherboard
Gateway Intel 850 Socket 478 ATX Motherboard
Part # 4000782. I need the Installation book for wiring hook up?
  • Anonymous May 12, 2008
    need Gateway 4000782 motherboard pinout
  • John lamb
    John lamb May 11, 2010
    making sure ur motherboard is a Gateway 478 ATX...
    then :
    http://support.gateway.com/support/manli...
    have fun.
    good Mboard btw.
    cheers, lamby
Http://support.gateway.com/s/MOTHERBD/INTEL/2515762/8508314.pdf
I found the pdf file(manual) for this motherboard kinda by accident but hopefully this could help someone else out. : )
Posted on Sep 26, 2008
  • MERCMAN1974 Sep 26, 2008
    GATEWAY LEXINGTON 3 P4 I850 MOTHERBOARD, 2517202 4000810 INTEL 2 -
    setTimeout('HtmlControlJS.loadFrame(\'ctl00_IWS_WH_CPH_Content_HtmlControl13\', \'\\x3Cform target=\\\"paypal\\\" action=\\\"https://www.paypal.com/cgi-bin/webscr\\\" method=\\\"post\\\"\\x3E\\r\\n\\x3Cinput type=\\\"hidden\\\" name=\\\"cmd\\\" value=\\\"_s-xclick\\\"\\x3E\\r\\n\\x3Cinput type=\\\"hidden\\\" name=\\\"hosted_button_id\\\" value=\\\"26055\\\"\\x3E\\r\\n\\x3Cinput type=\\\"image\\\" src=\\\"https://www.paypal.com/en_US/i/btn/btn_cart_SM.gif\\\" border=\\\"0\\\" name=\\\"submit\\\" alt=\\\"\\\"\\x3E\\r\\n\\x3Cimg alt=\\\"\\\" border=\\\"0\\\" src=\\\"https://www.paypal.com/en_US/i/scr/pixel.gif\\\" width=\\\"1\\\" height=\\\"1\\\"\\x3E\\r\\n\\x3C/form\\x3E\\r\\n\',1033, \'2.02.924.0\');', 0);
    Gateway - Intel Lexington 3 Pentium 4 Socket 478 400/533FSB RDRAM Motherboard,
    With 10/100 Lan,
    Supports 1Ghz - 3.5Ghz in Socket 478 400/533FSB
    Main Specifications:
    Compatible Part Numbers: 2515555 2515556 2515762 2516011 2516014 2516015 2516016
    2516017 2516079 2516080 2516081 2516298 2516309 2516310 2516311 2516312 2516560
    2516561 2516562 2516563 2516564 2516565 2517110 2517112 2517117 2517118 2517124
    2517125 2517126 2517127 2517191 2517193 2517194 2517195 2517200 2517201 2517202
    2517203 2517204 2517205 2517638 2517641 2517863 2517866 2517882 2517885 2517887
    2517888 2517889 2517890 2517937 2517937 2517939 2517944 2517945 2517950 2517951
    2517952 2517956 2518001 2518002 2518003 2518347 2518738 2519060 2519077 2519082
    2519088 2520382 2520532 2520532 2520683 4000779 4000796 4000782
    4000810 700S 700XL 700L E4650 Lexington 2 and Lexington 3
    Manufacturer: Intel
    Type of Motherboard: Standard ATX
    Socket: 478
    Expansion Slots: 5 PCI, 1 CNR, 1 AGP, 4 RIMM
    Chipset: Intel i850
    Front Side Bus Speed: 533Mhz FSB
    Supported CPUs: P4 1.0Ghz-3.5GHz, 256/512K Cache Chips with 400/533MHz
    FSB Socket 478 Celeron 1.7GHz-2.4GHz
    Socket 478
    Connectors: PS/2 Mouse, PS/2 Keyboard/ Printer Port, (4) USB Ports, 1 COMM
    Ports, 10/100 LAN
    Supported Memory: PC600/800/1300 184PIN RAMBUS Memory
    Operating Systems: Windows 98, ME, 2000, XP and NT
    These boards are Intel made boards for Gateway, so you will see a Gateway logo come
    up when booted.
    download drivers here:
    http://support.gateway.com/support/drive...
    Detailed Specifications:
    Form Factor ATX 12.00 × 9.60 inches
    Processor 478-pin zero insertion force (ZIF) socket supporting:
    Intel® Pentium® 4 processor
    Up to 533-MHz system data bus (System data bus speed is determined by the processor.
    The minimum speed for the Pentium
    4 is 400 MHz.)
    Memory Two Direct-RDRAM channels with two RIMMs per channel (four RIMM sockets)
    Support for up to 2 GB of system memory using PC800 or PC1066 RDRAM
    Chipset Intel 850 chipset, consisting of:
    Intel 82850E MCH
    Intel 82801BA ICH2
    Intel 82802AB 4-Mb FWH
    I/O Control SMSC LPC47M142 LPC bus I/O controller
    Video AGP connector supporting 1.5-V 4X AGP cards only
    Peripheral Interfaces Six USB ports
    One serial port
    One parallel port
    Two IDE interfaces with Ultra DMA 33 and ATA-66/100 support
    One disk drive interface
    PS/2 keyboard and mouse ports
    Expansion Capabilities Five PCI bus add-in card connectors (SMBus routed to PCI bus
    connector 2)
    BIOS AMI BIOS (resident in the Intel 82802AB 4-Mb FWH
    Support for APM, ACPI, Plug and Play, and SMBIOS
    Instantly Available PC Support for PCI Local Bus Specification revision 2.2.
    Suspend to RAM support
    Wake on PCI, CNR, RS-232, front panel, PS/2 keyboard, and USB ports
    LAN Wake Capabilities Support for system wake-up using an add-in network interface
    card with remote wake-up capability
    via the PME# signal
    Hardware Monitor Voltage sense to detect out-of-range power supply voltages
    Thermal sense to detect out-of-range thermal values
    Fan control and monitoring
    Hardware Monitoring Features Two fan sense inputs used to monitor fan activity
    LAN Intel 82562ET 10/100 Mbps Platform LAN Connect (PLC) device
    USB 2.0 Support for USB 2.0 devices
    The USB 2.0 option is supported on the front USB ports and the two rear USB ports
    under the NIC. At this time, this option is only supported in Windows® XP and Windows
    2000 with installed drivers.
    LBA Support for 48-bit Logical Block Addressing (LBA)
Here is a link to find wiring, and pin positions on a gateway lexington mobo
http://support.gateway.com/s/MOTHERBD/INTEL/2517944/2517944mv.shtml
happy hacking
Posted on Oct 19, 2008
ONLY 40 NS RAMBUS TOO !!!!!
Posted on Apr 20, 2008
    President:
  • 2,351 Answers
The Intel 850 Socket 478 will help but what is needed first is the model number. Ex: "Gateway GZ7108", the Serial Number would be best. If you do not know where the serial number is you can click the link below & pick a Pc from the list that looks like your.
http://support.gateway.com/s/MISC/CustIDSerial/Gateway_Learningsu4.shtml
Once the serial number is found and added to the search a manual can be searched for a download.
Posted on Feb 01, 2008
Need display driver
http://download.cnet.com/mobile-intel-r-945gm/3000-2098_4-98144.html
http://download.cnet.com/intel-r-82852-82855/3000-2098_4-94913.html
if these driver packages are not right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name display driver you might have to try a few times to get it right
hope this helps
Jun 18, 2012 | Intel E210882 Motherboard Socket Micro Atx...
Dear Sir, my mother board d101 has been damaged can i use of p4sd m/b insted of that while i want all rest parts remain using i dont want change ram,SMPS, Proccesser etc.
fbhushan, the Intel D101GGC motherboard (Grand Country) supports;
1) Intel Pentium 4, Intel Celeron D, and Intel Pentium D processors that fit in an
> LGA 775 processor socket.
http://en.wikipedia.org/wiki/LGA_775
The Processor has the socket holes, and the processor socket (LGA 775) has the pins.
775 socket holes, and 775 pins.
The Front Side Bus (FSB) can be either 533MegaHertz, or 800MHz.
2) Supports DDR Sdram ram memory at either 333MegaHertz or 400MHz.
(PC2700 and PC3200, respectively)
Will support Up To 2GB of ram memory.
Has two ram memory slots. The maximum amount for EACH slot is 1GB
3) The SMPS used for it has,
A) One 24-pin ATX main power cable
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
B) One 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
The Intel D101GGC motherboard has Four SATA headers (Connectors) on it, so I'm going to assume you are using a SATA harddrive.
This would mean the SMPS you are using should have at least one SATA power cable.
It should also have an assortment of 4-pin standard Peripheral power cables.
(Misnomered as 'Molex')
The Asus P4SD (Motherboard chipset Intel 865PE) supports;
1) Intel Pentium 4 and Intel Celeron processors that fit in a > Socket 478 processor socket
http://en.wikipedia.org/wiki/Socket_478
The Processor has the pins, and the processor socket has the socket holes.
478 pins, and 478 socket holes.
Your Processor will NOT work.
The Ram Memory WILL work.
The SMPS MAY work.
I state MAY because the Asus P4SD motherboard uses a 20-pin ATX main power cable.
If the last four pins of the 24-pin ATX main power cable that you have on your SMPS right now, Do Not remove, you can Carefully cut them off. Wrap them up, and out of the way.
If you need guidance on this I can help instruct you.
You need an IDE (PATA) harddrive, or a SATA adapter card to use a SATA harddrive.
So there you have it sir.
Regards,
joecoolvette
Nov 22, 2010 | Intel D101GGC Motherboard
Does the MB support an Intel Prescott 3,06 ghz fsb 800mhz processor?
that is a socket 478 board. it supports northwood and early prescotts. prescotts at 3.06 with the 800mhz fsb were made in both socket 478 and lga 775 forms, so you have to make sure that your processor is indeed a socket 478 model.
Nov 06, 2010 | Abit IC7-G I875P;SOCKET 478;800MHz...
I put my 3 0 ghz cpu in my Gateway Intel 850 Socket 478 ATX Motherboard no video from agp is new board with 2x 256 rimm pc 800 pc seems to start all the fans as well new power supply 512 ati vid card but...
Remove the BIOS recovery jumper near the battery on the motherboard and attempt to boot. If the system displays a startup screen, replace the jumper on pins 1 and 2 (pin 1 will have an arrow by it) and configure your bios appropriately.
Mar 16, 2009 | Computers & Internet
Power supply died for old computer socket 478
yes, replace it with the same ratings of the original power supply
Jan 14, 2009 | Gateway (4000782) Motherboard
Gateway Intel 850 Socket 478 ATX Motherboard Power Supply
Please use the following as a reference: ATX12V Power Supply Design Guide, http://www.formfactors.org/developer/specs/ATX12V_PSDG_2_2_public_br2.pdf
Sections 4.5.2 and 4.5.3 (Page 38) list the signal and wire colors for the +12V2DC (2x2 pin) and Peripheral (Molex) Connectors. Figure 11 (page 36) shows diagrams of the connectors and pin-outs for reference.
Most likely, you are looking for the 2x2 pin connector; pins 1&2 are common (black wire), pins 3&4 are +12V2DC (yellow wire w/black stripe)
Dec 14, 2008 | Gateway (4000782) Motherboard
Fan and heatsink
Just ask for the fan & heatsink for the 478 socket. Its easily available in the market../
Nov 16, 2008 | Intel D845GRG Motherboard
Wiring off tower into motherboard for gateway intel 850 motherboard scoket 478 mod. # 4000782
thanks for the help. but it ended being a inteldesktop board model D850EMV2. I now have all the paper on it from Intel, agin I say thanks for the help
Jul 21, 2008 | ASUS A7S333 Motherboard
Gateway Intel 850 Motherboard will not boot
Please download a memory (RAM) testing program for free. Click the link. http://www.memtest.org/
This program will allow you to make either a bootable floppy disk or a bootable CD. Before you can use the above program I will need the correct model No# for the Gateway, found on a sticker somewhere in the PC case along with the serial number.
The information regarding you're board is incorrect. You can find the boards model number written in white lettering somewhere on the board or on the side of a PCI slot.
The link for the Intel 850 is listed here.
http://www.intel.com/design/chipsets/850/
Gatway's link here.
http://support.gateway.com/support/drivers/dlcenter.asp
I'll check back from time to time & check if you have found the correct information.
Good Luck
Mike
Apr 14, 2008 | Gateway (4000782) Motherboard
Gateway (4000782) Motherboard Logo
3,882 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
