Question about Dryers
Zanussi TDE4234W Tumble drier noise
My dryer has suddenly made a loud grating sound. The drum will turn, but it is very stiff and noisy. Is it worth fixing or is it a big job?
  • Anonymous Mar 19, 2008
    I have the same problem. Did you ever find out what the fix is?
  • 126 Answers
Probably the gliders is worn.
Posted on Jan 31, 2008
Why is my tumble dryer making a loud banging noise when on its a white knight model CL3A
Most of the time a tumble dryer will work like a dream but, as with all appliances, occasionally there will be technical problems.
If your tumble dryer is making a banging, whining (or other strange noise) it's best to diagnose and sort out the problem. It could be the result of a number of things, but what you certainly don't want to do is ignore it.
Here are the most common reasons for your tumble dryer making odd noises.
Coins and keys
One of the most common reasons for a banging, rattling or clanking is keys or coins left in pockets - so always check them before you put any clothes in the tumble dryer. More often than not you won't hear anything until the dryer cycle is in full spin.
Uneven surfaces
If the dryer is vibrating or shaking during spinning, check to make sure the dryer's sitting on a level surface. If it's fitted with height adjusters on the front legs, adjust them accordingly to ensure the machine is level as this will often reduce or eliminate the banging sound.
Drum bearings
If the tumble dryer is noisy when its turning and the whole appliance is shaking and rumbling, it could be indicative of a problem with the drum bearings, which help the wheels turn freely and easily.
The drum
If the banging noise is continuous when the drum is turning then it might be problem with the drum itself. If the noise is a metallic one, it could be the result of the drum scraping on something inside the machine. You could always check the drum visually for any marks or dents.
Motor bearings
If the tumble dryer is emitting a high-pitched screaming or whining noise it could be a sign that the motor bearings are wearing out.
Tension pulley wheels
If there's a squeaking noise coming from the dryer it could be the result of wear on the tension pulley wheels. This occurs more frequently on older models...or try this link..
Common Tumble Dryer Problems
Dec 09, 2016 | Dryers
MY FRIGIDAIRE MODEL FAQE770KW0 DRIER IS MAKING A LOUD NOISE AFTER IT GETS HOT
you might need a new roller on the back of the drum, As for being louder when warm it's the part getting hot from Friction that is wearing the roller or roller pin down.
Oct 09, 2014 | Frigidaire FAQE7077K Electric Dryer
Zanussi tc470
DEFO BEARINGS WHEN YOU SEE THAT DUST A REAL SIGN
Jan 22, 2014 | Dryers
Hoover HDV 7 FM tumble drier. The drum is not turning (its making a loud buzzing noise like its trying to get going) and the filter light is on, although that is free from fluff. Is it time for a new drier...
sumanth m 's answer may well be correct because I have the same dryer and it has the same problem. I got a massive electric shock off mine and so I think the buzzing is a protection measure against a short circuit
Feb 15, 2011 | Hoover HDV7FM Electric Dryer
High pitched squeal when running. Capacity Plus Gas Dryer ten years old.
tumble dryer / twin tub is making a loud rumbling noise when running, unplug it, take the rear cover off and remove the drive belt. Then turn the inner drum by hand. If there is a grating noise, the bearings will almost certainly need replacing
Mar 09, 2010 | Dryers
Tumble dryer works ok but its really really noisy.
Sounds like you have a bad drum bearing. It's seems loud because the clothes drum aplifies the noise. Depending how old it is will determine if repairing is worth the cost. Once you have decided that, replace the drum belt and check all bearings including motor. Clean out all lint which can become a fire hazard.
Oct 15, 2009 | Dryers
Noisy drier
I had the same problem with my dryer. The large cloths drum rides on two wheel bearing rollers that are mounted behind the drum. If one of those bearings to the rollers wears out, it will make a loud racket. If you want to repair it your self, purchase a repair manual for your model dryer. Then Disessemble the front of the dryer to expose the large drum. Remove the belt that goes around the drum. Then remove the drum. You will then be able to see the two rollers that the drum rides on. Go to your nearest parts store and replace both of them. Good luck.
Oct 02, 2007 | Dryers
Noise from dryer
drum has worn drum bearing dryer top AND rear panel must be removed to acess the rear of drum to replace drum
Sep 24, 2007 | Zanussi TC7102W Electric Dryer
Dryers Logo
295 people viewed this question
Top Dryers Experts
