No disply monitor
Cpu run --monitor power on but monitor no disply ........
    Champion:
  • 217 Answers
Check your cable connection
Posted on Jan 31, 2008
  • Mike Wright Feb 01, 2008
    Also- In your display properties, on the screen saver tab, click the button that says Power. Make sure your hard disks aren't set to turn off after a certain amount of time.
    Master:
  • 619 Answers
Hi, check all connection monitor power cord and push socket and tightened two screw reset computer .
My cpu is front light on but not go to disply powr fan is ok runing but not show the disply plz help me any on
check the display monitor cord to CPU if attached perfectly/check on off switch of display screen
Feb 23, 2015 | Computers & Internet
Samsung syncmaster 912T disply will disapear. moniter still on just not getting info from cpu. after it is on for and hour somtimes it will not show display
Your description suggests the fault is with the screen, not the system. Can you you test that by connecting both screens to a buddy's computer?
When first powers up display is fine suggests a bad solder joint, revealing itself after heating up.
Oct 27, 2017 | Samsung SyncMaster 912T (Black)
My computer turns on but my screen wont HELP NOW
please check on cables connecting the monitor to your tower/cpu. make sure both ends are plugged in tight. check on the monitor power light aswell, if its blinking or not, if the monitor has been more than 5years old too, its possible thats already dead computers have a life time too especially the old models.
Apr 06, 2011 | Computers & Internet
I used CRT monitor now iconect hcl 710 Lsa model lcd monitor no signal disply. an other cpu accept his monitor working good what problem ? My cpu core 2 duo intel prosser 2 gb ram 2ghz
Possibly, the CRT monitor was set to a frequency which is too high for the LCD monitor.
Try booting in Safe Mode (press F8 at boot), then set the video for a lower resolution.
Reboot with the new, lower, resolution.
In Control Panel choose Hardware, then Scan for New Hardware and get the LCD monitor recognized.
Then, from the Desktop properties, you will be able to see all resolutions supported by the monitor.
Nov 03, 2009 | Honeywell Computers & Internet
Monitor display problem..
Change yor keyboard. If any one key remains pressd or if any pin is bent then evrything seems to work but there is no Display and no beeps or error messages either!......i too suffered the same once................sodeep
Mar 18, 2009 | Computers & Internet
No display
check if all cables are connected.
turn on pc...observe all lights
test the monitor to other pc...
if monitor is good
check if everything inside the CPU are connected.
Mar 13, 2009 | Mercury P4VM800M7 Motherboard
My monitor keeps turning off every like 5 minutes and i dont know
u have to check the power cable and data cable connect with cpu and monitor. if problem is not solve then go to control panel and trobleshoot the disply device ie; monitor
Mar 03, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Blank screen
first identyfy the problem in cpu or monitor.
remove the disply cable in cpu, menu or white screen is comming. monitor is ok . problem in cpu.
Sep 12, 2008 | Computers & Internet
Monitor problems
if u get normal beep of ram then check your disply resolution .
when u start your pc press F8 key continus then if u get menu choos best configuration loading in menu.then change your resolution to 800x600 or 1024x768 .if u not get menu and your cpu ;s smps still work but not disply on monitor then clear your bioss . get away the cmos cell for 15 minutes from its case.then start your pc .i think your problem is solved.
Mar 20, 2008 | Computers & Internet
The power on my pc keeps recycling
remove all hardware except RAM n CPU and then try it if the system gives you a disply then add all hardware 1 by 1 and keep checkin this way you can find the problem with the harware compatibility if the system wont disply then check the mobo for RAMs and CPU respectively if the problem presists then you have the BAD BOARD.-
Jan 16, 2008 | Intel D845GLLY Motherboard
Computers & Internet Logo
64 people viewed this question
Alun Cox
David Payne
David Payne
