Question about Toshiba Tecra A4 Notebook
Screen Fading My Tecra A4 initially works as it boots up WIndows XP, however the screen then randomly flickers and ends up being so dark that you can barely see whats actually on the screen. This all happens before I can even login to Windows. It then stays like that until you restart again.
    Genius:
  • 1,601 Answers
Kvnfaber:
The inverter board on your laptop is failing. It is a board that changes DC to AC voltage, and powers the backlight. It needs to be replaced.
Posted on Jan 31, 2008
Screen flickering with lines and static.
I would install Windows and see what happens.
Mar 06, 2014 | Acer Aspire 4720 Notebook
Tecra m3 screen
my dvd door wont open
Dec 08, 2012 | Toshiba Tecra M3 Notebook
I installed windows xp on my toshiba tecra m4. How stylus pen works?
Toshiba Tecra M4-S435 is Tablet PC. Windows XP (Profession) has no option of touch screen.
In order to use the feature, you need to install Windows XP Tablet PC Edition or you may install Windows 7, which supports this feature and you would definately be able to use stylus and touch screen, as I have installed Windows 7 and its working fine with all the drivers etc.
Hope it helps! Good Luck!
CreativeTECH
Apr 23, 2011 | Toshiba Tecra M4-S435 Tablet PC
Toshiba tecra M3 wont start. Upon startup it shows a black screen and says problem loading operating system
download form bootdisk.com "XP Boot" and burn to cd in an .iso (bootable) format.
boot from the cdrom (you may have to go into BIOS and look for a "boot priority" option to allow you to boot from cd, to acess BIOS, hit "escape" and then either "F1" or "F2" as soon as you turn it on). run fdisk /mbr from the XP Boot cd. with this tool, try to repair the mbr. if that does not work, you need to use this tool to erase the mbr and reinstall windows.
Nov 06, 2010 | Toshiba Tecra M3 Notebook
Screen does not work
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 04, 2009 | Toshiba Tecra 8100 Notebook
Tecra m1won't boot up properly.
1. Switch on your computer and press F8
2. you will find some options on the screen... such as SAFE MODE and many options which is related
to windows boot up.
3. select safe mode
4. Now you will be entering into windows XP in safe mode
5. uninstall the last software which you have installed, may be with some installation your computer
trapped in trouble..
6. restart your computer
7. if the problem doesn't cleared, then again goto safe mode which you have done in step 1,2,3,4 and
take backup if you have any important documents, if not, no problem leave it and shutdown your
computer.
8. Re-install your Windows XP service pack 2
hope your problem may solve.....
Jun 21, 2009 | Toshiba Tecra S1 Notebook
After downloading windows xp service pack 3: screen turned black boot failure/won't bootup without CD old files missing screen flickers hardware missing
you will have to restor it to factory stetings there is nothing else i can think that you would be able to do
please rate my help to you
thank you.
Apr 22, 2009 | Computers & Internet
Toshiba won't boot
 You can boot from XP cd.
When prompted..press [R] this will launch recovery console.
Choose your windows installation (typically by pressing [1] press return..
When prompted for password type chkdsk /r
Press return..Windows will fix errors..type Exit and press return..
Let me know if that helps.
Jan 05, 2009 | Toshiba Tecra A8-S8314 Notebook
My Tecra 8100 will no longer boot
GO I2 THE BIOS SET UP DEFAULTS ,SAVE AND EXIT ,IT SHOUL DBOOT OFF THE CD DRIVE THEN H/DRIVE DEPENDS HOW YOUVE GOT IT CONFIGERD
Oct 28, 2008 | Toshiba Tecra 8100 Notebook
Mr l carter
Go to BIOS and have the cdrom as first boot device.
look at screen, you may have to hit a key to start boot from cd.
Let me know how it works out for you.
thanks
Dec 11, 2007 | Toshiba Tecra M1 PC Laptops
Toshiba Tecra A4 Notebook Logo
90 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
