Flex cable(flat type)
My laptop was dropped and the lcd got black, but when u power it on you can hear the sound that its ok and problem is i dont know what to do should it be the flex cable or the lcd itself?
    Problem Solver:
  • 6 Answers
If the screen isn't visibly damaged(cracked or shattered) it is either the CCFL tube $15 part on ebay or an inverter board that either has a loose connection or is bad. The flex cable rarely breaks unless the lcd was seperated from the laptop and/or pulled on. The flex cable may have come loose from the back of the screen as well but it just plugs back in like anything else.
Posted on Jun 26, 2009
    Champion:
  • 217 Answers
The cable isn't nearly as fragile as the LCD screen. It sounds like the screen is broken. The flex cable is alot cheaper to replace, so you can always try that first.
Posted on Jan 31, 2008
Acer 4552 dead screen
hi,
check lcd cable
replaced lcd panel
Apr 06, 2014 | Acer Aspire 4552 Series Laptop Power AC...
Red and yellow horizontal lines on the last third of the screen
3 Options
LCD damaged
Flex cable from MB to LCD
Graphic card damaged
First try to connect the laptop to a external screen...its ok???
Remove the lcd and try another one...its ok???
If not....change the flex....its ok?
If not...only one option...graphic card (GPU)
Feb 26, 2014 | DELL Inspiron 15 3520 Cnfg 2 Lptp 3Yr 2nd...
Acer 4745g black screen problem
So, if you can hear startup sound then motherboard, RAM and HDD is OK! Try to connect it with external monitor, if it's working on it, then problem in LCD, LCD light or LCD cable. If not working with external monitor then it is video card problem, if card is integrated then you need to reball or change at all south bridge on the motherboard, if video is as module card then just replace it with compatible one.
If LCD cable - disassemble laptop to get LCD cable and test each wire with any multimetr with sound beep and replace it if needed.
If LCD light - try to take LCD screen under good lamp then power on laptop and carefully look to dark screen if you see very dark Windows boot screen then you need to disassemble LCD housing, disassemble LCD, remove and replace LCD lamp with working one.
If all this cant help, then you need to replace LCD at all.
Nov 15, 2012 | Computers & Internet
Hp8710w
Have it checked in service. This could shortcircuit the display and burn it
Oct 12, 2012 | HP Hewlett-Packard Compaq 8710w Mobile...
Black screen but i do have sound
HelloCheck the backlight inverter board. If it has damged, most common fault to LCD TVs, there will be no backlight to the LCD screen, and will look black. Your tV has sound output without picture. This means that all other boards ar functioning well. Check the backlight inverter section and CCFL tubes used in backlight assembly. OK.
Dec 20, 2011 | Hisense TL1700 17 in. LCD Television
My phone is switching on ok and the screen is lighting up but nothing is happening.One minute it was working, the next it went blank. I have been told that it needs a new screen but I dont know why. It...
Hello
I suspect a flex problem
The flex is what connects the screen of the phone to the board of the phone.
what you are experiencing is common with all flip phones and slide phones, the more you flip and slide these type of phones,the flex gets weaker and that may be the cause of the blank screen
What you should do is;
Open your phone,you will see a plasticlike cable connecting your phone screen to the board of your phone(that is the flex)
Remove the flex and fix it back carefully, you should hear a click sound.
Close your phone and switch it on you wont have a blank screen anymore.
if you cant do this yourself,get a person with experience to do it for you
Thank you for visiting fixya
Mar 01, 2010 | Nokia 6270 Cellular Phone
Screen does not lightup nor display
If the flex cable is ok, you're lcd inverter or the actual lcd may be bad. try using an external monitor and see if it works. If not, you may need to call dell for lcd replacement.
Regards,
Melgasbal
Feb 22, 2010 | Dell Studio 1537 Laptop
Black screen but still able to hear sound. Have tried turning off and leaving off for 24 hours and still no joy
This sounds like an LCD problem. My tv did something like this. Only my screen lit up and flashed random colors.I took it to a shop and was told the LCD was bad and throw it away.I kept the tv and just found a replacement LCD on EBAY for a grand total of $88.Now I can fix my tv for a fraction of an new one. The part number is LTM190M2-L31.I hope this helps.
Jan 14, 2010 | Samsung LN-T1953H 19 in. LCD HDTV
HI MY HP COMPUTER HAD SOUND YESTERDAY AND NOW TODAY NO SOUND WHAT DID I DO WRONG
check if the laptop has an external volume control with a on/ff click or maybe the volume is at minimum. IT could be also that is muted. make sure the MUE is OFF the volume is at max and then reboot the laptop.
Jun 11, 2009 | HP Pavilion dv6000z Notebook
Flashes a black screen while playing a ps3 game.
It sounds as if the set is losing & recovering sync; these are the signals that tell the set when to start painting a line of horizontal and a frame of vertical. Try to catch the thing doing this while holding the cable from your game system to the TV and whether moving/flexing the cable causes it to go to black or return from it.
Dec 15, 2008 | Philips 42PFL5603D 42 in. LCD HDTV
Computers & Internet Logo
332 people viewed this question
David Payne
David Payne
